Old 03-26-2013, 12:52 AM   #1
atm0706
Member#: 279219
02 WRX, 06 STi
PSM, WRB
Default Broken nipple on td04 outlet
I just got this turbo from another member on here and the nipple for the vac line on the compressor housing was smashed to hell during shipping. Can this nipple be replaced easily? And how do I go about doing that?
It really sucks because I bought this to replace a broken turbo... Now I have 2 broken ones...
Here are pics of the nipple I'm talking about:
Any fixes are welcome. I just don't want to have to shell out a bunch of money again...
Thanks,
Alex
atm0706 is offline   Reply With Quote
Old 03-26-2013, 12:53 AM   #2
hella_sti
Member#: 139289
2003 WRX Wagon
drill it out and tap it for a barb fitting, no big deal
hella_sti is offline   Reply With Quote
Old 03-26-2013, 12:59 AM   #3
Andrewxxcarlson
Member#: 316415
2006 WRX
Bend that b**ch back! Get a hose, attach it, blow through it. If ya feel it come out the other side with the relative force ya blew with (no restriction) then slap it on!
Andrewxxcarlson is offline   Reply With Quote
Old 03-26-2013, 01:31 AM   #4
atm0706
Member#: 279219
02 WRX, 06 STi
PSM, WRB
I tried bending it already and it cracked. I have a tap set, however I don't have a drill to drill it out... Any thought on how much it would cost to take it to a machine shop or something to get fixed?
Old 03-26-2013, 08:28 AM   #5
rdieder
Member#: 257818
2007 STi
CGM
get a drill at walmart, hold on to the receipt and return it when you're done.
rdieder is offline   Reply With Quote
Old 03-31-2013, 11:39 PM   #6
dictoresno
Member#: 139816
2002 WRX, VF34 swap
is that just press fit into the housing? pair of lock pliers and rip it out?
dictoresno is offline   Reply With Quote
Old 03-31-2013, 11:43 PM   #7
alx8283
Member#: 225024
2002 wrx
alx8283 is offline   Reply With Quote
Old 03-31-2013, 11:51 PM   #8
dictoresno
Member#: 139816
2002 WRX, VF34 swap
Originally Posted by alx8283 View Post
good call.
Old 04-02-2013, 10:47 PM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
For those who have drilled and tapped it, what size barb fitting did you get? I went to Home depot, but couldn't find barb fitting small enough for turbo.
Old 04-03-2013, 08:08 AM   #10
quazimoto
Member#: 70395
The go to Lowes or ACE . 1/8 NPT thread with the smallest barb they got (generally 1/8"). Watts is generally the company they use around me at both Home Depot and Lowes.
quazimoto is offline   Reply With Quote
Old 04-03-2013, 10:44 AM   #11
Turd Nugget
Member#: 346017
2013 STi Wagon
Satin White Pearl
Just swap the housing from your old turbo onto this one, too bad you'll loose the awesome red paint......
Turd Nugget is offline   Reply With Quote
Old 04-03-2013, 05:26 PM   #12
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
quazimoto, thanks for the photo.
Have you tried to search online to see if you can find anything smaller?
Old 04-03-2013, 07:48 PM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I found 1/16" barb fitting here....
http://www.ebay.com/itm/Nickel-Plate...35c7aa&vxp=mtr
Old 04-03-2013, 10:40 PM   #14
atm0706
Member#: 279219
02 WRX, 06 STi
PSM, WRB
Old 04-03-2013, 11:08 PM   #15
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
atm0706, any reason why you went with 3/16"? Isn't 1/16" be closer to OEM size?
Old 04-04-2013, 06:25 AM   #16
quazimoto
Member#: 70395
I would n't worry about the size to much. As long as the vacuum line will fit on it. Stock will have the restrictor pill anyways and if using silicone hose the ID of the hose will act as the main oriffice.
Old 04-04-2013, 10:54 PM   #17
atm0706
Member#: 279219
02 WRX, 06 STi
PSM, WRB
Not really, I kind of just winged it on that one haha. But I do remember seeing threads about people using that size successfully. After it actually gets here ill post my results.
Old 04-13-2013, 11:17 PM   #18
atm0706
Member#: 279219
02 WRX, 06 STi
PSM, WRB
The 3/16 x 1/8npt fitting worked perfect for me. that's what I would buy if I had to do it again
