Old 04-10-2013, 01:54 AM   #26
ppayer38
Member#: 234407
04 Self-tooned
STi
Well I got the Wideband/Boost Failsafe gauge installed today... I did not do the FP yet just to keep the results the same even though the weather has warmed up quite a bit(45* to 65*)
Well anyway on to the interesting info that everybody wants to hear.. The final AFR seems to float at 10.7-10.8 which is exactly where it is set to BUT on the other hand it has a massive dip to about 9.9-10.0 that has to be fixed! I am trying to figure out how to use the software to get datalogs and all that good fun stuff!
I will keep updating as I figure this out and smooth out the AFR!
Also to Ron. I had to downloaded the needed version of Microsoft.net and everything seem to go smoothly. Still trying to understand how the AEM program works but other then that it was a pretty straight forward install as far as install, open, update, restart, and have fun!
ppayer38 is offline   Reply With Quote
Old 04-10-2013, 02:16 AM   #27
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
For some reason the .net framework just wont install correctly on my laptop.
I wouldnt worry about using the software for logging....its much easier to look at the data when its just in the romraider log....otherwise you're trying to match up rpm and MAFv from Romraider to the AEM log.
Im quite surprised at that AFR, with the IDC only at 96-97% at redline i would have exected the afr's to be well above 11 up there. Even 07+ STi's are at 100% IDC up there at 10.5-10.8 AFr's and they have the bigger 565cc injectors.
Heres a stage2 07
Code:
RPM	IDC	MAFv	LC-1
2955	22.23	3.12	13.79
3004	24.36	3.18	13.76
3054	25.32	3.24	13.2
3071	27.44	3.4	13.39
3115	29.24	3.38	13.39
3144	33.11	3.54	13.67
3216	37.58	3.54	13.67
3260	43.12	3.7	12.61
3316	48.1	3.82	11.83
3370	55.61	3.94	11.42
3436	61.4	4	11.05
3481	68.84	4.12	11.05
3530	68.57	4.06	11.07
3618	69.8	4.14	10.94
3663	69.33	4.16	10.92
3732	69.74	4.16	11.07
3793	71.68	4.16	11.07
3914	76.03	4.24	11.01
3932	76.25	4.24	10.83
4000	77.11	4.26	11
4070	76.21	4.24	10.92
4124	76.98	4.24	10.92
4190	78.32	4.3	10.92
4257	78.82	4.34	11
4347	80.6	4.34	11.05
4390	82.07	4.34	11.05
4486	83.97	4.38	10.94
4518	84.74	4.4	10.94
4585	85.47	4.4	10.91
4638	86.62	4.42	10.91
4736	87.47	4.44	10.94
4748	88.84	4.44	10.95
4859	89.85	4.46	10.91
4881	89.69	4.46	10.95
4936	91.06	4.5	10.98
5053	91.63	4.5	11.02
5080	93.26	4.5	11.04
5178	93.51	4.5	11.01
5217	94.68	4.52	11.01
5266	94.61	4.52	10.95
5314	95.87	4.54	10.95
5356	94.89	4.54	10.98
5449	96.7	4.56	10.92
5469	95.97	4.54	11
5562	95.63	4.56	11
5581	95.11	4.54	10.98
5664	96.89	4.56	10.98
5714	96.32	4.58	11
5729	96.87	4.58	10.95
5788	96.49	4.56	10.92
5829	97.22	4.56	10.98
5878	95.84	4.56	10.98
5924	96.3	4.56	10.97
6038	98.48	4.58	10.95
6062	97.08	4.58	10.95
6105	97.61	4.58	10.98
6167	97.84	4.56	10.98
6225	98.2	4.58	11
6217	96.98	4.58	10.92
6306	98.42	4.58	10.92
6359	99.31	4.58	10.78
6358	97.92	4.58	10.94
6396	97.9	4.6	10.7
6486	99.72	4.58	10.7
6529	99.36	4.58	10.7
6534	99.8	4.58	10.58
6553	99.49	4.6	10.61
6606	100.02	4.6	10.63
6633	100.76	4.6	10.58
6734	100.59	4.6	10.63
6761	100.99	4.6	10.63
6802	101.75	4.6	10.75
Old 04-15-2013, 06:47 PM   #28
ppayer38
Member#: 234407
04 Self-tooned
STi
Just a little update on this... I've been fighting fuel trims and believe the front 02 is bad so I'm replacing that tomm! Hopefully will only take a few days to dial everything in and then make sure OL is good to go.
Old 04-15-2013, 10:55 PM   #29
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
What bpv are you running?
woodys77 is offline   Reply With Quote
Old 04-15-2013, 10:56 PM   #30
ppayer38
Member#: 234407
04 Self-tooned
STi
OE BPV
Old 04-16-2013, 05:10 PM   #31
ppayer38
Member#: 234407
04 Self-tooned
STi
So far so good! Installed the new front o2 sensor and cleaned the MAF. WB now reads just about right and fuel trims are close from what I can tell in the short period of driving I've done(within 5%).
I will have some new data logs tonight of the new OL scaling to see how that looks. Hopefully I am close if not right on to match the OL table within .1-.2 across the board. I am waiting on my MBC to show up and then to install the Wally 255 so she can be happy for a while!!
Old 04-16-2013, 05:56 PM   #32
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
You do realize that you don't have to have the fuel map match the exact afr your running. It isn't intended from Subaru to be exact match, it's just easier for people to read AFR instead of pulse width. If making it match throws off your maf scaling so that it isn't linear, that isn't really a good thing. Just my .02.
bswilmington is offline   Reply With Quote
Old 04-17-2013, 06:00 PM   #33
ppayer38
Member#: 234407
04 Self-tooned
STi
I scaled it within .2(actual AFR being .2 richer) and the MAF still looks really good. It is just a personal preference of mine to have it match... Now to install the MBC, Wally 255 and all my wrap/turbo blanket/Heatshield!
I will post an updated log/graph once everything is in...
