Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 04-01-2013, 10:27 AM   #1
crxgator
Member#: 39017
2000 Audi S4, 323iT
Default Kinugawa turbo install kit
Has anyone used this kit before? I'm looking to install a vf39 on my FXT, and this is a lot cheaper than going through Subaru just for the gaskets alone.
http://shopping.kinugawaturbo.com/tu...8g20g-1-1.aspx
crxgator is offline   Reply With Quote
Old 04-01-2013, 11:03 AM   #2
ogboot
Member#: 170906
psm
I installed a kinugawa turbo this weekend with the same included hardware:
Everything fit well. You will probably want to replace the clamps on the OEM oil and coolant hoses, because when I put mine on I had leaks there and had to use worm clamps to get it to seal. None of the kinugawa hardware leaked, and although I have a grimmspeed gasket set I used their supplied gaskets, they're beefy. Take note that it does not include nuts/bolts for the top of the hotside --> downpipe. I sheared one of mine on removal and had to get it replaced at the parts store.
ogboot is offline   Reply With Quote
