Old 03-27-2013, 12:23 PM   #1
02nismokiller
Member#: 322963
04 wrx
psm
Default Tgv deletes???
I'm finally finishing up my clutch and should finish putting the tranny back in tomorrow but since the tranny is out I was thinking about doing tgv deletes. But would you say it's safe to break my clutch in for the next 500 miles with no tune on the tgv deltes?
I also got gms phenolic spacers and I turbo inlet I had planned installing while I'm there...
My mods are:
04 wrx 5spd
Full 3" tbe
Catless up pipe
huge tmic
255 pump
Gms boost solenoid
Intake
Thank you
02nismokiller is offline   Reply With Quote
Old 03-27-2013, 11:13 PM   #2
paulpat
Member#: 237145
02 WRX
12 FXT
Get a tactrix cable and read the stickies on here. You can turn off the cels or get an e tune
paulpat is offline   Reply With Quote
Old 03-28-2013, 01:39 PM   #3
02nismokiller
Member#: 322963
04 wrx
psm
I do have a tactrix cable... Maybe someone can offer me a map with my similar mods???
Thank you
Old 03-28-2013, 02:47 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
The only real tuning necessary is to turn off the TGV codes in the OBDII section.
There may be a little bit of oscillating RPM on warm up. If this bugs you, you can also add some fuel to the warmup tables. Add ~5% at a time until it feels right on cold warmup. Changing those tables is not strictly necessary.
Assuming you are tuned for your other mods and all you did was delete the TGVs, you won't likely need any other tuning on the stock turbo. Boost might taper a little faster due to lack of restriction, but I doubt it at TD04 flow levels, your turbine housing is the main restriction... So, you shouldn't need much in the way of "real" tuning, just turning off the codes and if you feel like it, adjust the warmup tables.
Concillian is offline   Reply With Quote
Old 04-03-2013, 12:33 PM   #5
mikeydrives1
Member#: 262117
The first thing i noticed after TGV deletes was that WGDC tables had to be adjusted because boost would drop off decently quicker up top. Fuel was still good though and didnt need much done to it.
Also, WOT pulls got a little louder from the motor.
mikeydrives1 is offline   Reply With Quote
