Old 11-16-2015, 01:36 PM   #1
Masterauto
Member#: 198376
STI E30 M3
Nissan GT-R 15
Default New emissions solutions
http://www.pollutiononline.com/doc/b...he-source-0001
News | September 25, 2015
Breakthrough CO2 Technology Eliminates Vehicle Exhaust Fumes At The Source
Nova Institute of Technology introduces a breakthrough technology for removing all vehicle exhaust fumes before they leave the tailpipe. The Corona Discharge Gas Plasma Disassociation System™ (CO2 device) can also be adapted to gas vents used in refineries, exhaust stacks for incinerators, and implemented in more than 100 other common uses.
Salt Lake City, UT /PRNewswire/ - David G. Yurth, principal inventor and co-founder of Nova Institute of Technology, a privately-owned research and development group located in Salt Lake City, Utah, announced today the successful testing of The Corona Discharge Gas Plasma Disassociation System™ (CDGPDS™), a compact, lightweight, low-cost energy efficient device that eradicates all exhaust fumes produced by internal combustion engines before they leave the tailpipe.
States Yurth: "The CO2 device can be retrofitted to every internal combustion engine on the planet. The device can also be adapted for use in gas vents used in refineries, exhaust stacks for incinerators, and more than 100 other common uses."
CDGPDS™ incorporates proprietary plasma generating devices with high speed switching circuits to create what is known as a fracturing field inside a pulsating plasma chamber located within the exhaust system. The fracturing field breaks down or "dissociates" carbon dioxide and other pollutants within the device itself, thus eliminating the problem before it manifests.
"The challenge with dissociating carbon dioxide is that unlike most other three-atom gas molecules, CO2 is a very stable gas," says Yurth. "We have succeeded in demonstrating virtually 100% efficiency in the dissociation process because we have been able to propagate what is known as non-linear dissonance in the plasma chamber."
States Dr. Michael Kralik, Senior Physicist and Chief Science Officer for Nova: "Carbon dioxide molecules behave according to a well-known set of harmonic resonances which generate the fields that attract and bind the oxygen atoms to the central carbon atom. By subjecting the gas to intensely dissonant field effects, we are able to disrupt the spin polarity and oscillation frequencies that bind the atoms together."
According to Yurth and Kralik, the search for a solution to the production and release of carbon dioxide and other potent greenhouse gases has been the target of intensive research for more than 40 years.
"The stability of the CO2 molecule has resisted other attempts to break it down using a long list of excitation technologies, including microwaves, radio frequency pulses, lasers, electromagnetic fields, and various plasma field effects," says Yurth. "Thus far, the scientific literature has reported only nominal success using these methods under carefully controlled laboratory conditions."
The CO2 device is the result of Nova' s joint technology development arrangement with Collier Group, LLC and SaviCorp, a publicly traded supplier of the DynoValve® family of automotive products since 2004.
States Kevin Collier, CEO of Collier Group: "The system developed by Nova's design engineers can be retrofitted to the tailpipe of the exhaust system and powered by less than 20 amps of current. When we manufacture and distribute these units for mass consumption in the automotive after-market installation and retail outlets, no modifications to the vehicle's electrical system will be required. The Nova system will be compact, lightweight, low cost, and very energy efficient."
Nova Institute of Technology LLC is a privately-owned Research and Development group specializing in system integration, prototype testing, and leading edge technology development for itself and selected strategic partners. Nova has designed, developed, fabricated, tested and evaluated more than 300 technologies during the past 12 years. Nova's inventory of proprietary patent-protected technologies includes: Electronically Shaded Glass®, Plasma Field Propagation Devices, Zűt! Fair Trade Publishing System™, DynoPlug® Spark Plug System, HDCC System for remediating nuclear fuel waste, Corona Discharge CO2 Gas Plasma Dissociation System®, Remaindered Solvent System for Extracting Refinable Bitumen from Tar Sands, Oil Shale, and Frack Sands©, and Vacuum Drying System© for Organic and Inorganic Materials, in addition to 40 other proprietary technologies, devices and systems.
Collier Group, LLC is a locally-owned engineering services company that designs, manufactures and tests systems for water purification, desalination, contamination removal and industrial waste water treatment. Founded in 2002, Collier Group and its principals have been awarded 22 patents by the USPTO. The company specializes in remediation of waste water produced by fracking, reduction of mineralized water to produce pharmaceutical grade saline solutions for medical use, and installation of salt-gradient ponds for storing brine and producing electrical power.
SaviCorp® is an innovative automotive technology company that licenses, manufactures, distributes and services an array of patented technologies and products that reduce harmful emissions and improve fuel efficiency. The company, an evolution of more than twenty years of automotive engine emissions testing, materials research and development, was formed to create, support and license its patented supplementary vehicle Emissions Reduction Technologies (ERT). Using proprietary methods and processes, the company's flagship DynoValve® system protects the environment, reduces an engine's carbon footprint, increases gas mileage and improves engine performance, resulting in dramatic savings in both fuel and oil.
SOURCE: Nova Institute of Technology
Masterauto is offline   Reply With Quote
Old 11-16-2015, 03:40 PM   #2
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
20A at 12V does this? Call me skeptical.
shikataganai is offline   Reply With Quote
Old 11-16-2015, 04:20 PM   #3
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
If it sounds too good to be true..
Well..
Old 11-16-2015, 04:33 PM   #4
RobM
Member#: 177056
2015 WRX - CVT
2009 Forester XT
Phoney baloney
RobM is offline   Reply With Quote
Old 11-16-2015, 05:33 PM   #5
dedrooster
Member#: 32278
2000 2.5RS SRP Sedan
MB 190E 2.3-16v
So what does it create instead of CO2? Oxygen? Ozone? Carbon Monoxide? Carbon?
dedrooster is online now   Reply With Quote
Old 11-16-2015, 05:43 PM   #6
SCRAPPYDO
Member#: 873
2014 GLK/allroad
just some arsenic
Nothing to see
Old 11-16-2015, 11:31 PM   #7
hi5.0
Member#: 340456
2013 Impreza
CDGPDS™ all the things! Why, it can clean the very air around us as we speak! Would be great if it could do what it promises so "easily".
hi5.0 is offline   Reply With Quote
Old 11-17-2015, 08:56 AM   #8
MrH
Member#: 186279
2016 Forester XT
Ice Silver
Didn't someone come out with this around 10 years ago but no one could figure out why it worked ?
MrH is offline   Reply With Quote
Old 11-17-2015, 04:10 PM   #9
skywaffles
Member#: 82470
I am more humble
than you can understand.
e + CO2 --> CO + 1/2O2
Carbon dioxide is a very stable molecule and really doesn't want to split. Most of the effort is being put into activation of metal complexes and other catalytic processes. Plasma is a really stupid way of breaking CO2 because you're basically just dumping a bunch of energy into it. There are many vibrational modes that don't contribute to disassociation that can absorb this energy. I don't know their system (but they claim 100% efficiency ), but the cost I'm seeing quoted in literature (J. Phys. Chem) is 0.5-1 eV/mol for vibrational excitation in plasma. Yeah, you're not getting that power out of a freaking alternator.
skywaffles is offline   Reply With Quote
Old 11-17-2015, 04:31 PM   #10
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
Plus you then have CO, which you have to convert back to what... CO2?
Old 11-17-2015, 04:50 PM   #11
skywaffles
Member#: 82470
I am more humble
Just throw more energy at it and make C(s) and 1/2O2(g)!
Our ICP-MS requires three phase 240v to run, and it doesn't have to deal with constant flow.
Old 11-20-2015, 01:00 PM   #12
Len
Member#: 39937
2011 328i 6MT
LMB
Why not add some pressure also and turn it into pure oxygen + diamonds? Oh wait that's going to be in their next press release.
Len is offline   Reply With Quote
Old 11-20-2015, 01:18 PM   #13
E. Nick
Member#: 8489
1978 Plymouth Volare
Maroon / White Vinyl
They're setting up shop here to get funded by all the VC's. Elon is pitching it as an oxygen bar that sells engagement rings, above the airtight underground free parking garage in SanFran. Cost of good sold and distribution expenses approach 0, while relegating all horrible, polluting non-Teslas to the underground tomb. Genius.
E. Nick is offline   Reply With Quote
Old 11-21-2015, 11:26 AM   #14
Balantz
Member#: 101457
Czar of Sweet Dance
Moves
I'm not surprised in the least that this was posted by masterauto.
Balantz is offline   Reply With Quote
