Alaskan Impreza Club
Old 03-29-2013, 07:04 PM   #1
Muphzilla
Member#: 330992
Default New subaru motors
Was wondering the other day if the direct injection heads would fit on any other motor and work properly? Any ideas?
Muphzilla is offline   Reply With Quote
Old 03-31-2013, 08:21 PM   #2
akeric
Member#: 122954
2006 Evo IX
My car is black not
At the very least you'll need new fuel rails pump, pistons and probably an ecu. If you got aftermarket ecu you'll probably be able to make it work after alot of work. That's if they even fit. I imagine because you could but a full engine swap would probably be easier.
But it would be cool.
akeric is offline   Reply With Quote
Old 03-31-2013, 09:06 PM   #3
coldfiremx
Member#: 285848
Being that one motor uses a timing belt and the other a timing chain, you would be looking at some major modifications, fabrication and machine work, custom camshafts and thats if you are lucky and the heads bolt up and have the same oil feeds and drains and coolant passages. Other than that you are looking at changing the complete fuel system and also running a stand alone engine management system. Or you could just swap in a new motor and harness ecu and call it a day.
coldfiremx is offline   Reply With Quote
