Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 09-23-2002, 10:15 AM   #1
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Default Break Fluid/Stearing Fluid/Diff. Fluid/Transmission Fluid???
When should I change each of these and what do you guys suggest are the best fluids to use.
Jasno999 is offline   Reply With Quote
Old 09-23-2002, 07:19 PM   #2
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Anybody?
Old 09-23-2002, 07:31 PM   #3
rkkwan
Member#: 5596
2010 Honda Fit Sport
What are you using the car for? Why do you think you should change the fluids?
-Ray
rkkwan is offline   Reply With Quote
Old 09-23-2002, 11:55 PM   #4
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Default I'll lend a hand here
As per the service manual:
Brake fluid - every 30k mi.
PS fluid - indefinate (inspect every 15k mi.)
Trans/Diff fluid - indefinate (inspect every 30k mi.)
As for me, I'm soon to change brake fluid to ATE Super Blue (along with Goodridge SS lines.) Using OE original PS fluid. Trans/Diff I'm using Royal Purple 75W90 full synthetic Max Gear Oil.
So far, so good. Hope to get to the brake upgrade in the next couple of weeks. That should make a marked improvement (might do pads as well, haven't decided.) The OE brake system isn't that bad, IMHO. Not for street use anyway.
HTH - Jim
MackDaddy is offline   Reply With Quote
Old 09-24-2002, 12:27 AM   #5
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
interesting.
Old 09-24-2002, 02:18 PM   #6
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Anybody else?????
Old 09-24-2002, 02:49 PM   #7
cakes25rs
Member#: 1024
2000 S2000
White/Red
Rear Diff - Redline Synthetic 75W90
Tranny - Redline Synthetic 75W90 NS
Brakes - ATE Super Blue
i just changed all three at 3x,xxx miles. hope this helps.
cakes25rs is offline   Reply With Quote
Old 09-24-2002, 05:37 PM   #8
jlevy
Member#: 15696
2015 WRX 6 speed
I'm using Amsoil ATF in the p/s.
jlevy is offline   Reply With Quote
Old 09-25-2002, 11:36 PM   #9
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Does anybody use anything else?
By the way where can I purchase the redline Synthetic stuff?
Old 09-27-2002, 11:52 AM   #10
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Last call
Old 09-27-2002, 12:05 PM   #11
jlevy
Member#: 15696
2015 WRX 6 speed
I got my last batch of redline stuff from here
http://keith.mcbride.org/gearoil.html
Old 09-27-2002, 12:22 PM   #12
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
What are the recommend weights for the MT and Rear Diff?
WRX 2003-rear brakes/rotors, steering rack, front spindles, subframe, diff, ebrake Tigris Suspension/Brakes/Handling 1 05-19-2010 11:07 PM
Brake And Transmission Fluid Flush rafi03wrx Service & Maintenance 2 03-02-2010 11:25 PM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 06:54 AM
Rear Diff Fluid and Transmission Fluid Q??? 01G_WRX_02 Service & Maintenance 3 06-29-2006 10:43 PM
is this power steering line or transmission fluid line? thanks racerxl99 Transmission (AT/MT) & Driveline 2 04-05-2006 08:53 AM
