Old 03-31-2013, 10:59 PM   #1
Charlton
Member#: 43038
2002 Forester S
Default Straight Gas vs Gas with Ethanol
We've got a couple gas stations with 100% gasoline here locally. Would there be a benefit doing straight gas vs gas with ethanol?
Charlton is offline   Reply With Quote
Old 03-31-2013, 11:06 PM   #2
97cv
Member#: 151048
2003 Baja
Black/ Silver
I So Envy You!
97cv is offline   Reply With Quote
Old 04-01-2013, 12:21 AM   #3
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Straight gas has better gas mileage. That's really about it.
Ethanol slightly increases knock resistance.
formula91 is offline   Reply With Quote
Old 04-01-2013, 01:16 AM   #4
GrundleJuice
Member#: 165749
Ethanol has less energy per mass compared to gasoline, hence the slight loss of mpg's with an ethanol blend. The knock resistance gained with ethanol is lost when blended with gasoline at such a low percentage. I assume the gasoline is just a slightly lower octane rating then it used to be and then it's boosted back up to the posted octane number when the ethanol is added. That would make sense for the oil companies.
Ethanol is also not inert when in contact with many types of plastics and rubbers. It's harder on some parts of the fuel system.
Old 04-03-2013, 03:19 PM   #5
kay95
Member#: 45494
95 impreza L awd
green
Less energy per pound but more pounds per gallon. You have to factor density of ethanol in there too. You will have more energy than if you just calculate percentages. One gallon of gasoline weighs 6# and one gallon of pure ethanol weighs 7#.
Ethanol doesnt show knock resistance well on a octane test. Reason for this is because you start with super hot manifold air and on a real engine the ethanol would greatly lower intake air temps. Pure ethanol has a octane rating of less than 100 but can easily replace 110 octane gasoline because of this reason. So even at 10% mixed with 87 you would still have more than what the R+M/2 would suggest.
My 95 impreza is rated for gasohol up to 10%. Everything since the mid 80s is ethanol compatible. My state has used ethanol in the gas for a long time and people are now only demonizing it because the media and the uninformed are blaming ethanol. There are many other much more agressive solvents in common gasoline blends that can cause problems. Blame the EPA not ethanol.
kay95 is offline   Reply With Quote
Old 04-03-2013, 08:52 PM   #6
stevefazek
Member#: 128922
straight gas will cause less damage to your fuel injectors and fuel pumps, will give you better MPG too not much through 2-5% better MPG
ethanol has 20% less BTUs per gallon than gas and gas generally uses 10% ethanol here.
Ethanol is a scam to make monsanto rich off of their overpriced GMO corn seed
stevefazek is offline   Reply With Quote
Old 04-04-2013, 06:56 AM   #7
kay95
Member#: 45494
95 impreza L awd
green
Proof??
Old 04-04-2013, 08:15 AM   #8
AWDmonk
Member#: 271442
2006 Impreza 2.5i
CGM
Let me go ahead and sum up 15 years of personal driving experience along with millions more around the world.......
**** E10.
**** E20...if you don't know, you're lucky.
E85, well, no turbo so no opinion.
91/93 octane in WI are 100% gas and I get 1-2 more MPG on that than on 87. The price difference made me reconsider when I was young and underemployed, but now that its ****ing $4/gallon anyway, another quarter doesn't matter.
Also, ethanol is corrosive to the seals in the fuel system. Actually, we store 100k+ pounds of E99 at work and have just recently switched to plastic tanks because it was starting to eat at the steel ones.
AWDmonk is offline   Reply With Quote
Old 04-04-2013, 04:14 PM   #9
hyperduc
Member#: 350545
Last time I checked I purchased fuel in Gallons, so essentially you are getting less BTU (power) per gallon.
One of the few redeeming qualities...
people are now only demonizing it because the media and the uninformed are blaming ethanol. There are many other much more aggressive solvents in common gasoline blends that can cause problems. Blame the EPA not ethanol.
Aside from the obvious less power per gallon, ethanol is corrosive and this isn't "media hype" Underwriters Laboratories (UL) for the National Renewable Energy Laboratory (NREL) have both confirmed this repeatedly. Ethanol is also Hygroscopic, so introduction of water into the fuel system is a concern.
On top of all of that, ethanol/gasoline combustion is actually "dirtier" than straight gasoline. The geniuses running the federal government dance around or just plain ignore this fact and choose to frame the issue by stating that the "overall production emissions" for corn are much lower than that of oil.
In summation: What comes out of your tailpipe is dirtier than the alternative, more expensive than the alternative, is more harmful to your vehicle than the alternative and this "improvement" has increased food prices worldwide.
hyperduc is offline   Reply With Quote
Old 04-04-2013, 09:50 PM   #10
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I'd focus more on driving habits over which gas you use to improve MPGs.
chazly413 is offline   Reply With Quote
