Old 03-31-2013, 11:09 PM   #1
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
Lightbulb Rear JDM Foglight into 12-13 Impreza/Crosstek 2.0i
I am going to do a small walk through of the 12-13 Impreza/Crosstek install of the REAR JDM fog light. Here is my parts list of OEM and non-oem parts.
(1) Red Lens P/N 84913FG420
(1) Harness P/N 84981FG050
(1) Lightbulb P/N 84920KE010 $5.10
(4) Plastic Clips P/N 909205126
(6) Bolts P/N 901000344 $0.77
(2) Threaded Clips P/N 902510032 $1.47
(1) Fog Light Switch P/N H4510FJ000 $32.21
(1) Dash Switch Panel P/N 83472FJ010VH $7.50
(1) Durite Socket P/N 0-729-03 $3.10
(1) Durite 12V Micro Relay P/N 0-728-13 $5.26
If anyone has any input or information to add please do so, I can always use any new information. Also if you need any help just send me an email to:
[email protected]
THIS IS WHY YOU ONLY NEED TO TURN IT ON IN REAL BAD WEATHER!
ZURCALED12 is offline   Reply With Quote
Old 03-31-2013, 11:30 PM   #2
danstheman7
Member#: 331089
2012 Impreza Base
DGM/Dark Grey Metallic
Holy crapola, insanely bright, nice job! Surprisingly cheap, install doesn't look fun though. How bad was the back install?
danstheman7 is offline   Reply With Quote
Old 04-01-2013, 02:53 PM   #3
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
J, can you hook it up to the brake lights? will it stay lit and get bright when you tap the brakes? any idea?
looks good and that thing is blinding bright.
Blackmamba24kb is offline   Reply With Quote
Old 04-02-2013, 05:01 PM   #4
Evolution17
Member#: 352216
Is there any way to make this blink F1 sytle? :P
Evolution17 is offline   Reply With Quote
Old 04-02-2013, 05:57 PM   #5
ZURCALED12
Member#: 309754
Ice Silver Metallic
This light is what you need in BAD weather, Especially in thick fog and mist, this light would cut through all of it.
The only way to make it flash is by adding a 12 volt programmable electronic flasher, and wiring it up to your brake lights, but it's very bright. The bulb is a 21 watts wedge type.
The web has these JDM kits for about $152 shipped from JAPAN or if you do not want to wait you can order it for $200 from the California Subaru dealer in El Cajon, CA
It's too bad we can't do a group buy and get a lot of 20 to bring the price down. I strongly suggest getting the socket and harness, to make it a bit easier on the install.
Old 04-02-2013, 06:00 PM   #6
ZURCALED12
Member#: 309754
Ice Silver Metallic
You can easily do that with a two contact bulb and socket. But you would have to run your own wiring and not use the harness that comes in the kit. It would not be hard at all, just some wiring up!
Old 04-02-2013, 07:22 PM   #7
ZURCALED12
Member#: 309754
Ice Silver Metallic
Talking easy install , some wiring of the relay and you are done.
Not too bad, just got to put the car on ramps (I am a big guy) so it was easier for me and there are pre-drilled holes behind the bumper, just pop the rubber grommet out and push the wiring harness through, the mounting of the light is as easy as changing a bulb, pop out the cover/cap, slide the new light housing in and slip on the C nuts and bolt and that parts is done.
Pre-drilled hole behind grommet/cap.
This is the other side of the wheel well, behind the bumper cover, and no you do not have to remove the bumper cover either.
This is the rubber grommet that comes with the harness, you are going push it through the hole where you removed the other grommet/cap from.
Old 04-02-2013, 07:33 PM   #8
danstheman7
Member#: 331089
2012 Impreza Base
Not bad! Something I might consider, thanks.
Old 04-04-2013, 07:01 AM   #9
solistik
Member#: 345948
That looks great, but I am wondering with a different bulb could the output be less bright?
I would seriously consider this modification if the price was around the same it is to convert the reflectors into lights, but at this price I'd rather get the hitch that fits in that space instead. Especially since its about the same price. But thanks for posting this information, it's appreciated!
solistik is offline   Reply With Quote
Old 06-23-2013, 09:40 PM   #10
Toastypinoy
Member#: 360301
2013 Impreza Sport
Satin White Pearl
Any chance you can do a FULL write- up on how you did this? It would be much appreciated.
Toastypinoy is offline   Reply With Quote
Old 06-27-2013, 11:54 AM   #11
JustaImpreza
Member#: 357515
2013 Sport - 5MT
Satin White Pearl
Was a new panel piece/switch cover thing necessary? I assumed the slot on the stock panel would just knock out for the new switch.
Also, the wires that connect to the back of the switch, is that the small gray harness clip thats visible in my fuse box? Stock set up - not attached to anything.
JustaImpreza is offline   Reply With Quote
Old 06-27-2013, 08:21 PM   #12
ZURCALED12
Member#: 309754
Ice Silver Metallic
Subaru Banner Dash plastic cover
Yes, and it's only $7.50 but the stock piece is very hard plastic not fun to cut. It does NOT knock out, if you turn the piece around on the other side is smooth. That would had been the smart thing SUBARU could have done, but they did not. and its not that hard to change.
Old 06-28-2013, 03:34 PM   #13
srpuywa
Member#: 355974
2013 2.0i 5 door
dark grey
European cars sometimes have a rear foglight
srpuywa is offline   Reply With Quote
Old 07-12-2013, 12:15 PM   #14
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
Heat up a scalpel blade or something similar ... Heat it up super hot , and it'll cut through like butter ...
ANR62NV is offline   Reply With Quote
Old 07-12-2013, 12:52 PM   #15
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Or use a Dremel?
sgoldste01 is offline   Reply With Quote
Old 07-12-2013, 05:02 PM   #16
fistv
Member#: 350063
2013 Impreza sport
It is not just Subaru, I think they all do that intentionally, jeep did it with the center switch panels in the 97+ Cherokees and wranglers for the switches that do the rear wiper switch, rear defoggers switch, fog light switch and high idle switch option for police cars and such. Makes you buy a new panel when you want to add a factory switch, not only that but they put tracks and rails in the panel switch holes so the new switch has to go into a specific hole. They wised up on the 2000+ TJ wrangler and used removable blanks.
fistv is offline   Reply With Quote
Old 07-12-2013, 05:05 PM   #17
fistv
Member#: 350063
2013 Impreza sport
Originally Posted by sgoldste01 View Post
Or use a Dremel?
Too fast and hot for a standard dremel rotary tool though the dremel multi max would probably work for this. Just wear heavy gloves when using this tool or it will aggravate carpel tunnel a hundred fold if you have it.
Old 07-13-2013, 09:04 PM   #18
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
the foglight switch can you tell me where to find that loom?
[quote=ZURCALED12;39484033]
Dijm8 is offline   Reply With Quote
Old 03-11-2014, 01:05 AM   #19
mrdirosa
Member#: 357745
2014 Sport Prem. 5MT
Dark Gray Metallic
A few questions on this switch:
1. How are you connecting it to the relay and fog light? Did you get the plug somewhere, or are you just direct connecting it to the wiring?
2. Does it light up? If not, you have no indication the rear fog is on.
3. Did you wire it to the parking light or front fog circuit? You wouldn't want it on unless you have other lights on as well.
4. Do you really need the relay? A 21W bulb is only going to pull about 1.75A.
Thanks,
Michael
mrdirosa is offline   Reply With Quote
Old 11-16-2014, 08:13 PM   #20
Tobey
Member#: 21400
2015 WRX Limited
ISM
Bump - anyone else done this with the dash mounted OEM fog switch? Looking for info on wiring up the switch.
Tobey is offline   Reply With Quote
Old 12-03-2014, 02:23 PM   #21
eolivas
Member#: 397836
2015 WRX STi
Lightening Red
Would like to do this on my `15 STi.
eolivas is offline   Reply With Quote
Old 12-03-2014, 06:29 PM   #22
Cflo23
Member#: 394949
Ditto
Cflo23 is offline   Reply With Quote
Old 12-07-2014, 07:17 PM   #23
ZURCALED12
Member#: 309754
Ice Silver Metallic
Look at my write up post I show you which wire to use you need the relay cause the wire from the switch has a ground, also it's grounded even without the key in the ignition.
Old 12-08-2014, 01:52 AM   #24
eolivas
Member#: 397836
2015 WRX STi
Lightening Red
Zurcaled,
Hello, I would like to know if it is possible to adapt your layout to a 2015 STi. I have the fog light assembly installed already. However, I don't want to use it as an additional brake light, I want to use it as intended... A rear fog. I tried to drop you an email but got an error. Do you have another email?
Any help you may provide me will be greatly appreciated.
Thanks in advance.
Old 12-16-2014, 01:00 AM   #25
BlurpleSti
Member#: 408333
11 WRX Sti
Plasma Blue Pearl
Love it! So need to do this to my car
BlurpleSti is offline   Reply With Quote
