Old 04-01-2013, 07:51 AM   #1
Buellrunner
Member#: 144553
2004 Impreza WRX
Default Wastegate fluttering sound
Hi all,
I recently started getting wastegate flutter noise out of the blue. 2004 wrx 185k Downpipe Tune Stock exhaust My car makes full boost no problem. I have been reading that this noise is nothing to worry about and that many people experience it. Is this accurate?
Thanks for any advice!
Buellrunner is offline   Reply With Quote
Old 04-01-2013, 08:15 PM   #2
Member#: 301037
2004 Forester XT
I am trying to make sure I understand you. You have downpipe with a tune and are running a stock catback. Is that right?
art@grimmspeed is offline   Reply With Quote
Old 04-01-2013, 08:27 PM   #3
Buellrunner
Member#: 144553
2004 Impreza WRX
Exactly - actually it's a stock catback from a 2006 if it makes any difference.
Old 04-04-2013, 02:41 PM   #4
mdean12
Member#: 331255
2004 WRX
Started to notice the same thing after installing an uppipe, downpipe, catback, and an AccessPort Stage 2 OTS map. Seems to flutter when I get into boost a little past 1/4 throttle. When I really push the car hard and get into higher boost, it goes away. Checked to make sure the turbo to downpipe connection was torqued to spec. Bumping this thread for any ideas.
mdean12 is offline   Reply With Quote
Old 04-04-2013, 02:42 PM   #5
silvercookie
Member#: 180033
2005 WRX
It was probably always there and now you can just hear it more due to the downpipe.
silvercookie is offline   Reply With Quote
Old 04-04-2013, 03:00 PM   #6
Buellrunner
Member#: 144553
2004 Impreza WRX
Just had mine diagnosed and repaired. My fluttering sound came from my exhaust temp sensor not being secured properly into the pipe. Went away as soon as it was secured properly.
Old 04-04-2013, 03:35 PM   #7
mdean12
Member#: 331255
2004 WRX
I removed the header portion of the exhaust when I installed the new uppipe. Pretty sure I didn't knock the engine temp sensor around, or bang it against anything in the process. The noise sounds like it's coming from right under the hood in the upper most portion on the passenger side. Exhaust temp sensor is way down there in front of the car, tucked right against the plastic shielding for the wheel well.
Old 04-04-2013, 04:45 PM   #8
danger1138
Member#: 279525
04 rex luger!
I think u here it more cuz of the aftermarket downpipe.
danger1138 is offline   Reply With Quote
Old 04-05-2013, 07:55 AM   #9
Gamble_WRX
Member#: 234783
2004 STi
Easy fix, get an EWG. harder fix, adjust the actuator arm. it shouldnt be any danger, just an annoyance.
Gamble_WRX is offline   Reply With Quote
Old 04-05-2013, 08:58 AM   #10
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Exactly!
WRX_02_227 is offline   Reply With Quote
