Old 10-04-2013, 11:47 AM   #1
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Default 03 wrx td04 stock wastegate
I need a replacement stock wastegate, but can not seem to find a source, or for that matter a PSI rating so I can just order it.
Anyone?
The Phenx is offline   Reply With Quote
Old 10-04-2013, 11:55 AM   #2
bluemk3
Member#: 263694
World Rally Blue
Kinagawa.com
bluemk3 is offline   Reply With Quote
Old 10-04-2013, 11:58 AM   #3
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Link no worky
Old 10-04-2013, 02:07 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
Old 10-04-2013, 02:32 PM   #5
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Originally Posted by subaru_gc8 View Post
Sadly they do not offer an 8psi (.55bar) actuator for the '02-'05
From what i understand the .5 bar .735psi (which they have) is only for '06 - '07
Any other places to check?
Old 10-04-2013, 11:20 PM   #6
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
irrelevant....pure irrelevant
Old 10-05-2013, 12:49 AM   #7
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
I used a 5bar today and can't hit more than 16psi with the wastegate pretension cranked. Definitely relevant. Found an old one in my shed, so swapping it out.
I have a feeling the turbo is on its way out they only seem to last 150,000 miles or so.
Old 10-05-2013, 12:55 AM   #8
lavid2002
Member#: 226864
I have one for sale. 15 shipped PM me
lavid2002 is offline   Reply With Quote
Old 10-05-2013, 03:53 AM   #9
Uncle Scotty
OK buy Nates beans
the difference is irrelevant...you have other issues
generally...you want yourwg spring pressure to be 1/2 or a bit more than your MAX boost pressure that you will be running......but i run 20-21psi on my td04 with the stock acuator without any issue....holds boost just fine....while it CAN that is
Old 10-05-2013, 08:55 AM   #10
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
the difference is irrelevant...you have other issues generally...you want yourwg spring pressure to be 1/2 or a bit more than your MAX boost pressure that you will be running......but i run 20-21psi on my td04 with the stock acuator without any issue....holds boost just fine....while it CAN that is
Yep normally it's fine. 19 psi no worries.
Started getting boost spikes, and it was the next easy thing to test. Already checked for vac leaks.
Had an 07 wastegate actuator lying around... Swapped it, no more spikes, but couldn't hit target boost. It opens too early cause it's a lighter sprung unit, it's messing w my tune.
Found a correct one in the shed, so on it goes.
