Old 04-01-2013, 05:12 PM   #1
Qtipimpreza
Member#: 347330
2013 Impreza Sport L
Default Sport Impreza - Back end is saggy...
Love my sport limited, but does anyone feel like the backend of the vehicle looks "sagged"?
Ie, when I look at the clearance above my rear wheels in comparison to the front, there is a noticable difference that makes the car look like its jacked up in the front...not the best look IMO.
Has anyone done anything to adress this? Pics to share? Would this change the handling of the car significantly to raise the back and lower the front end just a tad to make it look more balanced?
Qtipimpreza is offline   Reply With Quote
Old 04-01-2013, 06:41 PM   #2
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Yes i put coil spacers in the back. no pics, but it improved it. Not a long term solution because they are made out of rubber
auskip07 is offline   Reply With Quote
Old 04-01-2013, 08:28 PM   #3
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Can't read today - No comment.
G-Omaha is offline   Reply With Quote
Old 04-02-2013, 07:40 AM   #4
fistv
Member#: 350063
2013 Impreza sport
Yes, I noticed that also on my 13... how thick a spacer did you use and whose ? have not been under it yet, do these have bump stops inside the coils ?
fistv is offline   Reply With Quote
Old 04-02-2013, 12:17 PM   #5
mrbloink
Member#: 333058
The front wheel arch is larger than the rear one to accommodate the wheel when you turn. This kind of makes the rear look saggy
mrbloink is offline   Reply With Quote
Old 04-02-2013, 03:28 PM   #6
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
Checked a few hatchbacks and they all seem to be setup that way in terms of height relative to rear
aeoporta is offline   Reply With Quote
Old 04-02-2013, 05:50 PM   #7
Rememo
Member#: 340728
2013 Impreza 5-spd
And here I thought it was due to the added weight of my new 19mm sway bar.
Rememo is offline   Reply With Quote
Old 04-02-2013, 07:55 PM   #8
aeoporta
Member#: 334126
Dark Gray Mettallic
you got some junk in the trunk
Old 07-10-2015, 12:33 AM   #9
Qtipimpreza
Member#: 347330
* Bumb
Has anyone raised the back end with a long-ish term solution that has picks and instructions/guidance?
Old 07-10-2015, 07:03 AM   #10
revin-it02
Member#: 287184
05 RS-T & 16 FRS
Holy bumping old thread batman!
Use these: http://www.paranoidfabrications.com/...za-08-11-hdpe/
They install on top of the strut (essentially a lift kit). Install is straight forward, remove strut, reinstall.
revin-it02 is offline   Reply With Quote
Old 07-10-2015, 09:40 AM   #11
Obviously Tyler
Member#: 395955
2016 WRX Premium
Ice Silver Metallic
This.
The car is level. The "sag" is all in the design of the fenders.
Obviously Tyler is online now   Reply With Quote
Old 07-10-2015, 09:53 AM   #12
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Welcome to owning a Subaru. Just call the butt hella flush around the ricers and you'll be good. You just haven't gotten around to dropping the front yet
Dirt Bringer is offline   Reply With Quote
Old 07-10-2015, 09:56 AM   #13
Obviously Tyler
Member#: 395955
2016 WRX Premium
Ice Silver Metallic
Should we just start telling people to cut their front springs?
Old 07-10-2015, 10:03 AM   #14
Jimpreza111
Member#: 407850
2014 Impreza 2.0i
Quartz Blue Pearl
I was looking at this last night and the car itself is level, the fenders are cut at different heights. I found about 1-1/4" gap in the back and a 2-1/4" gap in the front. It's almost an optical illusion. I suppose if you did raise the back end a bit it wouldn't look too bad with a little front rake.
Jimpreza111 is offline   Reply With Quote
Old 07-10-2015, 10:10 AM   #15
Obviously Tyler
Member#: 395955
2016 WRX Premium
Ice Silver Metallic
I'm all for raising the car. It's just funny to see people so worried about their rear suspension, like something's wrong with it.
I've seen a couple people on here say that they took their car to the dealership because of it...
Of course I'm sure nothing was changed.
Old 07-10-2015, 10:50 AM   #16
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
here is mine on winter wheels with 3/4" spacers on the rear. there is a little rake now but not really noticeable unless you look for it. been like this for 2 years now on my homemade hdpe spacers
Old 07-10-2015, 10:58 AM   #17
Obviously Tyler
Member#: 395955
2016 WRX Premium
Ice Silver Metallic
Still has slightly noticeable negative rake. But looking at your side skirts, it's very apparent that the rear of the car is actually higher than the front.
Old 07-10-2015, 11:13 AM   #18
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i had stuff in the hatch too. can't remember what it was all posted several years back now. i even had measurements and the wheel gaps are w/in 1/4" IIRC. not going to try searching for all that info as it is burried in the gigantic thread.
Old 07-10-2015, 11:21 AM   #19
Obviously Tyler
Member#: 395955
2016 WRX Premium
Ice Silver Metallic
Gotcha. No biggie. I'm not saying there's anything wrong with your setup.
I have a 1/4" spacer in the rear at the moment. It's hardly noticeable but it's mostly just peace of mind for me. A little extra clearance can go a long way.
Old 07-10-2015, 12:48 PM   #20
Dirt Bringer
Member#: 340297
Ice Silver
This is how you scuff your bumper.
Old 07-10-2015, 12:49 PM   #21
Dirt Bringer
Member#: 340297
Ice Silver
Nah, we should tell them to chain them
Old 07-10-2015, 01:10 PM   #22
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
3/4" min IMHO. 1" would have been nice, but trying to find 1" material was $$$$$, 2 pieces of 3/8" stacked together was like 15.00
