Old 04-02-2013, 02:59 AM   #1
LastYearsMammalMeet
Member#: 332046
2007 2.5i wagon
obsidian gray
Default Driveshaft bolt help
Im taking apart my 2007 2.5i 5mt and in part of getting to my clutch, i had stripped one of the nuts on the driveshaft bolt, i had to get the thing out and i was not going to put a grinder or sawzall right next to my drive shaft or deferential, so i decided to drill the nut out. However after traveling around to local part stores, i am unable to find these bolts, it is not the normal hex sided bolt, instead it is flush and flat on one side to fit up against the driveshaft.
the only help i could find was this: http://www.iwsti.com/forums/drivetra...placement.html
and this is for a difrent bolt on an older sti drivetrain
can anyone lead me in the right direction? i am going to take a trip to the stealership tomorrow with high hopes
[IMG][/IMG]
[IMG][/IMG]
LastYearsMammalMeet is offline   Reply With Quote
Old 04-02-2013, 06:11 AM   #2
LastYearsMammalMeet
Member#: 332046
2007 2.5i wagon
obsidian gray
I posted pictures but it doesn't look like they are showing, I assume I don't meet a post count to post links or something
Old 04-02-2013, 08:21 AM   #3
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
I see the pictures. You might have better luck in the drivetrain forum.
Counterfit is offline   Reply With Quote
Old 04-02-2013, 10:03 AM   #4
abaton6
Member#: 149373
Maybe you could grind down a regular bolt head to match.
abaton6 is offline   Reply With Quote
Old 04-02-2013, 11:06 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
You can try grinding down a bolt, but the dealer will have the correct part.
Old 04-02-2013, 11:16 PM   #6
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You can use a standard bolt no problem. Make sure to use a set of 4 matching bolts, though, as to not cause balance issues.
Old 04-03-2013, 03:18 AM   #7
LastYearsMammalMeet
Member#: 332046
2007 2.5i wagon
obsidian gray
Thank you I wasn't sure if this would cause any issues, I had not gotten to swing by the dealership yet as I forgot the closest one is over an hour away from me.
Old 04-03-2013, 03:28 AM   #8
Counterfit
Member#: 124254
"The Scoobinator"
I guess I stand corrected. You've had plenty of luck in this forum.
Old 04-03-2013, 07:46 PM   #9
stevefazek
Member#: 128922
Grind a bolt down and mail order the right bolt swap it out when it comes in
stevefazek is offline   Reply With Quote
