Old 04-02-2013, 11:13 AM   #1
abaton6
Member#: 149373
Default 97 auto won't downshift
My Son's 97 won't down shift when needed. Going uphill, it will not D S till it's really bogging down, then, WHAM! into 1st, 5000 rpm. He can shift it down manually, but it will not do it on it's own. Any suggestions would be appreciated. Trying to make this thing last till he's out of College.
abaton6 is offline   Reply With Quote
Old 04-02-2013, 12:16 PM   #2
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Check the trans fluid level
Rudgers73 is offline   Reply With Quote
Old 04-04-2013, 08:00 PM   #3
abaton6
Member#: 149373
Thanx, The tranny fluid is fine. This has a vacuum activated downshifter assist. I put my mityvac on the hose that goes from the diaphragm housing to the intake manifold. It holds a vacuum, but does not move.. So the diaphragm is fine. Any other suggestions why this will not work?. I noticed that the booster has an electrical connection..............................
Old 04-04-2013, 08:44 PM   #4
silverton
Member#: 331131
2001 2.5RS-T
Silver..thorn Metallic
maybe the TPS? since it'll shift in to the lower gears manually, but won't do it automagically at speed like it should, it's gotta be a sensor.
silverton is offline   Reply With Quote
