Old 04-02-2013, 11:36 AM   #1
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
Post Quick Question
I Just Installed My Q300 On My 13 Sedan And After That I Hear More Urbo Whistle In 5th At Like 2400 Rpms Sounds Like A Tea Kettle Anyone Else Experince This Issue I Mean I Broguht To Dealer They Said It Was Normal No Tune Stock Downpipe Jut Cat Back
Any Ways To Fix It?
PlasmaBlue518 is offline   Reply With Quote
Old 04-02-2013, 11:44 AM   #2
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
I just installed my Q300 on my 13 sedan, and after that I hear more turbo whistle in 5th at like 2400 rpms. Sounds like a tea kettle. Anyone else experince this issue? I mean, I broguht to dealer. They said it was normal. No tune, stock downpipe, jut Cat Back
What in the hell typing style is that...
Here's how to fix it.
1) Use punctuation to separate sentences. See quote above.
2) Use capitals properly. They are designed to help separate out sentences, in marking the beginnings, as well as highlighting certain things. IF YOU ONLY TYPED IN CAPITALS NOBODY WOULD HAVE ANY IDEA IF YOU WERE TRYING TO EMPHASIZE EVERY WORD, OR WERE JUST AN IDIOT.
3) ??
As for your exhaust issue, I like that you asked a dealer if an aftermarket part was normal. You're probably just not used to the noise yet. If it was the DP (see how that's capitalized?), I'd say it's completely normal, as you're getting rid of the car and will hear the turbo more.
Catback though... I'm sure it's fine. I wouldn't worry about it.
And if you blame this typing on your phone, I'm going to petition to ban you. I type from my phone most of the time, and usually it's no caps, not every word.
Loyale93 is offline   Reply With Quote
Old 04-02-2013, 11:45 AM   #3
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
whistletipgoeswhoowhoo.mp4
vision.dynamix is online now   Reply With Quote
Old 04-02-2013, 11:48 AM   #4
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
well theres a stock DP on the car and its just a CATBACK so just curious to see what is wrong bc i heard the noise before i did exhaust bc the 13's didnt come with intake silencer but after i put my exhasut on it became louder at a certain RPM
Old 04-02-2013, 11:48 AM   #5
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
You installed the midpipe upside down. Common problem. Just remove it, rotate it 360°and install it again.
Psychoreo is offline   Reply With Quote
Old 04-02-2013, 11:50 AM   #6
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Pretty sure you gotta rotate it 1080*.
Old 04-02-2013, 11:50 AM   #7
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
the invida writing is on top
Old 04-02-2013, 11:51 AM   #8
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
Yougotsomeofthetypingtipsrightatleastyouarentcapit alizingeverywordnowletsworkonpunctuationandcapital swhererequired
Old 04-02-2013, 11:51 AM   #9
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
i mean seriously cmon is this normal or what
Old 04-02-2013, 11:54 AM   #10
Psychoreo
Member#: 79643
2015 WRX STI
720° should do it. Any more will cause excessive play.
Old 04-02-2013, 11:56 AM   #11
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Maybe he is using the stock bolts. OP, that exhaust was meant to be welded together. Are you better at MIG or TIG welding?
JSchell1309 is offline   Reply With Quote
Old 04-02-2013, 11:58 AM   #12
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
lol that is a good one^^^
Old 04-02-2013, 11:59 AM   #13
btc2112
Member#: 322981
2012 WRX 5 Door
OP- Yes, it's normal. And I must say, damned funny too. You cant take offense man, gotta have thick skin around these parts, especially if you're going to vomit words into a thread like that.
Did you install a gasket?
btc2112 is offline   Reply With Quote
Old 04-02-2013, 11:59 AM   #14
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I usually just use hot glue so that its removable.
Old 04-02-2013, 12:03 PM   #15
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
yes well i used gaskets that were giving to me and used the stock crush gasket. car is garage kept and has only 2 k on it!
no leaks dealer said just turbo spool down low but wanted to ask and dig deeper.
Old 04-02-2013, 12:03 PM   #16
luan87us
Member#: 335013
2013 Premium WRX 5dr
I laughed so hard.
luan87us is offline   Reply With Quote
Old 04-02-2013, 12:19 PM   #17
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
The part in bold has 100% to do with nothing we need to know.
If you are having a tea kettle noise, you might have a leak. Without video, well we have nothing.
Old 04-02-2013, 12:31 PM   #18
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
well i checked for leaks and didnt feel or hear anything ill check again tonight and tighten up some bolts but again its just a CAT back stock downpipe. Also a tech from subaru drove the car with me in it. said it was normal turbo spool at 2500 in 5th gear
Old 04-02-2013, 12:32 PM   #19
Psychoreo
Member#: 79643
2015 WRX STI
Did you check for leaks in 5th gear at 2400rpm?
Old 04-02-2013, 12:35 PM   #20
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
well car sounds normal doesnt sound loud or anything if thats what you mean?
Old 04-02-2013, 12:37 PM   #21
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
usually you would hear a exhuast leak car sounds normal and all
Old 04-02-2013, 12:39 PM   #22
JSchell1309
Member#: 321321
Tuxedo Black
In all honesty it could be unrelated to your recent mod. Maybe the top mount coupler came loose, pretty common on these cars. Look under the hood for a short large diameter hose coupling he top mount to the intake plenum. If that is loose or off you have a boost leak and would create increase turbo noise.
Again, could just be a random problem unrelated to your CBE.
Edit: forgot to add that your blinkers will make a teakettle sound when they start to run low on fluid, check those out first.
Old 04-02-2013, 12:57 PM   #23
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
lol on the blinker fluid and i checked intake tubes and all, nothing loose. its just annoying around 2500 rpms other then that you dont hear it unless under throttle
Old 04-02-2013, 01:07 PM   #24
JSchell1309
Member#: 321321
Tuxedo Black
I would assume the turbo isn't spooling without throttle. And yeah the blinker fluid is an old one.
There is one last thing it could be. This fix goes way back to old legacies. If your top mount has any dirt between fins, it will start to whistle under throttle. It takes a while to explain but when you apply throttle, it brings the intercooler under pressure and will cause air to go through the clogged fins and whistle because they are under vacuum. Same theory as how a referee whistle works.
So to fix it you need to unclog the fins. The easiest way to do this is an old trick. A bar of soap will unclog the fins. Again it's tough to put into words but its as simple as taking a bar of Dove Ivory soap, putting it on the top of your intercooler, and driving around for about 10 minutes. The air passing over the soap has a way to clean out the fins. Make sure it's Dove Ivory, as it doesn't have any additional additives that could harm the intercooler.
Give that a try and it should clear up the noise.
Old 04-02-2013, 01:14 PM   #25
PlasmaBlue518
Member#: 347382
2015 WRX
CRYSTAL WHITE PEARL
lol yea okkkkkkkkkkkk i figured i would ask people on forums i didnt know a bunch of ppl would not help me lol smh ill think twice about asking for help again on here
