Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 04-02-2013, 01:15 PM   #26
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Originally Posted by PlasmaBlue518 View Post
lol yea okkkkkkkkkkkk i figured i would ask people on forums i didnt know a bunch of ppl would not help me lol smh ill think twice about asking for help again on here
Unless you post a video, the sound could be ANYTHING
Psychoreo is offline   Reply With Quote
Old 04-02-2013, 01:18 PM   #27
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
I was being serious.
https://www.google.com/search?q=lega...ient=firefox-a
See, it's a real thing...sorry for trying to help.
JSchell1309 is offline   Reply With Quote
Old 04-02-2013, 01:18 PM   #28
Scoobers
Member#: 341693
2013 Subaru
13 WRX SWP
Originally Posted by JSchell1309 View Post
I would assume the turbo isn't spooling without throttle. And yeah the blinker fluid is an old one.
There is one last thing it could be. This fix goes way back to old legacies. If your top mount has any dirt between fins, it will start to whistle under throttle. It takes a while to explain but when you apply throttle, it brings the intercooler under pressure and will cause air to go through the clogged fins and whistle because they are under vacuum. Same theory as how a referee whistle works.
So to fix it you need to unclog the fins. The easiest way to do this is an old trick. A bar of soap will unclog the fins. Again it's tough to put into words but its as simple as taking a bar of Dove Ivory soap, putting it on the top of your intercooler, and driving around for about 10 minutes. The air passing over the soap has a way to clean out the fins. Make sure it's Dove Ivory, as it doesn't have any additional additives that could harm the intercooler.
Give that a try and it should clear up the noise.
Scoobers is offline   Reply With Quote
Old 04-02-2013, 04:44 PM   #29
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,
1050 Triumph Speed Triple
Op, this is the real issue. You claim it's "a whistle from your turbo in 5th gear at 2400rpm". At 2400rpm, your turbo is only barely starting to spool up. We don't know where the noise is coming from, unless you meant "from up towards the turbo in the engine bay somewhere" when you said "from the turbo". If that's the case, the coupler could have come loose. It could be a small leak somewhere in your engine bay.
Give us a video and we can actually help.
Loyale93 is online now   Reply With Quote
