Old 04-02-2013, 05:37 PM   #1
originalozzyo
Member#: 198935
Default Reflashed and upgrade, now wont start
I just finished my uppipe and downpipe install and put everything back together. Did the 2.2K ohm resistor in the plug. Flashed with Accessport to stage 2 and went to turn the car on and nothing but rapid clicking. It almost sounded like it was going to turn over but real weak once then just more clicking. Is this a low battery? I had the radio on while I was working but I don't think it could have drained it that much as I've worked on the car before with the radio running. Wont have jumper cables till my brother gets home to try and give me a boost. Ideas?
originalozzyo is offline   Reply With Quote
Old 04-02-2013, 05:42 PM   #2
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Battery is dead bud.
boosted25 is offline   Reply With Quote
Old 04-02-2013, 05:49 PM   #3
Kanchou
Member#: 46936
2004 WRX
sorry about your start troubles... but am i the only one who found it hilarious that 'boosted' was the one who replied?
Kanchou is online now   Reply With Quote
Old 04-02-2013, 06:03 PM   #4
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
What's funny about it?
Old 04-02-2013, 06:06 PM   #5
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
i get it now lol
Old 04-02-2013, 06:49 PM   #6
originalozzyo
Member#: 198935
Am I missing something? lol thanks for the reply
Old 04-02-2013, 06:55 PM   #7
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Because you said your brother was going to give you a boost and my username is boosted. Lame joke lol. But back to the point, did you get the car jumped yet?
Old 04-02-2013, 09:04 PM   #8
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Your battery is dead. The amount of time to use a battery without the car running is generally only 90 minutes on a GOOD battery. Plus flashing the car with a bad/failing battery can corrupt your ECU.
Old 04-03-2013, 02:07 AM   #9
originalozzyo
Member#: 198935
Jump start worked fine. Let it idle for a while and took it for spin. Battery works perfectly again.
Old 04-03-2013, 08:15 AM   #10
quazimoto
Member#: 70395
You are lucky OP. Tons have bricked thier ECU trying to flash the ECU with a bad/weak battery. Even clearly states to check the battery condition before flashing in the AP user manual.
quazimoto is offline   Reply With Quote
Old 04-03-2013, 09:20 AM   #11
rkramer
Member#: 118209
2015 WRX Limitec
no, the battery isn't perfect... Flattening a conventional battery even just once reduces its life, so your battery is probably on its way out the door. Also you will want to put it on a charger. Unless you are driving around for an hour or more, your battery isn't close to full charged. A decent charger with a desulfation cycle can also help reduce the damage that was done by the full discharge.
