Old 04-03-2013, 11:25 AM   #1
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Default A-Pillar Dash Rattle Fix
I figured while I was repairing my Map light rattle I would tackle the A-pillar rattle as well. There are threads here which link to outside sites, so I figured it wouldnt hurt to post an actual tutorial here since this plagues EVERY subaru Ive ever been in.
First, you will need a flathead screwdriver, a 10mm socket wrench OR philips screw driver, and foam tape such as the one I have pictured below. And a panel tool wouldn't hurt to have handy.
My foam tape is from home depot and was $8 in the isle with air ducting. I wanted enough to do 5 subarus and other things around the house.
First off, pop off the SRS air bag tab to get to the screw holding the pillar in place. I found it least damaging to push the screwdriver in vertically and not slightly angled like my picture shows.
Once the tab has snapped up, you can pull it off with your fingers:
Go ahead and remove the screw with a 10mm socket wrench or use a philips screw driver:
Once that is out the pillar is ready to yank off. I started at the top with a panel remover to get my fingers under and used my fingers to yank it evenly as possible outwards. Once it snapped in the outwards direction I applied some upwards pressure to pull the bottom clips out of their slots.
Here is a video of me yanking mine off for the first time to show how easy it is:
You can see how crappy the foam tape Subaru uses is in that video.
Now, yank off Subaru's tape and apply the foam tape over the same areas.
Thats it, put it back together by pushing the clips back into the slots on the dash:
Click the pillar back in and put the screw and airbag plastic clip back on.
Then do your radar detector if you have one!
MtnXfreeride is offline   Reply With Quote
Old 04-03-2013, 11:28 AM   #2
855T
Member#: 246628
2010 Impreza WRX
Nice. I also found some light felt on the inside (facing the dash) bottom (dash side) edge of the pillar trim helped as well. You only need to cover the depth of the trim piece into the dash.
855T is offline   Reply With Quote
Old 04-03-2013, 11:30 AM   #3
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Oops I meant to post this in interior/exterior modifications.. Mods feel free to move it if it doesn't belong here!
Old 04-03-2013, 11:33 AM   #4
DC_Hokie
Member#: 315766
2012 WRX
Thanks for the clear write-up
DC_Hokie is offline   Reply With Quote
Old 04-03-2013, 11:41 AM   #5
Urabus86
Member#: 352287
Awesome! This should help a lot!
Urabus86 is offline   Reply With Quote
Old 04-03-2013, 11:59 AM   #6
grzydj
Member#: 84984
2006 Impreza 2.5i 5D
'04 Toyota Tacoma TRD
Looks like a good starting point for fixing the rattles in my Impreza. Nice writeup.
EDIT: Also trying to track down a rattle that only happens during the summer when the car is idling, like at a stop like while still in drive with the A/C on.
Turn the A/C off and the car revs a bit higher and the rattle goes away. It's a pretty low rattling sound as well, and super annoying. '06 Impreza.
grzydj is offline   Reply With Quote
Old 04-03-2013, 12:10 PM   #7
Ranchrex86
Member#: 349396
2013 Wrx Sti hatch
Plasma blue pearl
Probably a heat shield as the rpm's go up when the compressor kicks on. I would check the exhaust first.
Ranchrex86 is offline   Reply With Quote
Old 04-03-2013, 12:39 PM   #8
mejifair
Member#: 11356
2012 WRX STi Hatch
Most excellent post OP!
As soon as the temperature warms up enough I plan on doing this...thank you!
mejifair is offline   Reply With Quote
Old 04-03-2013, 12:58 PM   #9
erik11876
Member#: 275888
2011 WRX Limited
Subaru would do this for you, it's a TSB. I had mine done a week after I bought it.
erik11876 is offline   Reply With Quote
Old 04-03-2013, 01:31 PM   #10
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
It should be covered under warranty - however - last time I had something looked at in my 06' impreza they left a lot of grease marks in my car.. so I would rather do it myself since its so easy.. and this applies to a large range of subarus that arent under warranty anymore as well.
Old 04-03-2013, 02:37 PM   #11
mejifair
Member#: 11356
2012 WRX STi Hatch
Do you know what the TSB number is? I hear conflicting things that rattles have a TSB, then people say they don't.
Old 04-04-2013, 01:57 AM   #12
hozouria
Member#: 332388
2014 Whiteout FRS
2014 BMW 328d
nice. I want to go in and do everything. all inner panels. all pillars. the top of my dash (right above the radio) starts to rattle unless I put my hand on it and pull it slightly forward. poeifngqpijenfooijqergughhhh I need it gone.
hozouria is offline   Reply With Quote
Old 04-04-2013, 04:34 PM   #13
grzydj
Member#: 84984
Confirmed. It is a heat shield rattle! Funny that Subaru didn't notice it or fix it when they replaced the catalytic converter a few weeks ago. I'll put it up on ramps this weekend when I swap out the winter tires and do it myself.
Old 04-04-2013, 05:19 PM   #14
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
OMGHi2U
Thanks for this clear how to...especially like the video - it makes me more comfortable to see how easy it comes out. I am pretty anal when it comes to things and I am reluctant to do some things for fear of doing more cosmetic damage just to fix a problem...looks like this is a no brainer!
garzdos is offline   Reply With Quote
Old 10-16-2013, 10:58 AM   #15
granuale
Member#: 344989
2010 STI 5 Door
Sweet write up MtnXfreeride! Had some vicious rattling on a road trip last week, and so I did your fix last night. Super easy. I used a pocket knife to get the SRS badge off & that worked well. I also added some other strips of tape on the cover up top, and on the pillar itself towards the bottom. Looking forward to no rattles from this area - thank you.
Now I need to find some projects for the 29.5 feet of tape I have left over!
granuale is offline   Reply With Quote
Old 11-15-2013, 08:14 AM   #16
Pawk
Member#: 372730
2016 WRX-base
LAPIS
Search function worked perfectly in this case: I searched for rattle, this thread popped up, I completed the work and: no more rattles!
Simply wanted to say nice work and thank you to the OP.
Pawk is offline   Reply With Quote
Old 11-15-2013, 10:07 AM   #17
MaddMax
Member#: 9264
2016 BMW M235i 6MT
I've spent probably 10 hours fixing the rattles in my 2012 hatch including the infamous a-piller rattle. It's amazing to me how Subaru engineers saw it fit to place plastic directly on metal and plastic. I've probably identified 20-25 major rattle areas in this car so far. 1mm, 1" wide black felt tape (75' roll) from Amazon goes a long way. During my winter vacation, I'll do a lengthy write-up of the areas of concern in this car and how to address. My hatch now 95% rattle free in temps below 60 degrees and above 70 is completely rattle free. It's amazing much more solid the car feels and a bit more quiet when it doesn't rattle. It now rattles less than my prior Infiniti G35.
MaddMax is offline   Reply With Quote
Old 11-15-2013, 02:02 PM   #18
romanc
Member#: 274653
Did you also work on the hatch itself? Mine is making a ton of noises from where the plastic touches the glass. I am curious if you have any links/photos on how to remove the plastic so that foam tape can be placed between the glass and the plastic cover.
romanc is offline   Reply With Quote
Old 11-15-2013, 03:16 PM   #19
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
Looking forward to your write up!!! Mine is gaining a new rattle every day ;-)
Old 11-15-2013, 05:09 PM   #20
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
great write up!
WhatsASubie is offline   Reply With Quote
Old 11-15-2013, 09:45 PM   #21
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Oh yes, every panel was removed from the hatch. Takes less than five minutes to get every panel off. Basically you start at the top, then the vertical panels, then the large lower panel.
Old 11-16-2013, 08:08 PM   #22
Zumiez87
Member#: 206481
2013 WRX STI
Did this while at work on lunch took 5 mins max per side. And re routed my v1's power cord
Zumiez87 is offline   Reply With Quote
Old 11-16-2013, 10:05 PM   #23
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Originally Posted by Zumiez87 View Post
Did this while at work on lunch to 5 mins max per side. And re routed my v1's power cord
I should do my wiring for my radar detector too... good idea.
Weird going on this forum and seeing my year old post on the first page.. happened x2 today lol.
I just want to follow up now many months later and say that I've had days cold enough that my wife's new forester started creaking, but my car which had this quick mod done is still creak free (at least at the A-pillars). Ill be doing her forester soon.
Old 11-19-2013, 04:20 PM   #24
romanc
Member#: 274653
Do the panels just snap off, I didn't see any screws last time I looked.
Old 11-19-2013, 10:51 PM   #25
Jessewrx
Member#: 374096
2002 Wrx
I am so OCD about rattling interior pieces !!!!!!!
Jessewrx is offline   Reply With Quote
