Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 04-03-2013, 01:28 PM   #1
tec_41
Member#: 346278
04 WRX
Default Restrictor Pill Help...pics included
Basically I'm getting boost surging on the Cobb stage 2 OTS tune, which I think I've narrowed down the issue being a missing restrictor pill...at least I can't find one anywhere around the turbo.
I've been searching and reading, but I don't believe my vacuum lines are the same as any of the diagrams I've been looking at. From what I can tell, I need a restrictor pill in the line going from the compressor housing to the wastegate. However, the vacuum line from my compressor housing goes to some type of device with 2 other lines coming out of it. I don't know if it's an aftermarket boost controller, or if it's even the stock one...That's what I'm hoping you guys can help with.
I've attached 2 pictures, sorry they aren't the greatest. I can take other if needed.
http://imageshack.us/photo/my-images/59/vaclines.jpg/
Here's another shot, in case it helps
http://imageshack.us/photo/my-images...402192705.jpg/
I guess my ultimate question is where the heck does the pill go? And am I dealing with aftermarket parts here? Thanks for any help.
tec_41 is offline   Reply With Quote
Old 04-03-2013, 01:49 PM   #2
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
The restrictor pill goes in the first line off the intake. for better control get an after market three port ebcs. I just noticed in your pics that you have a three port I dont think you need a restrictor.
Old 04-03-2013, 02:15 PM   #3
tec_41
Member#: 346278
04 WRX
Ah thanks for the response...I guess that aftermarket ebcs would explain why the car wasn't overboosting/fluctuating before I flashed the new tune.
How does one compensate for this ebcs when using the Cobb stage 2 tune?
Old 04-03-2013, 02:17 PM   #4
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Get a protune.
EBCS requires significant modification of WGDC.
Alternatively you could source and install a stock boost control solenoid and run the OTS stage 2 map.
mechatricity is offline   Reply With Quote
Old 04-03-2013, 02:56 PM   #5
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
^^^ Pro tune is sooooo much better.
Old 04-03-2013, 05:23 PM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
3 port boost control requires significant tuning.
Alternately, you can use that 3 port as a 2 port via re-plumbing it and use the restrictor. This would give similar enough results to the stock for that Cobb tune to work for you.
Sounds like it's probably already tuned though if it had a 3 port... which means an off-the shelf tune might be worse.
Concillian is offline   Reply With Quote
Old 04-03-2013, 05:39 PM   #7
tec_41
Member#: 346278
04 WRX
Awesome, thanks. I might take this route in the meantime, work up to the protune. The previous tune gave me lean codes...And had trouble getting the car to idle after accelerating. It hit target boost properly, yes, but it was in need of some tweaking.
Old 04-03-2013, 06:08 PM   #8
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
to hook it up as 2 port, you go:
compressor nipple --> restrictor --> Tee
branch 1 of Tee --> Wastegate nipple
branch 2 of Tee --> Port labeled "to compressor housing" --> port labeled "to wastegate" (this port is normally closed when de-energized and open when energized) --> inlet
Cap off the port that's currently to inlet (this port is normally open when de-energized and closed when energized).
Old 04-04-2013, 09:28 AM   #9
tec_41
Member#: 346278
04 WRX
Excellent, thank you so much!
Old 04-04-2013, 11:26 AM   #10
art@grimmspeed
Member#: 301037
2004 Forester XT
Here is a good write up that Cobb did a while back
http://www.cobbtuning.com/Technical-...es-s/70674.htm
art@grimmspeed is online now   Reply With Quote
Old 04-04-2013, 05:36 PM   #11
Boostedbob
Member#: 336241
08 Sti
OPB
Check out Torqued Performance, Eric has some really good maps and will do revisons to get the car running just right.
Boostedbob is offline   Reply With Quote
Old 04-08-2013, 07:22 PM   #12
tec_41
Member#: 346278
04 WRX
https://docs.google.com/file/d/0BwTr...1hWXFsX1k/edit
Here is the latest 3rd gear pull after installing the restrictor pill and hooking up the 3 port EBCS in bleed mode.
And here is a picture of how I connected the vacuum lines. The restrictor pill is located right after the compressor nipple.
As you can see, the car isn't even close to hitting target boost now. Any thoughts?
Old 04-09-2013, 10:21 PM   #13
tec_41
Member#: 346278
04 WRX
Berrrrmmmp. I'm open to any suggestions
Old 04-09-2013, 10:50 PM   #14
myk
Member#: 223143
2001 2.5rs Sedan
Brack
Where in WI?
Did you get the correct pill? Their are a few different sizes you can get. You could try tightening the wastegate actuator arm but looking at those logs I think something is still plumbed wrong. Personally I'd tune for the EBCS, it isn't that overly difficult. Another option just to be sure is replace it with a stock BCS, I think I might have one sitting around.
myk is offline   Reply With Quote
Old 04-10-2013, 10:53 AM   #15
tec_41
Member#: 346278
04 WRX
Thanks myk. I got the pill for an 04 from the dealer, that's what he looked up and ordered for me. Not to say that it's for sure the right one, but I sure hope it is. I'll shoot you a PM!
