Old 04-04-2013, 11:27 PM   #1
splif180
Member#: 294817
95 Impreza
white
Default Accessport on 95 later impreza
ok i may be brain farting at the moment but if you swap a 2.0 or 2.5 wrx sti engine into a first gen. could you just hook up an access port to it and reflash the ecu instead of getting a stand alone and tune form there? will it rune or would you still need the stand alone?
splif180 is offline   Reply With Quote
Old 04-05-2013, 01:36 AM   #2
pmugabi
Member#: 280926
If you transfer the engine, wiring and ECU then you will be able to use an Accessport or open source to map the ECU.
The newage engine will not be a direct plug and play into the older wiring. The least effort route to put a new age engine into a classic car is using the newage shortblock and classic heads. That still gives you the option of remapping the classic ECU through chipping it.
pmugabi is offline   Reply With Quote
Old 04-05-2013, 01:47 AM   #3
splif180
Member#: 294817
95 Impreza
white
ok i think i got a good under standing of that. i was just looking at parts and came up with a thought that i might be able to make this work. im basicly trying to get an idea of what i want in a car.
