Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 04-06-2013, 01:19 PM   #1
projectvoltron97
Member#: 258203
Default Front end suspension clunking noise
I know there are a billion give or take threads on front end clunks in the driver front area, however, I can not find anything that is like my problem. My car only clunks when I turn right a little and then back left. It happens every time my car just barely starts to turn left. It seems like a pretty significant clunking noise also. I have cobb front and rear sways with whiteline endlinks, h&r lowering springs, and strut tower bars. I have disconnected the end links from the control arm and drove and it does the same thing. I have checked all the bushings and bolts on the front suspension and grabbed and tried to shake the axel (no play), steering rack (no play) and tie rods (no play). It only happens while my car is moving so it is hard to deduce what is making the pop happen.
If there is anyone out there that can help me I would greatly appreciate it
projectvoltron97 is offline   Reply With Quote
Old 04-06-2013, 02:48 PM   #2
projectvoltron97
Member#: 258203
Narrowed it down to something in the steering system
Old 04-06-2013, 04:06 PM   #3
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Replace the grease on the swaybar bushings with silicone grease. Most swaybars come with white lithium grease, which burns off pretty quick and leaves sticky residue that "grabs" the bar and pops when you go over stuff or turn hard enough. If it was an issue with something in the steering system it would most likely be repeatable and frequent.
I assume it also does this going in and out of angled driveways? You can test my theory by spraying some silicone lube into the swaybar bushings before pulling them apart.
aboothman is offline   Reply With Quote
Old 04-06-2013, 08:20 PM   #4
projectvoltron97
Member#: 258203
I tried spraying some lubricant on the the bushings and it didn't make a difference. I got it to start popping when the car is sitting still and from what I can see is its not the sway bar. The steering rack moves a little so I am thinking it might be a bushing in the steering system
Old 04-21-2013, 02:59 AM   #5
MedicDG
Member#: 329822
2012 WRX, Sedan
Front lower ball joints
MedicDG is offline   Reply With Quote
Old 04-21-2013, 08:11 AM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Assuming your car is a 97 from your SN
Lower ball joints x2
Old 07-10-2013, 02:43 PM   #7
NickPSI
Member#: 61625
2002 Impreza WRX
I know this is an old thread, but I have the same symptoms in an 02 wagon, I have done inner and outer tie rods as well as both lower ball joints and the control arm recall. Still pops even when sitting still on pavement when I turn the wheels lock to lock. Will not do it when the suspension is unloaded (on jackstands) I feel like it is the steering rack now, but I dont think that would have anything to do with the suspension being loaded or not. Maybe tension on the rack from asphalt resistance.
NickPSI is offline   Reply With Quote
