Old 04-06-2013, 04:25 PM   #1
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
97 Ford Ranger on Bags
Default spun bearing but is the block okay?
So last night I went to move my car to a different parking spot at my house
and as soon as I fired it up it started knocking
I shut it down immediately and pushed it to the spot it was going to put it in.
I had heard upon start up a bearing on it's way out for about 2 months, but couldn't locate where the noise was coming from since it only made the noise literally for a second or two.
My question is, since I didn't put any load on the car, and it only idled for maybe 10 secs, do you guys think that I'll need to replace the block?
Or can I have the car towed to the shop and have them break down the
motor and replace the bearings and whatever else is damaged?
the car had 196,xxx miles on the original motor
so close to my goal of 200k
TRinityMtrSprts is offline   Reply With Quote
Old 04-06-2013, 05:13 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
If you spun a rod bearing the block should be good but my crystal ball isn't working right now so I don't know for sure.
Old 04-06-2013, 06:48 PM   #3
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
The block should be fine...the internals however...you won't know until you pull it apart and find out how bad things got since all those bearing shavings can ruin your day.
skimobile is offline   Reply With Quote
Old 04-06-2013, 09:06 PM   #4
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
thanks y'all
I wish my crystal ball was working too ;(
Old 04-06-2013, 11:42 PM   #5
vf22Bugeye11
Member#: 272096
2002 6Speed swap wrx
Function Warrior!!
Noooooo so close
vf22Bugeye11 is offline   Reply With Quote
Old 04-09-2013, 04:58 PM   #6
bubjoe
Member#: 304600
mine spun at 197xxx i wanted 200xxx but a new built block with sti rods new crossed drilled crank haveing it polished and everything balanced and throwing some acl bearing in will make it handle the beating my car gets.good luck on the build bub
bubjoe is offline   Reply With Quote
Old 04-09-2013, 07:47 PM   #7
hoffmanEstates
Member#: 122043
04 wagonier
psm
I am 400 miles short of 200k
hoffmanEstates is offline   Reply With Quote
