Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 08-24-2012, 01:58 PM   #1
P&L Motorsports Inc.
Member#: 67199
07 [email protected] STI
97 RS [email protected]
Default P&L Motorsports BRZ/FRS Stg. 1 Turbo kit Results!
Event: Dyno Pull
Ambient Temp: 80° F
Elevation:
Weather: Sunny
Track and Conditions: N/A
Tires: Hankook V3s
Car: 2013 Subaru BRZ
Tuner: John Visconti @ P&L Motorsports
Dyno Info: Dyno Jet
Transmission: Stock 6 speed AUTO
Gear: 3rd
Peak HP at RPM: 403 whp
Peak Torque at RPM: 308 TQ
Baseline hp/tq for a Stock on Same Dyno: 154 whp
Target Boost: 15 psi
Target AFR: 11.8
Fuel: E-85
Engine/Power Modifications: Stock Engine, P&L Motorsports BRZ/FRS Stage 1 Turbo Kit, P&L Race Catback, P&L Mid-pipe
Driveline Modifications:
Suspension Modifications: KW v3 Coilovers, Brembo Big Brake Kit, Whiteline Sway Bars, P&L Stainless Steel Brake Lines
Other Modifications:
"TUNED USING EcuTek RaceRom"
The Kit:
The Car:
Dyno Results:
Thanks For looking!
P&L Motorsports Inc. is offline   Reply With Quote
Old 08-24-2012, 02:08 PM   #2
torquemada
Member#: 128484
2006 EDM WRX STI
3rd gear?
Old 08-24-2012, 02:42 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
Originally Posted by torquemada View Post
3rd gear?
It's indicated in the OP. Yes, 3rd gear.
cnk is offline   Reply With Quote
Old 08-24-2012, 03:20 PM   #4
Lminette
Member#: 138923
2000 2.5RS Coupe
Satin Green Metallic
Not sure that I like the turbo placement.
Lminette is offline   Reply With Quote
Old 08-24-2012, 03:33 PM   #5
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP [email protected]
Damn you E 85! Great job guys.
berge56 is offline   Reply With Quote
Old 08-24-2012, 04:34 PM   #6
torquemada
Member#: 128484
2006 EDM WRX STI
and why?
For me, itīs normal to use the gear nearest to 1, that would be for the manual transmission the 5th gear, and for the autotragic the 4th gear.
Old 08-24-2012, 05:08 PM   #7
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
and why?
Because those gears can reach an unreasonably high mph for a dyno.
Awesome numbers guys! Makes me think about getting one
-Ty
AMS is offline   Reply With Quote
Old 08-24-2012, 05:24 PM   #8
Dreamforlimitedsti
Member#: 312727
2003 WRX/STI hybrid
PMS
I really don't like the BRZ. But not bad at all with the with that turbo set up. May I ask how much did everything come up to to get those numbers?
Price of mod's and tune? But great car first one I like some what. Keep they pics and mod's coming!
Dreamforlimitedsti is offline   Reply With Quote
Old 08-24-2012, 06:13 PM   #9
North Star
Member#: 191334
2005 Forester XT
Cayenne Red
That is very impressive. Do you guys have a run or tune on 91?
North Star is offline   Reply With Quote
Old 08-24-2012, 06:19 PM   #10
Member#: 67199
Old 08-24-2012, 08:27 PM   #11
chadb
Member#: 198179
2007 STI
UGM
Have you reached target boost yet? How much do u think the bottom end could handle?
chadb is offline   Reply With Quote
Old 08-27-2012, 03:32 PM   #12
torquemada
Member#: 128484
2006 EDM WRX STI
-Ty
thanks, but I still donīt buy this...cars with much more hp were testet all over the world, and most of the tuners are using the gear nearest 1
Old 08-27-2012, 03:52 PM   #13
cnk
Member#: 10757
Here you go. Read up on why it really doesn't matter: http://forums.nasioc.com/forums/show....php?t=1478091
Old 08-27-2012, 06:46 PM   #14
torquemada
Member#: 128484
2006 EDM WRX STI
well, Iīve read the thread, and it does matter.
- wheel torque is different
- wheel hp is different
- and sponaugle itself claims first "no difference" in post #35 and than "there is a difference" in post #43
in your thread it clearly states that "wheel torque" and "wheel hp" will change with different gears...funny that the tuners here are giving us the wheel numbers, but who am I...
Old 08-27-2012, 08:17 PM   #15
cnk
Member#: 10757
Read the thread more carefully. What exactly are you trying to do? Your point initially was why wasn't the tune done in a gear closer to 1:1. The thread I linked explains exactly why this does not matter. If you are chasing numbers, then you can go with different gears until you get the peak numbers you're looking for.
The point of dyno tuning shouldn't be to aim for a peak number, but to aim for a smooth curve and maximize the area under the curve. What you should really be comparing when looking at a dyno readout is comparing the percentage difference between the baseline run and the "tuned" run. That will show you a percentage gain or loss. The only important factor here is using the same gear.
In regards to tuning in a lower gear as opposed to a higher gear, I'm with AMS on that as it is a safety concern. Have you ever seen a car jump off the dyno? I would not want to be near one if it was spinning the wheels at 140+ mph in a high gear.
Old 08-30-2012, 09:13 AM   #16
sportsguy83
Member#: 316140
2013 BRZ
GBS
Let's try to keep the discussion on the P&L Turbo Kit.
sportsguy83 is offline   Reply With Quote
Old 08-30-2012, 05:18 PM   #17
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
That's hardly a Stage 1.
Stage 1 = Reflash Only
Stage 2 = Reflash + Exhaust
Stage 3 = Reflash + Exhaust + turbo + intercooler
Stage 4 = Reflash + Exhaust + turbo + intercooler + E85 (maybe injector)
Mattr762 is offline   Reply With Quote
Old 08-30-2012, 05:56 PM   #18
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
"Stage X" is whatever the company making it wants it to be. Don't get all caught up with "Cobb Stg 2" and "TurboXS Stg 3" or whatever.
Besides, this isn't a "Stage 1 BRZ" it's a "Stage 1 Turbo Kit". Haven't you seen companies sell staged brake kits or suspension kits? Those have nothing to do with reflash, etc. It's just a way to differentiate products.
2point0 is offline   Reply With Quote
Old 08-30-2012, 06:38 PM   #19
Misanthrope789
Member#: 174595
2005 STi
Frank Dux Edition
I'm curious to see how the drivetrain will handle the boost over time...
Misanthrope789 is offline   Reply With Quote
Old 09-03-2012, 04:26 PM   #20
Mattr762
Member#: 31624
02 WRX White
I understand what you're saying, but "Stages" are stepping stones. Stage 1 is usually a small increase in power, Stage 2 adds a little more, stage 3 even more... Stage 1 shouldn't be doubling the power with some special gas. What are they going to call a "Stage" that offers 50hp over stock instead of 200? Stage .25?
Old 09-03-2012, 05:30 PM   #21
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Like you said, stages are stepping stones. Stage 1 is what they have available now. If they feel that adding something that only gains a small amount of horsepower isn't worth bragging as "Stage 2" then they can just call it "Stage 1 with (insignificant upgrade)".
They can just call it Stage 2, but they're under no obligation to do so.
Old 09-06-2012, 04:41 AM   #22
neverendingmods
Member#: 23796
2006 STi
white
"stage 1 turbo kit" . Not stage 1 power kit.
This is likely a $8k turbo kit. Stage 1 means that is the initial turbo. Stage 2 turbo kit will be all same parts plus bigger turbo and injectors(maybe pump too). Stage 3 even BIGGER turbo.
People hating on a BRZ because it makes more power than their car,lol
neverendingmods is offline   Reply With Quote
Old 09-06-2012, 05:49 PM   #23
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
[off topic] Go back to the newbies section. [/off topic]
Seeing this makes me really want to sell my car and get a brz and turbo it.
Great job on the turbo kit. Only time will tell how the engine will hold up to the power.
k04sti is offline   Reply With Quote
Old 09-06-2012, 09:08 PM   #24
Decipher
Member#: 262760
2011 WRX Hatch Limtd
If they call it Stage 2, then it makes even less sense since they don't have a stage 1. They just bypassed it? FML. This "stage" stuff is wrecking the tuning community.
Nice job, P&L. Semantics aside, your numbers are impressive. Good thing I don't own a BRZ. I'd be knocking your door down for a kit.
Decipher is offline   Reply With Quote
Old 09-06-2012, 09:26 PM   #25
cnk
Member#: 10757
Honestly, who cares? Back in the day a TXS Stage 4 was equivalent to a Vishnu Stage 2. Each company can name their products however they want. It's up to the consumer to figure out what they want and who to get it from. It's not like you're dealing with the IEEE here with a set of standards that everyone has to abide by. It's pure marketing.
