Old 04-07-2013, 07:01 PM   #1
25rsti
Member#: 166324
Default EcuFlash won't open
I just downloaded and installed all associated programs and files needed for the use of my new Tactrix cable 2.0
I went into my car connected the flash connectors plugged in the Tactrix to my lap via usb port tried opening EcuFlash and windows gave me a pop up saying 'ecuflash has stopped working' and closed it down.
I've uninstalled it and reinstalled it multiple times even trying different locations for the program and files.
I'm running Windows Vista.
TIA
Old 04-08-2013, 12:12 AM   #2
pmugabi
Member#: 280926
Well Vista was one of the most buggy OSs produced by Microsoft when they were still getting the privilege management features sorted out.
If Vista has got run as administrator then use that to install and run Ecuflash and see if it helps.
Otherwise, use XP or Windows 7.
pmugabi is offline   Reply With Quote
Old 04-08-2013, 08:06 AM   #3
25rsti
Member#: 166324
Easier said than done for me.
I did try opening it as administrator with no difference.
Old 04-08-2013, 08:18 AM   #4
25rsti
Member#: 166324
I should also note that RomRaider works fine.
Old 04-08-2013, 10:08 AM   #5
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
nmlittlebigman is offline   Reply With Quote
Old 04-08-2013, 02:47 PM   #6
25rsti
Member#: 166324
Thanks but his problem was different. My ecuflash program won't open at all. I haven't even gotten to the point of connecting to the car.
I did try a really old laptop like 10 years old laptop and ecuflash opened up no problem BUT I would rather use my newer laptop because the other one needs to be plugged into an outlet to stay on
Old 04-08-2013, 03:26 PM   #7
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Likely a windows issue and not ecuflash at all. Have you updated all your drivers, especially all the windows drivers as well as video drivers. There is a program thats free for download that will tell you why your last run program crashed. After work ill find it and link it.
Try booting up vista in safe mode WITHOUT networking and see if it will load and run that way. If it does its definately a windows or video driver conflict.
Cathexis is offline   Reply With Quote
Old 04-08-2013, 04:03 PM   #8
25rsti
Member#: 166324
Will try that right now, thanks.
Old 04-08-2013, 05:03 PM   #9
Cathexis
Member#: 335445
2012 WRX - BLK STIG
This is a standalone application, it requires no install. Just run it after the crash and it will give you all the info to troubleshoot it it. The .dll file list is the drivers involved when it crashed.
http://dottech.org/24452/windows-win...eporting-tool/
Dl link ist at the bottom....
Old 04-09-2013, 05:40 PM   #10
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Any luck?
