Old 04-07-2013, 07:16 PM   #1
weeble1
Member#: 352330
Default Need a little help. I bought into a mess I think.
OK so I picked up an 02 WRX with a 2.5 swapped in it. Apparently it has 850CC injectors, HTA68 turbo pushing 20 lbs, full turbo back, AMR inlet pipe, Greddy catchcan, evo 8 front mount and a few other small things. I was told it was tuned by PTUNING here in VA and it put down 333 AWHP and 333AWTQ. Here are my issues (Please keep in mind I'm COMPLETELY new to these cars and boosted cars in general), I have a cylinder 2 misfire but only at idle and under 3500 rpm or so. I have changed the plugs (NGK LFR7AIX gapped at 30) and when I did that I swithed the coil. I'm about to go hook up the code reader after I take her for a spin to see if it switched to a no.1 misfire. Full throttle the car moves out with no issues and no smoke out of the exhaust.
I am also having issues with the catch can (greddy). Air is blowing out of the breather hole, spraying oil mist everywhere. There is not a lot of oil in the can and the little bit that is in there, it's yellow so I assume that's fine. Possible PCV issue? I can feel air blowing out of it at idle. I think that's it for now. It's just going to take a little time to clean the bay up. Random vacuum lines and breather tubes running all over. I figured it wasn't a bad pick up for $4,000 with 126K on the body. Any help on either of the above issues will be greatly appreciated. Thanks in advance!
Josh
weeble1 is offline   Reply With Quote
Old 04-07-2013, 09:48 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
with the engine at operating temp and running at idle....take the oil filler cap off
if you get a raw exhaust hurricane blowing out of the opening.....its time for new pistons
Old 04-07-2013, 09:49 PM   #3
weeble1
Member#: 352330
Crap... ok ill try it. Thanks
Old 04-07-2013, 09:54 PM   #4
weeble1
Member#: 352330
And new pistons it is... what's the going rate for a rebuild on one of these?
Old 04-07-2013, 10:05 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
welllllll....depends on how much you can do yourself
and what all is toast in the motor
do NOT re-use the oil cooler!!!!!
throw it away and get a new one.....you have been warned
Old 04-07-2013, 10:07 PM   #6
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Do your research. But start saving 4K or more.
As a personal opinion, do not go back to that tuner. PM me if you REALLY want to hear why.
Old 04-07-2013, 10:14 PM   #7
weeble1
Member#: 352330
I have a buddy that is pretty well skilled with these cars. We can probably pull the motor. It's just going to be a daily for my girlfriend, so I really don't want to drop a ton of money into some nasty build. This sucks... lol.
Old 04-07-2013, 10:16 PM   #8
weeble1
Member#: 352330
4K? Holy crap! That's more than a rebuild on an LS1 car... with twice the cylinders. I might just want to sell this thing... PM sent
Old 04-07-2013, 10:16 PM   #9
Type2
Member#: 200436
2004 Forester XT
Add a couple more grand for labor if you aren't going to do the swap yourself. Plus another k for random things going wrong. Ask me how I know.
Type2 is offline   Reply With Quote
Old 04-07-2013, 10:26 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
d00000000000000d...chebbys are nickle and dime cars
subarus are 50cent and dolla bill cars : unamused:
Old 04-07-2013, 10:30 PM   #11
weeble1
Member#: 352330
Anybody wanna buy an 02 WRX? Well I guess I better start looking and researching. Thanks for all the good info.
Old 04-07-2013, 10:31 PM   #12
weeble1
Member#: 352330
Yea, I love my redneck Trans Am. lol
Old 04-07-2013, 10:41 PM   #13
weeble1
Member#: 352330
What I don't get is that it's kinda intermittent... sometimes if doesn't misfire at all and sometimes it bucks really hard and then full throttle it pulls like a raped ape. I'm just lost.
Old 04-07-2013, 11:29 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
its just mostly blowed up......either sell it or stop driving it...ya just gonna make it worse
and out of all the cars ive owned....my 79 T/A was my fav detroit hunk of ****
i cried when that car got totaled out, sittin parked at the curb
Old 04-08-2013, 01:16 AM   #15
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
its a hybrid right?
2.0L heads on a 2.5 block?
if so you have the wrong plugs in there.
you need NGK BKR7E
try that first
-Phil
Flat 4 Motorsport is offline   Reply With Quote
Old 04-08-2013, 01:53 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by Flat 4 Motorsport View Post
its a hybrid right?
you need NGK BKR7E
try that first
-Phil
phil....i think the real tell here is the exhaust gas hurricane coming outta the oil filler opening
dont think plugs are gonna do a whole lot for that one
Old 04-08-2013, 07:35 AM   #17
weeble1
Member#: 352330
its a hybrid right?
you need NGK BKR7E
try that first
-Phil
That's one thing I was wondering. When I first got the car, I pulled the plugs expecting to see the 2.0 plugs because I figured it was a hybrid. But the previous plugs were for a 2.5. Is there a casting number I can see somewhat easily on the heads?
Old 04-08-2013, 07:43 AM   #18
weeble1
Member#: 352330
If the rings were fried like that, would I see smoke out of the exhaust? And oild consumption? I don't have either of those symptoms. Sorry if I'm asking stupid questions.
Old 04-08-2013, 01:44 PM   #19
Luc
Member#: 276589
2004 WRX STI
Compression test and or leakdown test asap before you start drive and/or run the car anymore that will answer a lot of is the motor blow questions.
Luc is offline   Reply With Quote
Old 04-08-2013, 03:26 PM   #20
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
They ant the only ones that cant tune
I can name 2 other shops in the Mid-a north Va that eat ****, and still most people steer newbies to them to get their pockets raped and a "conservative no power tune" because of that support your local shop horse **** even though they suck.
Pm sent if you dont want to deal with shop bull****
Dr. octagon is offline   Reply With Quote
Old 04-08-2013, 03:27 PM   #21
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
The motor is already toast if smoke is bellowing out of the filler cap.
Old 04-08-2013, 03:46 PM   #22
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Shop around: refreshed Shortblock should be 1600-2000, depending, with forged pistons if cranks in good shape. This should be with machining, bearings and assembly. Refreshed heads if all is good 350-400 for the pair. Assuming you do the pulling, delivering, and reinstall.
Pull it out and fix it or sell it. Besides the obvious rings/piston issues. Valve issues can give you constant mis-fires. Leakdown would help you pin point what's going on with #2.
2.0=S20
2.5=D25/wrx
2.5=B25/sti
mccanixx is offline   Reply With Quote
Old 04-08-2013, 04:31 PM   #23
some dude
Member#: 100300
06 WRX
CGM
Check out this thread: http://forums.nasioc.com/forums/show....php?t=2476439
I took my oil cap off while running and it seemed like there was a fair amount of air coming out of there. No oil, doesn't seem like nasty air. My car is stock and consumes zero oil. I would do compression / leakdown test to know for sure how toight the engine is. And, even it if isn't totally amazing and tip top, it might run for 75k more and not blow up. Check oil level every time you fill up to start, and then as you get an idea as to the level of oil consumption you can check less often. Good luck with the car. 330 hp and tq sounds like a blast.
some dude is offline   Reply With Quote
Old 04-08-2013, 05:56 PM   #24
weeble1
Member#: 352330
I gotta say that I'm really impressed with how helpful you guys are. I really appreciate all the good info. Hopefully ill do a compression test this week and go from there. Fingers are crossed. Ill also look at the casting number on the heads to see if I need to grab the other plugs.
Old 04-09-2013, 04:54 PM   #25
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Most important thing is to stop driving it until you find the problem.
You could end up killing a good motor by driving it.
Badmunky is offline   Reply With Quote
