Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 04-08-2013, 02:20 AM   #1
Fatherrhyme1
Member#: 291435
Default Can anyone identify this rear end noise ?
I took a video it's the easiest way to explaine it , I have a humm from 45-65mph only while deceleration any ideas on what it could be ?
Link: Check out this video on YouTube:
http://youtu.be/sOZ-sgKBnTo
Sent from my iPhone
Fatherrhyme1 is offline   Reply With Quote
Old 04-08-2013, 03:11 AM   #2
Fatherrhyme1
Member#: 291435
Bump I see people lookin but not one have a guess as to what it could be ? Cv boot? Rear diff? Wheel bearing ? I don't think it's a wheel bearing as the sound does not change when I turn idk tho
Old 04-09-2013, 06:45 PM   #3
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Would be helpful if you told us what car and mods this has.
Guessing from knowing nothing about your car. Rear diff. If you have stiff rear diff or outrigger bushings.
talvai is offline   Reply With Quote
Old 04-09-2013, 07:00 PM   #4
Fatherrhyme1
Member#: 291435
I sent a link to the vid of what it's doing , it's a 05 wrx everything in the drivetrain is stock
Old 04-09-2013, 10:00 PM   #5
mhoerath
Member#: 131379
2003 354 ftlb@3k rpm
justablue hatch
wheel bearings -usually -are a constant whir that changes with wheel speed and may increase/decrease during turning. how many miles? check your trans and diff fluids levels? time for a lube change in either?
mhoerath is offline   Reply With Quote
Old 04-09-2013, 10:19 PM   #6
Fatherrhyme1
Member#: 291435
I thought it could be a wheel bearing but it don't change when I turn at any rate only happens when decelerating from 65mph then goes away at 45mph
Old 04-09-2013, 10:20 PM   #7
Fatherrhyme1
Member#: 291435
Also I will be changing the trans and diff fluid tm anyone have any suggestions as to maybe a thicker oil I could run to quiet it down ?
