Old 04-08-2013, 11:59 AM   #1
PurpleSauceGDA
Member#: 279655
04 wrx limited
wrb
Default JDM vs. USDM 5 speed
hey guys, so my usdm 04 wrx's transmission is kaput. i now have a jdm replacement, i am aware the ratios are different however i cannot find what differential i need to make this setup work. or can i use my usdm diff with some sort of modification? etc..
thanks in advance for any help
PurpleSauceGDA is offline   Reply With Quote
Old 04-08-2013, 12:40 PM   #2
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
You will need a lot more information for someone to properly answer your question. Just saying a "jdm replacement" isn't enough. What year jdm trans did you get? Is it a 5 speed or a 6 speed?
I'm guessing you bought a 5 speed jdm transmission which usually had a 4.44 gear ratio. To put this in you would need to first buy a 4.44 rear end to match.
Dirtyhobo010 is offline   Reply With Quote
Old 04-08-2013, 12:49 PM   #3
skets
Member#: 170698
2003 WRX V-Limited
Is there any difference with the gears themselves?
skets is offline   Reply With Quote
Old 04-08-2013, 12:54 PM   #4
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
mhoerath is offline   Reply With Quote
Old 04-08-2013, 05:27 PM   #5
PurpleSauceGDA
Member#: 279655
04 wrx limited
wrb
yes it is a 5 speed, 4.44 rear end which you can source from a forester? or a baja turbo? if my research is correct. i suppose my question at this point is will my stock axels fit or will i need to modify/replace them?
thanks,
matt
Old 04-08-2013, 05:45 PM   #6
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Stock axels and DS from an 04 wrx should work without a problem. You can pull the rear diff cover off to verify the ratio when sourcing your new diff.
Old 04-08-2013, 07:52 PM   #7
PurpleSauceGDA
Member#: 279655
04 wrx limited
wrb
fantastic, thanks guys ill let you know how it goes
Old 04-09-2013, 05:48 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
4.44 gears are gonna be REAL short and you will NOT like cruizin on the highway at 4xxx rpms
