Old 04-08-2013, 06:10 PM   #1
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
Default 2005 impreza 2.5rs auto Hesitation/low iddle
So a little history....
Changed the head gasket a few months ago. Car has 153xxx miles on it. After changed the head gasket I replaced sparkplugs but the wires didn't come in yet, so I ran it with the old ones. After a few days the car was misfiring like crazy and would stall out. So I stopped driving it and changed the wires. After doing so I got the famous code p0420. I ignored it at first because I figured since I was misfiring some gas prob got burnt down the pipe and caused the cel. After a few days the code went on and off and the. Went away completely.
Out of no where I started hearing a rattle as I accelerate. Searched on line and others where having a similar issue and most was caused by the shield on the headers. So I took them off. But the noise is still there. I took a mallet and tapped slightly on the cats and they sounded rattely.
Now my idle is very low under 500 and lower...and car shakes when it idles.
What is causing this? I just changed the fuel filter and hoped that it would fix the idle but nothing.
Is it the cat? O2 sensors?
Any help is appreciated.
Jb2.5rstst is offline   Reply With Quote
Old 04-08-2013, 08:48 PM   #2
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Quite possible a clogged cat that has broken up inside the housing. This would also give you hesitation as the flow is restricted through the exhaust.
kero is offline   Reply With Quote
Old 04-08-2013, 09:06 PM   #3
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
Would that also explain the low idle or is that from the o2 sensor ...
Old 04-09-2013, 09:38 AM   #4
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
??? Bump...
Anyone else have any ideas
Old 04-09-2013, 12:14 PM   #5
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Exhaust restrictions can def cause idle issues.
Old 04-09-2013, 01:32 PM   #6
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
One thing I forgot to mention is that the car idles at 499 in neutral and park....but once in gear it goes down ....
Old 04-10-2013, 11:28 AM   #7
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
That is correct, idle will be higher in neutral or park as there is no load on the engine.
Old 04-15-2013, 09:28 PM   #8
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
I am aware of that however there is hard vibrations and car feels like it wants to stall....is this caused by the cat being clogged or maybe o2 sensor going bad?
Old 04-16-2013, 01:06 PM   #9
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
I would say more cat that 02.
Old 04-16-2013, 03:54 PM   #10
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
K..well I ordered a set of tsudo uel headers with cat delete...hopefully that does the trick
Old 04-16-2013, 11:07 PM   #11
Theglovebox
Member#: 353701
Bump.................
Theglovebox is offline   Reply With Quote
Old 04-16-2013, 11:07 PM   #12
Theglovebox
Member#: 353701
Bump.........................
Old 04-18-2013, 08:08 AM   #13
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
Still haven't received the headers yet....ordered them from semotors.com..originally I ordered the CATLESS ones but they were out of stock do I got the ones with the high flow cat....should come in this week...will update once they are installed
Old 04-26-2013, 05:53 PM   #14
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
Got the tsudo headers...just running the headers and cat pipe right now...getting the exhaust welded tonight hopefully to complete the system...
Still have some hesitation and car feels like it's wants to stall when in park idle as well as when in drive and idleing....mostly when in drive though.....
What can cause this...
Could it be the injectors? No check engine light....
Anyone?????
Old 04-26-2013, 10:05 PM   #15
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
Bump.......
Old 04-28-2013, 11:42 AM   #16
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
Bump....anyone
Old 04-29-2013, 12:36 PM   #17
ohdamngetit
Member#: 336549
2005 Saab 92x
Desert Silver
I just changed the valve cover gaskets and spark plugs on my Saabaru. Straight forward, easy job. I go for a test drive and when I come to a stop, the car stalls out. Restart and very low idle. This happened multiple times on my way home. Got back to the house, rechecked everything and found that one of my hose claps weren't tight enough on the intake pipe. Tightened it down and fixed the idle issue.
Could your problem be an air leak like mine?
ohdamngetit is offline   Reply With Quote
Old 05-01-2013, 02:52 PM   #18
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
I wouldn't be surprised that I have a small leak by the intake cuz my stock box is a little messed up....will be doing the hybrid intake soon so that will eliminate the problem.....
Though I think what's causing the issues is the o2 sensors....
After my hg change the car was misfiring really bad because I needed to change the sparkplug wires....and I mean really bad...at least 2 cylinders at a time and would stall every few feet....once I changed the wires it ran better but that's when the idleing issue began and then slowly the hesitation....
Since the unburnt fuel was getting dumped down the exhaust and prob igniting there is it possible that the o2 sensors got messed up because of that...
Old 05-02-2013, 10:33 AM   #19
tauntaun
Member#: 355236
2001 Impreza L wagon
Sedona Red Pearl
I would try changing the oxygen sensor. Any time that the air/fuel mixture is messing up in a car it's usually to blame, most common car repair in America.
tauntaun is offline   Reply With Quote
Old 05-02-2013, 10:45 AM   #20
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
The misfire could be a leaky valve cover gasket. Have you checked the plugs to see if they have oil on them?
Mike
GrimmSpeed is offline   Reply With Quote
Old 05-03-2013, 10:14 AM   #21
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
Which sensor should I change...I know the front one is the one that controls the a/f mixture the most...
Or should I change both....
Old 05-03-2013, 10:16 AM   #22
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
Mike
When I did my hg I replaced the vc gaskets with new grommets ...new sparkplugs and wires....and that has been around jan this year
Old 05-18-2013, 06:36 AM   #23
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
Update
So I replaced both o2 sensors with denso oem....and customized the exhaust where there's only one cat....
Hesitation seems to be gone but I am still having very low idle when in drive or reverse and car is very rough and vibrates hard...
What else can be the issue that's causing the low iddle? When in neutral or park car idles perfectly?
Old 05-18-2013, 07:22 AM   #24
RallyB
Member#: 294247
2007 Impreza
Throttle control sensor perhaps?
RallyB is offline   Reply With Quote
Old 05-18-2013, 12:42 PM   #25
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
I was thinking of that but dreading it since I know it's quite pricey....
How would I be able to check if its faulty or not
