Old 04-08-2013, 09:37 PM   #1
Kikodaz
Member#: 352845
Default Gas Tank Issue
Hi I'm new to the forum.
I'm in the process of buying a 2004 STI and since I don't know much about the car so I took a friend who has a 2005. He said that every major component was in very good to excellent range (for a 2004 car). However the guy that has it know told me that he can't fill the gas tank completely. This is because it starts to spill out of the car. He says it falls underneath the car where the gas tank is and it has never fallen inside the car (friend has no idea what the issue might be).
My question would be if anyone has any idea what the gas tank issue might be and how easy or complex a fix would it be?
Thank you.
Kikodaz is offline   Reply With Quote
Old 04-08-2013, 09:56 PM   #2
btc2112
Member#: 322981
2012 WRX 5 Door
Thank you.
Howdy
Take the car to your mechanic/shop for a pre purchase inspection. They should be able to check it out for you and offer better advice on what the issue is and what it's going to take to fix than most here can.
btc2112 is offline   Reply With Quote
Old 04-08-2013, 10:24 PM   #3
Kikodaz
Member#: 352845
Originally Posted by btc2112 View Post
Howdy
That is good advice and I'm planning on doing it this Saturday. But my mechanic is more into tuning/working with Honda S2000's (which is my current car) and Honda's in general (although he does have a few evo and 350/370z projects, but never seen a Subaru there) so I wanted to have an idea of the issue might be before taking the car there. Although I don't think it should be that hard for him to see the problem after all he's a tuner and I think gas tanks are pretty common .
Old 04-08-2013, 10:30 PM   #4
btc2112
Member#: 322981
2012 WRX 5 Door
Quoted for truth, he should be able to figure it out for ya and give you an idea of what you're looking at. Good luck, hope it works out.
Old 04-25-2013, 08:30 AM   #5
Kikodaz
Member#: 352845
Thanks
Old 04-25-2013, 09:35 AM   #6
Brent22
Member#: 350169
2013 WRX Hatch
I would find a new mechanic then. Don't get me wrong, I definitely understand wanting to stay with someone who has proven themselves to you but on some levels cars are cars, on other levels you really need an understanding of the specific car. What works on a Honda may not work on a Subaru and may not work on a Nissan, etc.
Brent22 is offline   Reply With Quote
Old 04-25-2013, 09:46 AM   #7
cmiovino
Member#: 134005
2004 WRX Premium
So I'm kind of confused. You can't fill it completely up to full? But on other hand you say "it has never fallen inside the car"... kinda saying like you've never gotten gas in the car?
I'd check the gas filler tube that runs from the filler door to the tank. They commonly rust out. You could have a hole there from rust, or it can be coming apart at the rubber tube that connects to this metal tube. There is a clamp holding it on.
Start there first.
Old 04-25-2013, 05:34 PM   #8
Kikodaz
Member#: 352845
No sorry that's bad explaining in my part. Gas goes in the tank once the tank is almost full it starts spilling out. As long as you don't fill the tank fully it doesn't spill out. The inside of the car thing was a bad translation on my part.
I've had the car less than a week and did put gas in it once. Didn't fill it up and it didn't spill fuel. However it did go from almost 1/2 tank to almost 1/4 tank overnight so something is wrong in the gas tank.
