Old 04-11-2013, 12:10 PM   #1
Sean2.5Black
Member#: 150647
98 Impreza 2.5RS
Ej20G hybrid
Default Upgrade ej20g oil pump for vf39/43?
Hey guys a few years ago I put a vf39 on my 20g and ended up ruining the bearing in it... after talking with some subaru people and techs, it turns out this was supposedly a common problem in the 2 liters due to the smaller oil pump size... but what I've learned is only the 08+'s have a larger oil pump..
My question is;
When I end up doing my timing belt/seals, is it worth upgrading to an 08+ oil pump or should I just grab a 2liter pump?
Current setup;
Yellow tops
20g short block
2.5 heads
Vf39/43 soon
Not looking for more than 300hp
Sean2.5Black is offline   Reply With Quote
Old 04-11-2013, 12:22 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
bigger isnt better, and a 10mm is certainly adequate for what you have.
eg33GC is offline   Reply With Quote
Old 04-11-2013, 01:26 PM   #3
Sean2.5Black
Member#: 150647
98 Impreza 2.5RS
Ej20G hybrid
Is the stock 20g a 10mm? I'll just grab an oem one if so lol.
Old 04-11-2013, 01:33 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
indeed
Old 04-11-2013, 01:53 PM   #5
luka
Member#: 194742
1993 Impreza WRX JDM
the newer STI's came with 11mm stock no? is that a bolt on for the 20g?
luka is offline   Reply With Quote
Old 04-11-2013, 02:39 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
read the built motor forum on over-pumping stock engines
Old 04-19-2013, 12:53 AM   #7
NewWRXMike
Member#: 341540
This was something I was looking into as well because I was doing my timing belt. I decided to just reseal the oil pump and change out the O-ring.
NewWRXMike is offline   Reply With Quote
Old 04-19-2013, 01:28 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Bigger pump than necessary will destroy your bearings - eventually. I always make sure that the pump size is matched in such a way that maximum oil pressure is available just before the turbo starts to really spool up and load the bearings. The bigger the turbo and the more revs you intend to make, the smaller the pump can be.
If the block has a lot of oil flow sapping features like AVCS, dual AVCS and/or oil squirters or larger bearing clearances you need to compensate for that with a pump one size bigger though.
Marnix is offline   Reply With Quote
