Old 04-11-2013, 01:14 PM   #1
gfv355
Member#: 330335
02 wrx, stage 2
Default Tactrix on the way just a couple questions first
I read the stickies on the tactrix cable and i noticed its really dated. At one point it says that the maps dont flash well in anything other than xp and vista. All the laptops i have run windows seven and the new version for ecu flash has a win 7,8 download. Will i be okay to flash maps in win seven 64 bit right now or should i get a copy of vista or xp and install that solely for the purpose of flashing my ecu. I DONT WANT TO BRICK MY ECU. Ive been flashing roms to my android devices so i have a bit of experiance in the art but have never flashed a map to an ecu before.
Im having a rough time finding good instructions on exactly what i have to do to flash the maps as well. If someone could give me an updated step by step process on the flashing procedure it would be incredible, or perhaps a link to an accurate description. As of right now i'm trying to do all the research i can to make sure i dont brick my ecu any tips / useful anecdotes ect are GREATLY appreciated. Thanks in advance!
gfv355 is offline   Reply With Quote
Old 04-11-2013, 01:53 PM   #2
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
Everything works good in Windows 7. If you look at the sticky for the OS tuning tools, it has everything you need to get started. Bricking your ecu really only happens if you are super unlucky(memory failure) or things come unplugged in the middle of flashing.
endrswrd is offline   Reply With Quote
Old 04-11-2013, 03:11 PM   #3
masayver
Member#: 176021
2011 Impreza WRX
Lighting Red
I have used the tactrix and ecuflash just fine in winxp 32-bit, win 7 32 and 64 bit, and win 8 64-bit. Make sure to use the latest version of ecuflash and read up on the stickies on nasioc. It's a bit scary the first time but once you do it, it's really very simple.
masayver is offline   Reply With Quote
Old 04-11-2013, 03:39 PM   #4
ogboot
Member#: 170906
psm
Been using it with win7 64bit for years with no issue. I just wish there was an ecuflash and learning view for linux, then I could do everything from my netbook.
ogboot is offline   Reply With Quote
Old 04-17-2013, 08:35 PM   #5
mikeyPSF
Member#: 236475
You'd be hard pressed to find a better set of instructions than this set of videos:
http://www.youtube.com/playlist?list=PL13C9F1BF5C03E946
One important thing to understand is that if you run in to a problem where you're interrupted mid-flash (USB unplugs, laptop goes to sleep, etc.) you can always restart the process again as long as you don't turn the car off. If you have a problem with the flash and you turn the key off, you've just bricked your ECU. If your laptop powers down because of low battery, as long as you leave the key on (with a battery charger if it's a long time period) you could come back the next day and resume the process.
There are some issues with Vista that have to do with the unusual way that Windows setup the security certificates but that will be fixed in a release coming out soon.
mikeyPSF is offline   Reply With Quote
Old 04-23-2013, 02:21 AM   #6
eeyuhc
Member#: 312339
'14 BRZ
CBS
eeyuhc is offline   Reply With Quote
Old 04-23-2013, 09:33 AM   #7
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
If this was reddit you would get an upvote for good information. I forgot to add this to post up top. This is crucial for those that do end up making a mistake.
Old 05-01-2013, 02:20 PM   #8
xBlaze89x
Member#: 355156
Vista user here- I had no problems with the tactrix 2.0, ecuflash, and romraider.
xBlaze89x is offline   Reply With Quote
Old 05-01-2013, 06:18 PM   #9
gfv355
Member#: 330335
02 wrx, stage 2
Awesome!, very great information i really appreciate it. That deserves to be on a sticky somewhere
