Welcome to the North American Subaru Impreza Owners Club Monday December 29, 2014
Old 04-16-2013, 11:35 AM   #26
AkumaMotorsports
Member#: 214570
Originally Posted by Slimsti View Post
Can't wait to see what it does with pure e85 not this e60-e70 mix u have going and getting a little more aggressive on the tune. There A lot left on the table with that e85 tune.
I would not say there is much more HP to be had up top. Keep in mind, we can only achieve power up to MBT with timing(which we are very close). The turbo is a limiting factor here...need a bigger one to really make some noise. The AFR will yield a bit more power up top though.
I agree, we can get a bit more Torque if he want to really stretch out the stock turbo. He will need an aftermarket MAP sensor to keep the boost in check. We could try and shoot for 3 more PSI, but we will still see a good taper...no fighting physics there
It really comes down to the owner. If he wants to max it out, I am all for it. I am 90% sure he wants a reliable DD in the 20PSI range for longevity reasons. Eithert way, we will support his set up 100%.
Thanks guys!
John
AkumaMotorsports is offline   Reply With Quote
Old 04-16-2013, 04:59 PM   #27
rswagon609
Member#: 212048
2011 wrx
John is right, I asked for a nice safe tune around 20 psi. I would like to be able to drive the car without worrying about breaking anything. I'm sure ill be bitten by the 'more power bug' again, and when that time comes ill get a bigger turbo. For now, I'm happy with my new power. I hope to get the car down to the track next week. Ill be sure to let everyone know how I do!
rswagon609 is offline   Reply With Quote
Old 04-16-2013, 11:00 PM   #28
AkumaMotorsports
Member#: 214570
rswagon609,
Glad you are happy with the power and tune! Customer satisfaction is #1 @ Akuma!
-Dave
Old 04-16-2013, 11:49 PM   #29
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I've just read through this thread and it sounds like it's safe yet making good power! I'm curious why you didn't just drain the tank of the pump gas using the firewall connections and then fill it with E85 and tune to that?
Old 04-17-2013, 12:18 PM   #30
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Id assume because in reality if your switching back and forth from pump gas to e85 this is a more realistic way to just get the pump gas tank really low and then add in the E. Hes not gonna want to have to empty the tank through the firewall EVERY time he wants to switch maps and gases. This way his tune will match exactly what is in the tank. Im just guessing though. Thats what i would do myself.
Slimsti is offline   Reply With Quote
Old 04-17-2013, 12:28 PM   #31
manitou
Member#: 193757
2006 XTI Limited
Id assume because in reality if your switching back and forth from pump gas to e85 this is a more realistic to just get the pump gas tank really low and then add in the E. Hes not gonna want to have to empty the tank through the firewall EVERY time he wants to switch maps and gases. This way his tune will match exactly what is in the tank. Im just guessing though. Thats what i would do myself.
It's not quite as critical going from E85 back to pump gas but it could be more critical going from the pump gas tune to the E85 tune. One way to do it is have a 5 gallon gas container full of E85 and run the car out of 93 pump gas, then empty the E85 into the tank and then re-flash in your E85 map!
A lot of tuners like to empty the pump gas and then put the E85 in before tuning to that fuel. It's probably not as critical if your tuning is more conservative.
Old 04-17-2013, 01:02 PM   #32
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
lancelucas is online now   Reply With Quote
Old 04-17-2013, 01:20 PM   #33
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
We have always run the cars down to a 1/4-1/8th tank or less if possible. then cycle the car in test mode with a hose connected too the fuel return hose under the hood. just let too cycle till it gets close too no fuel is pumped out.
I dont like too let to go till all the fuel is out and the hose is not pumping anything out because i running the pump dry can be good for it.
This should leave less then a 1/4-1/2 gallon left in the system. now put 5-10+ gallons of E85 or what ever your running in and your good too go.
Ian,
rexworx is offline   Reply With Quote
Old 04-17-2013, 01:53 PM   #34
AkumaMotorsports
Member#: 214570
Agreed on all fronts, there are many ways to do this. We did this the simplest way we could and satisfy the client’s needs.
-Dave
Old 04-17-2013, 01:55 PM   #35
manitou
Member#: 193757
2006 XTI Limited
Agreed, pretty much what I was saying, I did not mean run it dry, I just did not explain myself very well!
Old 04-17-2013, 01:58 PM   #36
rexworx
Member#: 103232
Yep, thats what I assumed.
Old 06-05-2013, 11:57 PM   #37
rswagon609
Member#: 212048
2011 wrx
So I finally got to the racetrack tonight. The weather was great and there was a ton of cars so I only got 2 passes in. On the first one I left the launch control on by accident and ended up running a 12.89@109. On my second pass I got off the line much better and ran a 12.38 at 111.43.
Old 09-07-2013, 12:29 PM   #38
AkumaMotorsports
Member#: 214570
Nice, hope all is still well with the car and everything is working.
-Dave
Old 11-24-2013, 10:54 PM   #39
BigTaco425
Member#: 347237
2013 WRX Limited E85
Satin Black Vinyl
My tuner installed two fuel drain maps on my Cobb AP. Also provided access to the fuel return line for me to connect a drain hose. Map runs the fuel pump 100% on idle.
Just switched from E85 to pump gas for the winter. Connected the drain hose. Switched to drain map. Idled car until fuel drain sputtered. Stopped engine. Switched map to pump. Added pump gas. Done!
Not too bad.
BigTaco425 is offline   Reply With Quote
Old 11-30-2013, 02:07 PM   #40
scaryjello
Member#: 359987
2013 Subaru WRX
This is awesome. Something that's not too crazy and is still fast. I plan on going this same route someday after my warranty is expired
scaryjello is offline   Reply With Quote
Old 12-07-2013, 02:57 AM   #41
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
Not too bad.
that's a very cool idea! How quickly does it empty out the return line from say 1/4 tank ish?
SenorDucK is offline   Reply With Quote
Old 12-08-2013, 12:53 PM   #42
BigTaco425
Member#: 347237
Satin Black Vinyl
It's mostly about the convenience. 1/4 tank would probably be 7-10 minutes.
