Old 04-12-2013, 01:08 AM   #1
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Default Boosted Tuning Road Tune (SD testing) - '06 STI/PTE6766 on 91oct & E85
Event: Road Tune
Ambient Temp: 77*
Elevation: 200ft
Tires: 255/40/17
Car: 06 STI
Tuner: Jay @ Boosted Tuning (www.boostedtuning.com)
Dyno Info: Virtual Dyno
Transmission: Stock 6sp
Gear: 4th
Peak HP: 428hp (91oct) 535hp (E85)
Peak Torque: 362tq (91oct) 440tq (E85)
Baseline hp/tq for a stock on same dyno: 240/240
Target Boost: 20psi (91oct) 28psi (E85)
Target AFR: 11.3-11.1 (91oct) 11.6-11.5 (E85)
Fuel: 91oct/E85
Engine/Power Modifications:
-Motor Built by Owner
-Cosworth Pistons
-Crower I beams Rods
-STI Factory Crank
-King Bearings
-Stock STI headgaskets with ARP studs
-JDM 12mm oil pump
-Stock Heads P&P by Owner
-Supertech valves
-Supertech dual valve springs
-Cosworth 278/274 cams
-Perrin v2 Rotated kit - PTE 6766
-Perrin FMIC
-Perrin CAI
-Ported TGVs & Throttle body
-Tial BOV
-Agency Power Headers
-Invidia G200 Catback
-DW 1300cc Injectors
We finally got some time to test the 32-bit SD ROM. Car was great on SD, a lot better then the blow-thou that was on it. We didnt push either tune. Car will be back in a few days for more tuning.
91oct
E85
Boosted Tuning is offline   Reply With Quote
Old 04-12-2013, 03:27 AM   #2
morgankwright26
Member#: 344891
2003 Impreza WRX
There we go buddy! Better keep coming out to the club with that monster(:
morgankwright26 is offline   Reply With Quote
Old 04-12-2013, 07:05 AM   #3
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Is the turbo ball bearing? What is the AR?
Looks good!
Old 04-12-2013, 07:52 AM   #4
STi MAN86
Member#: 287906
2006 STi
Would love to try the SD on my 06STi ADM
STi MAN86 is offline   Reply With Quote
Old 04-12-2013, 09:28 AM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What is holding you back from going for more? Are you out of fuel with the 1300's? Is this power what you'd expect from this setup? I think I would have expected a little more with this turbo and those cams.
I know you guys are pretty well versed in Virtual Dyno, so I don't suspect any data entry issues (and the plots look very consistent). It just seems power is a bit on the low side for a 67mm turbo at 28psi. But I'm looking forward to seeing it turned up!
I do have to say I'm impressed by the spool on this turbo with the 06 STI short gearing! I love seeing all the people going with bigger setups this year. A couple years ago it seemed like 500-600+WHP was pretty rare, and now more and more people are doing it.
xluben is offline   Reply With Quote
Old 04-12-2013, 09:32 AM   #6
juanmedina
Member#: 133146
I agree 20psi by 4500rpm from a 67mm turbo is really good.
Old 04-12-2013, 03:38 PM   #7
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
We were just testing the SD ROM, so we didnt totally push it. Also we started to get some spark blow out, so the owner is throwing in new plugs with a smaller gap. We're hoping to hit 600hp when we play with the car again today or tomorrow.
Old 04-12-2013, 04:01 PM   #8
juanmedina
Member#: 133146
Looks good!
Old 04-12-2013, 06:11 PM   #9
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
spool looks more like a 6266 as does the power,something doesn't seem right.At 20 psi even on 91 should be higher with the amount of air the 6766 can move and should be way over 600 at 28 psi on e85.Not trying to knock this car just pointing out something doesn't seem right on the setup somewhere.
john 1badSTI is offline   Reply With Quote
Old 04-12-2013, 06:30 PM   #10
juanmedina
Member#: 133146
Maybe precision put the wrong compressor wheel
Old 04-12-2013, 06:40 PM   #11
john 1badSTI
Member#: 77470
^^^Anything is possible,it wouldn't hurt to measure both comp. and turbine wheels just to be sure.
Old 04-12-2013, 07:25 PM   #12
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That is what I was getting at. Compared to my car it is making about the same power vs. boost but it is spooling 1000rpm slower. Main differences are that I have a 6266, stock cams, and the longer 4th gear. I am looking forward to seeing what it does with higher boost. Hopefully the top end really comes up!
Old 04-12-2013, 08:59 PM   #13
john 1badSTI
Member#: 77470
but my point is with an efficient setup, with THAT turbo(same as xdrian's iirc)it should be making at least 500whp at 20-21 psi even on 91 and a whole lot more on e85.Pushing more boost to get where smaller turbos(gtx35r/6266) means there is a restriction of airflow somewhere.Just my observation.
Old 04-12-2013, 10:52 PM   #14
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, spooling a bit slower on a larger turbo with larger cams is expected. I would just expect to see an extra 50-100 WHP more to go along with it. I'm very curious to see what it will do with more boost.
Old 04-13-2013, 02:47 AM   #15
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
We had this car in today and found that the head gasket was leaking coolant into the cambers, so that was probably why the power was lower then it should have been. The APR studs were only tq'd to 90/ft. New gaskets and new studs going in soon.
Also, like said, the tune (timing) was real conservative.
juanmedina, Its a JB turbo and has a .81 hotside (according to owner).
Old 04-13-2013, 12:37 PM   #16
john 1badSTI
Member#: 77470
^^^thats why the spool might be better,that seems like a small hotside for a big turbo and could be choking it up top causing excessive backpressure.
Old 04-14-2013, 05:36 AM   #17
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Standard ARP's only get torqued to 90.
Sounds like an issue of surfaces or something else.
project_skyline is offline   Reply With Quote
Old 04-14-2013, 10:06 AM   #18
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
True the spec is only 90 tq, but most do them to 100-115 tq.
Also, a surface issue is very possible, as I think the motor was just slapped together.
Old 04-14-2013, 10:26 AM   #19
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I hope the higher tq helps you guys out but honestly if 90 didnt do it I forsee more issues. Might want to try the 625's/l19's
stretchedk7 is offline   Reply With Quote
Old 04-14-2013, 02:16 PM   #20
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
That or improperly torqued during assembly. For a turbo like that though I'd just step up to 625's or L19's.
Good work on the tune though jay.
Old 04-14-2013, 05:14 PM   #21
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Yeah, Im pretty sure the owner is putting in 625s or L19s this time around.
Thanks.
Old 04-15-2013, 11:09 AM   #22
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Get the surfaces redone. We where in std ARPs and running 34psi on a 6766 on E85. At the limits here. But the 625 studs are a great choice.
FuJi K is offline   Reply With Quote
Old 04-15-2013, 12:38 PM   #23
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
yep ^^. thats why i made that statement! them thinking more tq will fix the problem might cause more head aches then its worth!! i say resurface and then 625's. never another issue
Old 04-30-2013, 09:32 AM   #24
06TRDude
Member#: 130666
2006 WRX STI
what were the studs torqued to on that 34 psi beast? lol inside have more torque as well?
06TRDude is offline   Reply With Quote
Old 05-02-2013, 10:21 AM   #25
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Iirc, they where 90 outside, 95 middle.
