Old 06-03-2013, 09:36 PM   #51
Schlanseay
Member#: 340978
2013 13 WRX Hatch
Wondering if the Op or anyone else can help me out. I have the same exact setup as the Op but I can't enter remapping mode.
Axxess instructions say to hold the Volume Up button for at least 20 Seconds and the Led will turn red. Mine turns green and never becomes red.
Also when first auto reading everything the axxess reads my pick up and hangup as the LED goes out after 3 seconds but the buttons do nothing when in radio mode or any mode.
Schlanseay is offline   Reply With Quote
Old 06-03-2013, 10:03 PM   #52
foolycooly
Member#: 260545
2011 WRX Limited 4dr
iirc i ran into the same issue w/ the 20 second hold. I just performed a hard reset (using that tiny button) and i believe it went into program mode from there.
foolycooly is offline   Reply With Quote
Old 06-03-2013, 10:57 PM   #53
Schlanseay
Member#: 340978
2013 13 WRX Hatch
So you programmed everything manually?
Old 06-04-2013, 07:40 AM   #54
foolycooly
Member#: 260545
Yes...needed to to reprogram the 3 bluetooth buttons since they were set to preset up/down/mute all.
Old 06-04-2013, 07:44 AM   #55
Schlanseay
Member#: 340978
2013 13 WRX Hatch
Mine right now won't even preset up and down.
Old 06-04-2013, 07:48 AM   #56
foolycooly
Member#: 260545
I would try a hard reset and manual programming of all the buttons. There's a list in the ASWC instruction booklet with the correct order (skip non-applicable buttons).
Old 06-04-2013, 08:00 AM   #57
Schlanseay
Member#: 340978
2013 13 WRX Hatch
I'll try that today, thanks for the advice!
Old 06-04-2013, 09:33 AM   #58
Schlanseay
Member#: 340978
2013 13 WRX Hatch
gave it a shot and no dice. Still has a solid Green LED. Talked to Axxess and they said that I "need" to tap into the factory harness and not SVXDC's, I don't buy it.
Old 06-04-2013, 10:05 AM   #59
Schlanseay
Member#: 340978
2013 13 WRX Hatch
I have contacted Axxess and they claim I can't have the module connected to your harness and is has to be directly connected to the vehicle, however People on NASIOC have had success.
Issues:
I can't the the ASWC-1 to get into program mode
When I hold the Volume Up button for at least 20 seconds the LED lights up Green not RED as stated in the manual
I thought maybe I'll give it a shot with the GREEN LED instead of the red. I can actually reprogram some buttons to work
The Hook Pickup, Hook End and the PTT on the steering wheel can take on preset scrolling
Cannot reprogram the Mode button on the Steering wheel to do anything but MUTE
When I restart the car after this it goes into AUTO Program mode again.
I tried a Hard reset with the little button, the LED again lights up GREEN not red. What do I do?
Old 06-04-2013, 10:07 AM   #60
Schlanseay
Member#: 340978
2013 13 WRX Hatch
My Wires are ran per David Carters Spec's
ASWC's RED wire to the other RED wires (my harness' and your HU's)
ASWC's BLACK wire to the other BLACK ground wires (my harness' and your HU's)
BROWN/BLACK wire on my 20-pin harness (pin 14) to the other BLACK ground wires (same as above)
ASWC's GREEN/ORANGE wire to the BROWN/RED wire on my 20-pin harness (pin 4)
ASWC's BLACK/GREEN wire to the BROWN/BLUE wire on my 20-pin harness (pin 13)
Old 06-04-2013, 12:34 PM   #61
Schlanseay
Member#: 340978
2013 13 WRX Hatch
Making progress, I Still get the GREEN LED vs said RED LED but I am able to get the buttons to learn. Question, is your MODE button on the steering wheel able to be used to switch modes?
Old 06-10-2013, 10:28 PM   #62
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
My mode switches as it should however I still can't get my phone buttons to work. I never used them much so I quit worrying....for now.
Question for you guys with this or a similar HU. I was told today my bluetooth connection was pretty bad and I couldn't hear them at all. I mounted my Mic in the same spot as the OP. Any suggestions?
Thanks!
jester8798 is offline   Reply With Quote
Old 06-11-2013, 01:59 AM   #63
8crizzle8
Member#: 350064
2013 Impreza Sport
MBP
Yeah I got the green led instead of the red too. I did get my mode button to switch modes. However, occasionally it decides to att instead for whatever reason but mostly works. I couldn't program the buttons to mute or power on/off though.
8crizzle8 is offline   Reply With Quote
Old 06-12-2013, 07:37 AM   #64
zolaman
Member#: 299059
12 WRX hatchback
Originally Posted by Vossatron View Post
You need one of these
http://www.iaperformance.com/product...jbavikvobg5qp5
Also, to install it, you use the metal brackets off the stock unit and not the plastic one used with the stock bezel.
I really like this but....TOO EXPANSIVE.....$96.20 for a din????
zolaman is offline   Reply With Quote
Old 06-12-2013, 09:43 AM   #65
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Any thoughts on the bluetooth guys? I currently have the mic on the left side of the steering column where the OP did his.
Old 06-12-2013, 10:06 AM   #66
Schlanseay
Member#: 340978
2013 13 WRX Hatch
I have mine mounted in the same spot as the op and been told I sound clear. I did kind of tilt it out word as much as I could towards the Window. Not sure if it helped or not.
Old 06-12-2013, 12:24 PM   #67
MacAlert
Member#: 70965
2013 WRX STI
ISM
You could get the bezel off a Forester with Tom Tom navigation for ~$60. The part number for this is 66065SC130.
More info here: http://forums.nasioc.com/forums/show...31&postcount=7.
MacAlert is offline   Reply With Quote
Old 06-12-2013, 02:32 PM   #68
Schlanseay
Member#: 340978
2013 13 WRX Hatch
I got a cheap ebay CD-IU201V cable and plugged into my Compatible iPod touch and I can't get any video to show up. I can here it really muffled but that's it. Anyone else get this to work?
Old 06-12-2013, 05:22 PM   #69
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Huh, I've been told it sounds like the window is open. I guess I'll have to okay with it some more. Also, the volume doesn't turn up very loud for some reason. I could barely hear the person who called me.
Old 06-13-2013, 10:00 AM   #70
Schlanseay
Member#: 340978
2013 13 WRX Hatch
Maybe double check your connections and wiring. My callers are around volume 8 I believe.
Old 06-13-2013, 12:17 PM   #71
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Is the volume level controlled by the normal HU volume or the small bar that pops up when you receive a call on the right side of the screen? I tried turning it up while I was talking but it didn't seem to make much difference.
FWIW, when I tested it sitting in the garage everything was loud and clear. The last call was when I was on the highway but my windows were closed.
Old 06-13-2013, 12:25 PM   #72
foolycooly
Member#: 260545
I was confused about this same thing. It seems to be roughly tied to the normal radio/music volume more than the volume button in the little phone BT menu during a call. Turning that up and down didn't seem to do much for me either.
Old 06-15-2013, 02:44 PM   #73
Apedz215
Member#: 328682
What wire on the svdxc harness would i tap into for the amp remote wire?
Apedz215 is offline   Reply With Quote
Old 06-20-2013, 05:22 PM   #74
BellyUpFish
Member#: 357348
2010 Limited WRX
Does anyone know if the stock Subaru SAT antenna can be used with the head unit?
BellyUpFish is offline   Reply With Quote
Old 07-02-2013, 08:59 AM   #75
emfennell23
Member#: 361175
Default Parking Brake Bypass for AVH-X5500BHS on Chevy Vehicleq
I recently got this system installed in vehicle and looking for best way to bypass parking brake to view DVD while in motion. Do I need to purchase anything additional to accomplish this or can the wiring configuration be altered to get it working??
emfennell23 is offline   Reply With Quote
