Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 04-17-2013, 07:35 AM   #51
scott06sti
Member#: 320340
2006 Subaru STI
light weight pulleys wont help did some research with a dyno the only the light weight pulleys do is lose power, and I drive an 06 sti with complete HKS exhaust, 5 advan wheels one is the spare, crawford front mount intercooler, snow alchohe injection, bigger fuel pump an injectors, and still get 15-22 mpg. All depends on your tune and how you drive
scott06sti is offline   Reply With Quote
Old 04-19-2013, 01:00 AM   #52
pbrules10
Member#: 302995
Ok, so here's the new data log. This was 1st through 4th from 0 to about 55mph.
https://docs.google.com/spreadsheet/...zV1ctV0E#gid=0
pbrules10 is offline   Reply With Quote
Old 04-19-2013, 08:30 AM   #53
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
You need to set your file public on google.
Cathexis is offline   Reply With Quote
Old 04-19-2013, 11:06 AM   #54
pbrules10
Member#: 302995
Sorry about that, fixed it !
Old 04-19-2013, 11:37 AM   #55
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Well that's odd. In your last log AFRLA was pushing hard positive, and had hit +9% by the time you stopped the log. In this one it's hanging out at a constant -2%, which is fine. I see nothing in that log that stands out as a problem. The car was fully up to temp when you took this log, right?
Old 04-19-2013, 12:15 PM   #56
pbrules10
Member#: 302995
Correct full warm up. This was just me easy driving up to highway speeds.
Old 04-19-2013, 09:44 PM   #57
pbrules10
Member#: 302995
Anything?
Old 04-20-2013, 06:28 PM   #58
pbrules10
Member#: 302995
Bumpp
Old 04-22-2013, 05:59 PM   #59
pbrules10
Member#: 302995
Any thoughts on this one guys?
Old 04-22-2013, 06:21 PM   #60
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
if the o2 sensor is faulty you will certainly get a drop in mpg. i had a new bosch (always go with a Denso is what i learned from this) unit go bad within 1 year with less then 15k miles and my mpg was horrendous until i changed it out.
Fierysun is offline   Reply With Quote
Old 04-22-2013, 08:24 PM   #61
MRGierut013
Member#: 328260
2005 STi, 2004 RSX
i-Vtec just kicked in yo!
Originally Posted by pbrules10 View Post
Well if you figure the fuel tank holds approximately 15.9 gallons and on a good fill I get 220 miles out if it (220/15.9) that's about 14 mpgs. Most of the time I get like 200 miles out of the tank so even less then 14 mpgs.
You should only divide by 15.9 if your running the tank dry...
MRGierut013 is offline   Reply With Quote
Old 04-24-2013, 05:56 PM   #62
Fierysun
Member#: 82745
2005 Subaru STI
You should divide total miles by the # of gallons it took to fill up from the last full tank.
I.E. if you went 200 miles and it took 10 gallons to fill up, your mpg would be 20/gal.
Old 04-24-2013, 07:11 PM   #63
MRGierut013
Member#: 328260
2005 STi, 2004 RSX
Yesir.
Old 04-25-2013, 12:21 PM   #64
slowride05
Member#: 321322
2005 sti
i currently am getting about 16 mpg on about 90% city driving. i feel its way too low but my tuner told me that was normal :/. i have changed o2 sensor, cleaned maf, and changed spark plugs and still the same. cars an 05 sti with catless dp, stromung catback and protune.
slowride05 is offline   Reply With Quote
