Old 04-15-2013, 08:25 PM   #1
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
Have a Nice Day? Pros needed.To swap again! Ver9 in a new bugeye shell vs rebuild my ver8
Here's my dilemma-
Over the past 4 years Ive been upgrading my Bugeye. Just finished my final mods before going to get a respray and as luck would have it a family of deer step in and end my fun. Long story short, I swerved to dodge them at 50 mph car spun and hit a wall. The car stalled(or so i thought) and I tried to start her up and heard the fatal noise of valves clashing. Shots rang out shortly after in the direction of the wildlife... ...
I did all the previous work on the bug myself-Version8 longblock swap-rewired for AVCS, tuned, coilovers, brembos etc.
My car has over 200k on the frame. Ive decided that I would rather find another 02-03(bugeye) that needs an engine and swap all my mods over to the new one rather than fix my old ones body.
Should I bother with trying to have the version 8 rebuilt or just part it and get a version 9 to put into the new shell.
Is rebuilding a JDM V8 engine after timing failure worth the risk- Ive been quoted $1500 dollars for a complete forged rebuild from a reputable tuner here in TN.
Its getting hard to find version 8's Id trust and I like the idea of dual AVCS on the 9's. Ive found a ver 9 longblock/ecu/turbo for 3200 shipped.
With a ver9 is the wiring going to be any different than my ver 8 swap was-is ver9 still 16 bit?
02 Scoob-TN is offline   Reply With Quote
Old 04-16-2013, 04:12 PM   #2
25rsti
Member#: 166324
V8 and V9 are identical swaps OTHER than the V9 having an immobilizer. So you would either need EVERYTHING from the V9 car to start it OR find a V9 Spec C (no immobilizer) or run the V9 with a V7 or V8 ecu.
Old 04-16-2013, 10:56 PM   #3
02 Scoob-TN
Member#: 176010
Thanks. Im going to part my ver 8 and old shell and grab this ver 9 spec c. Going to start up the new build soon. Cant wait!
Old 04-17-2013, 07:34 AM   #4
25rsti
Member#: 166324
What's your old shell?
Old 04-17-2013, 05:32 PM   #5
02 Scoob-TN
Member#: 176010
2002 USDM Bugeye JDM Ver 8 Longblock swapped
VF37
Lots more..+Phatbotti Tuned
Relevant info,
18x9 et38 Styluz M575
255/35/ZR18XL...
Fortune Auto 500's+Roller Bearing upgrade Front 9k 14.0" Rear 7k 13.75"
Rear fenders folded flat from 9 to 3 o'clock
Front fenders untouched
2006 Brembo's re-drilled 5x100
Full Energy Bushings
No Spacers
Currently wrecked, Frame is perfect-needs 1k in body work and engine rebuilt due to timing jump.
before crash:
Old 04-18-2013, 09:42 AM   #6
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
What is the roller bearing upgrade?
And +1 for V9, but take a look at my thread, I update it oftenly and just came up with a new thing about V9.
http://forums.nasioc.com/forums/show....php?t=2385141
Old 04-18-2013, 02:29 PM   #7
02 Scoob-TN
Member#: 176010
Its a roller bearing setup for the 500 coilovers up front to allow them to freely turn and never bind under load.
Old 04-18-2013, 04:04 PM   #8
25rsti
Member#: 166324
Do you have after crash pictures?
Old 04-18-2013, 09:40 PM   #9
02 Scoob-TN
Member#: 176010
Ill post some up if i decide to go the sell it route, Im thinking I may just keep it and put the new shell donor's ej205 in it to use as a rally cross car- then no worries if I slide of course, gravel her up, etc..
