Notices
Old 04-16-2013, 12:54 AM   #1
rymaggi
Member#: 253442
Default Input on 4032 Piston for 450whp
Figured changing the name of the thread and OP would be easier than creating a whole new thread, as we have been getting really good info thus far.
So far the motor has been pulled, undressed, and head sent to the machine shop.
Heads looks great, cylinders and pistons looks actually super good as well.
We're looking for input and experiences with Wossner / Mahle 4032 pistons, any input reguarding mileage used, power output achieved, and just overall how you liked them for better or worse.
The car
The car is going to be used 90% of the time as a DD and will see very little auto X / thunder hill runs. Our main goal is to achieve a reliable 400-450whp DD that can take the abuse when i decide to have a little fun.
Build
  • Refreshed heads, set to stock spec
  • Manley H-beam rods
  • Stock Crank
  • Stock Bearings
  • Killer B oil pick up
  • Blouch 20g-XT
  • ID1000's
  • Hallman RX MBC
  • K&N Typhoon Intake
  • Mishimoto x3 core radiator
  • Spearco TMIC
  • APS Equal Length Headers w/ Up-Pipe
  • Stock gaskets
  • Deleted/Gutted TGV's
  • Walboro 255 fuel pump
  • ARP Head studs
  • Gates Timing Belt & Water pump
  • Perrin Inlet
  • Catch can
Off the top of my head i believe for the most part, that covers the majority of the major items being used in this build.
As of right now, the last thing to be purchased is the pistons, which is why we're looking for some feedback on what people have thought about the 4032's for Wossner / Mahle and similar goals.
Car is also going to be seeing E85 99% of the time.
Misc
  • V7 Complete Drivetrain Swap
  • Sedan front end conversion
  • STI control arms
  • 22m F&R sway bars
  • Whiteline HD Endlinks
  • Whiteline ALK kit
  • Whiteline RCA kit
  • BC BR coilovers w/ Swift Springs
  • Exedy 1508HD Clutch Kit
  • AUX Air pump deletes
  • 17x9 +35 Enkei RPF1's
  • 245/40/17 Direzzi Z2's
  • Whiteline Steering rack bushings
For fun pictures
rymaggi is offline   Reply With Quote
Old 04-16-2013, 12:59 AM   #2
StIGC11
Member#: 346106
2006 SGM BW88-75
E85
It all comes down to the engine builder. I run CP pistons with no coating and they are quiet. Before I had wiesco's with coatings and they were much louder but the engine was built by someone else.... I would give MPS a call (maxwell power service) or getadomtune talk to Dom.
StIGC11 is offline   Reply With Quote
Old 04-16-2013, 01:29 AM   #3
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Any forged piston will be a bit louder on cold start. PTW clearances play a role in how quite the motor ends up being. A piston with an offset is going to give you more side wall loading which will equate to a quiter piston. Subaru uses a offset stock bore piston in the OEM block but is cast therefore doesn't grow as much as a forged 2618 piston will.
Let me know if I can help you out at all.
I prefer Manley pistons for daily driver built motors. I run CPs in my cars but I drive like a jerk off, and my WRX isn't daily driven.
Flat 4 Motorsport is offline   Reply With Quote
Old 04-16-2013, 01:42 AM   #4
rymaggi
Member#: 253442
I will defiantly reach out to them for some additional advice in which to choose.
I am leaning towards the CP drop in's.
My builder pretty much told me to do a little research as to which forged pistons will do the least expanding, as new pistons come out all the time and people are different results with X mixed with Y and used with Z etc.
Old 04-16-2013, 01:44 AM   #5
rymaggi
Member#: 253442
Yea, I defiantly understand that running forged pistons will be a little louder than normal. Just trying to tone it down as much as possible.
Question "A piston with an offset is going to give you more side wall loading which will equate to a quiter piston."
What do u mean by offset and side wall loading.
Old 04-16-2013, 08:49 AM   #6
RemlapaN
Member#: 58251
2004 Sti
GT35R 530whp @ 27psi
The wrist pin is offset in the piston a very very small amount (millimeters) so that as the crank rotates, the offset drives the piston into the cylinder wall.
This little bit of side-loading on the piston can help reduce how much it rattles in the bore.
RemlapaN is offline   Reply With Quote
Old 04-16-2013, 12:08 PM   #7
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
stock ftw
Zackbo is offline   Reply With Quote
Old 04-16-2013, 01:33 PM   #8
rymaggi
Member#: 253442
Originally Posted by Zackbo View Post
stock ftw
Well, obviously.
Old 04-16-2013, 05:27 PM   #9
BlackHole
Member#: 85525
05 LGT Wagon 5MT
ABP
Originally Posted by rymaggi View Post
Things i plan on buying for the refresh/rebuild
- H-Beam Forged Rods (Kinda 50/50)
- STI Nitrated Crank (50/50 Also)
- 11mm STI Oil Pump
I vote for a good set of H-beams (like Manley H-tuff) or resize the stock rods with ARP bolts as insurance.
I vote against replacing the crank - stock crank is plenty strong, no need to replace unless it is bad.
And I definitely vote against the 11mm oil pump unless you build for it since otherwise it will bypass too much oil, overheating it.
Just my $.02...
Kyle "BlackHole"
BlackHole is offline   Reply With Quote
Old 04-16-2013, 08:57 PM   #10
ROFLBOXER
Member#: 188503
2003 Built EJ257 WRX
2.5xtr+W2A IC
My builder recommended wisecos for a dd 20g build. Slightly lighter than others, and except for startup in freezing temps they've been nice and quiet.
ROFLBOXER is offline   Reply With Quote
Old 04-16-2013, 10:19 PM   #11
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
not a fan of Wiseco's they have way too many failure on Subaru's that I've seen.
Too short of a skirt IMO
Here's a pic I stole from RexFTW (Brian) he had four cracked Wiseco's.
I have only seen ONCE, a cracked ringland on a CP piston and someone has it as a Subaru Shootout trophy.
Old 04-16-2013, 11:34 PM   #12
rymaggi
Member#: 253442
Just my $.02...
Kyle "BlackHole"
Thanks for your info.
Tuner/builder did say the sticker would be just fine. I've just read through so many threads and everyone seems to be using them.
Same with oil pump.
I'm kinda leaning towards the CP's. seems from everything I have read they very reliable.
Old 04-16-2013, 11:36 PM   #13
rymaggi
Member#: 253442
Thanks for that insight. I will defiantly stead clear of wiseco's.
I'm trying to keep my build basic/reliable without "cutting" corners with stuff that isn't necessary, but at the same time not cutting to many corners to only have it pop with 400whp running through it.
Old 04-17-2013, 09:00 AM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
IMO it really depends on the build, builder preferences, and application.
FWIW trying the new Manley pistons and new H-rods on our latest build. Had Swain Tech apply the skirt coating and ceramic top coating. Engine is sleeved, will see LOTS of (product development) dyno time with street and track time as well.
Will let you know how it turns out if/when she pops.
Previous engine had the older style Manley pistons and H-rods. Pistons came with the coating already on them from Manley. They were clack clack clack loud until she got really hot, which I'll take any day over the black death.
KillerBMotorsport is offline   Reply With Quote
Old 04-17-2013, 10:30 AM   #15
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Thief! My photobucket!
But yeah, all four of my Wisecos on my 2.1 stroker cracked in the exact same spot on both sides of the piston.
RexFTW is offline   Reply With Quote
Old 04-17-2013, 02:46 PM   #16
rymaggi
Member#: 253442
Will piston coating be any issue if I'm going to just hone the cylinders and use CP drop ins?
Old 04-17-2013, 03:09 PM   #17
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Going to have to measure ptw still. I would wait to hone the cylinder until you have the piston coated.
I can usually have my coater add .002 when he goes on the thicker side.
Measuring is you friend.
Old 04-17-2013, 05:32 PM   #18
rymaggi
Member#: 253442
Gotcha. I was just gonna have CP do the coating when I order them. Or do you recommend a 3rd party doing it.
Old 04-17-2013, 07:31 PM   #19
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
3rd party, the screened on skirt coating is crap.
I wouldn't waste the $25 per piston or whatever it was.
PM me, and I can give you pricing for skirts and domes.
-Phil
Old 04-18-2013, 12:37 PM   #20
gfx2043
Member#: 205174
For 400whp in a DD that you want to go alot of miles before a rebuild go with 4032 psitons. 4032 was specificly designed for that type of application. Only problem is if you get addicted to power and want 500+ I would start to worry about the 4032 pistons.
gfx2043 is offline   Reply With Quote
Old 04-18-2013, 03:19 PM   #21
Xcrave
Member#: 351592
1999 RSTI Ver. 6
I have Mahle pistons and they work pretty fine. Not much piston slap.
Xcrave is offline   Reply With Quote
Old 04-19-2013, 09:58 AM   #22
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
-Phil
Phil, what is the average turn around time? "ballpark"
Thanks,
Ian,
rexworx is offline   Reply With Quote
Old 04-19-2013, 10:05 AM   #23
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Thanks,
Ian,
depends how busy they are, I usually get my stuff back in a week, just all depends. It's been two weeks at times.
There's only one guy who sprays (the owner) he makes sure quality is number one.
They spend a lot of time on the prep work too. They tape off very evenly, on new stuff obviously it's easier on new parts put they still take their time on masking off the wrist pin holes, ringlands ect.
-Phil
Old 04-19-2013, 12:16 PM   #24
rexworx
Member#: 103232
Ok thank you.
Old 04-19-2013, 12:23 PM   #25
littlewhitewagon
Member#: 103068
11 STI sedan
As everyone knowledgeable has already said, PTW clearance is what makes the slap. For reference, I have Manley pistons and rods in mine and it is decently quiet. Although it's been relatively warm in LA, it sounds stock.
littlewhitewagon is offline   Reply With Quote
