Old 04-16-2013, 04:57 PM   #1
Zhahn11
Member#: 335671
2004 Impreza WRX STI
Default Car won't start!
Just had my motor rebuilt 3 weeks ago. I have fp Green 20g turbo
1000cc injectors, invidia turbo back. Car has been running fine until today. I was driving when it just died. No warning nothing. I wasn't getting into it at all. It will crank over but won't start. I was wondering if It was maybe flooded or something. Anybody ever have this problem? It's an 04 sti by the way.
Zhahn11 is offline   Reply With Quote
Old 04-16-2013, 06:12 PM   #2
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
Check your cam sensor electrical connectors. I've seen them come disconnected and cause that issue.
ckyguy68 is offline   Reply With Quote
Old 04-16-2013, 06:48 PM   #3
Zhahn11
Member#: 335671
Okay thanks!
Old 04-17-2013, 01:43 PM   #4
Zhahn11
Member#: 335671
Well the crank and cam sensors are all good. I checked all sensors I could see and everything is ok. Any other ideas??
Old 04-17-2013, 02:33 PM   #5
Scooby-ohses
Member#: 187707
06 Impreza wrx
obsidian black
check cels first, then pwr to main relay, ecu, and grounds accordingly .
Scooby-ohses is offline   Reply With Quote
Old 04-18-2013, 05:45 PM   #6
Zhahn11
Member#: 335671
So it's deffinately a fuel problem. I sprayed a little starting fluid and it started right up then died. I checked the fuel pump and it's fine considering its a new walbro 255 with 3k miles. I checked the passenger side relay behind the kick panel and it's fine to. Any other ideas!!?
Old 04-18-2013, 07:53 PM   #7
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
sbf-5 relay in engine compartment
Old 04-19-2013, 01:46 PM   #8
Zhahn11
Member#: 335671
Any hint to where at in the engine compartment
Old 04-21-2013, 10:42 PM   #9
DatSwagKid
Member#: 354183
Are you out of gas?
DatSwagKid is offline   Reply With Quote
Old 04-22-2013, 12:08 PM   #10
Zhahn11
Member#: 335671
No. Lol. 3/4 tank
Old 04-23-2013, 11:27 AM   #11
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
When you cycle the key on, do you here the fuel pump cycle for a couple seconds? Pull the fuel feed line to the rail and cycle the pump. If fuel barely comes out you have an issue. A good fuel pressure tester works great also.
fastblueufo is offline   Reply With Quote
Old 04-23-2013, 08:54 PM   #12
ringlander
Member#: 336100
2011 sti
What do you mean when you say the FP is fine. Did you verify pressure or just hear it prime?
ringlander is offline   Reply With Quote
Old 04-26-2013, 10:56 AM   #13
Zhahn11
Member#: 335671
Again about the pump. There is power going to the pump but is not priming anymore. It's a new walbro with 3k miles. I figured that's the problem.
Old 04-26-2013, 10:57 AM   #14
Zhahn11
Member#: 335671
I also did pull the feed line to the rails and turned it over and no fuel whatso ever came out.
Old 04-26-2013, 12:13 PM   #15
ringlander
Member#: 336100
2011 sti
Just make sure you have ground. If you have power and ground I would say you have found your problem.
Old 04-26-2013, 03:33 PM   #16
04wrx008
Member#: 261447
2004 Impreza WRX
If you pulled the feed line (connects to your fuel filter, from fuel rails) most likely you should have had fuel spray out, or at least a little fuel (Built up fuel pressure). If not, then it is most likely your fuel pump. Try checking the connection between the actual pump unit, and the hose that runs down to the end filter. I had mine wiggle loose on me once, and it gave the same issue. (You can hear the pump prime, but still no fuel pressure)
04wrx008 is offline   Reply With Quote
