Notices
Old 04-16-2013, 10:44 PM   #1
dukefan20019
Member#: 291992
2006 Wrx ej257
Rally blue
Default How much power with my swap?
So I just swapped my 06 Wrx engine for an 06 ej257. And my main question is how much power should I expect to be making with the following mods: ej257, sti intercooler, rfl bov, vf39 that likes to push 25 psi in 3,4,5 (I gotta fix this I know), aem ebc, 8mm spacers, gates racing belts, lightweight perrin pully, turbo inlet pipe, short ram intake, stock sti headers and up pipe, 4 inch clear down pipe, 3 inch mid pipe, Perrin dual tube out the rear, 255 pump, 750 dw injectors, open source tune from precision (tuned for Wrx engine). Obviously I'm going to have to do something about this 5 speed glass box and get a tune. But I'm just curious at what power the car is making with these mods since its going to be months till I'm able to hit the dyno. Anyone have a ball park figure? Thanks.
dukefan20019 is offline   Reply With Quote
Old 04-18-2013, 03:33 PM   #2
Xcrave
Member#: 351592
1999 RSTI Ver. 6
Honestly, not much more than stock. Till you get a tune though, no one can really just tell you what you'll be making. BOV will just shorten the **** out of your turbo and 25 psi on your bone stock internals isn't going to make your engine last for very long. Most of the mods listed are for prepping your engine for future internal upgrades. Like DW injectors, 255lph FP, spacers, belt, pully, intake, stock sti ****, etc... isn't honestly going to do **** for power. It'll help your engine for the future, but no power gains.
Xcrave is offline   Reply With Quote
Old 04-18-2013, 03:46 PM   #3
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
The same mods on an EJ255 vs. a 257 will yield virtually identical numbers.
The heads have different chambering, and I've heard said the 257 heads might be good for a little more tq. But nothing significant.
Dave D. is offline   Reply With Quote
Old 04-18-2013, 04:04 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Whatever STi's make with bolt-ons is what you'll make. It's a vf39....
FuJi K is offline   Reply With Quote
Old 04-20-2013, 04:32 PM   #5
mikeydrives1
Member#: 262117
VF39?
With proper tune, your looking at probably around 285hp and 300 torque on a mustang dyno. As for 25psi, your wasting your time on pump gas. After 21psi, those smaller turbos are past their efficiency and blowing hot-air into the motor and not making more power. With hot air coming in like that, it will increase your chances of knocking and the ecu (hopefully) pulling timing.
Your best bet is to run a lower boost, say, 19 psi, allowing a more aggressive use of timing advance to give you that initial thrust feeling of torque as boost kicks in.
mikeydrives1 is offline   Reply With Quote
