Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 04-17-2013, 09:41 PM   #1
AkumaMotorsports
Member#: 214570
Default AkumaMotorsports tuned 08 STI w/HSF-3 aquamist Meth!
Event: Dyno Tune
2-Amboy Avenue
Woodbridge NJ
07095
Weather: 69F, partly sunny
Elevation: Sea Level
Dyno: Mustang AWD 500
Tuner: John Schafer
Relevant Modifications: Stage-2, Perrin Intake, Invidia Catted DP, OEM TMIC, Tsudo CBE, DW65C FP, Aquamist HSF-3 Meth. Kit
Transmission: Stock 6-speed, ACT HDSS Clutch, Clutchmasters 19lb Flywheel
Gear: 4 th
Fuel: 93 octane pump
Engine Management: Cobb Accessport (Akuma Calibrated)
Numbers: 292 whp / 331 wtq.
272 whp / 290 wtq.
Background / Information: Great customer with Stage-2 modifications and Aquamist HSF-3 kit installed by AkumaMotorsports. Comparison pull in sport and sport-sharp mode. The good ole VF-48 putting up some great numbers, more tuning and tweaks to come on this one.
Thanks all,
-Dave
AkumaMotorsports is offline   Reply With Quote
Old 04-18-2013, 02:35 PM   #2
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Looking good! Heartbreaker dyno for sure
k04sti is offline   Reply With Quote
Old 04-18-2013, 07:32 PM   #3
AkumaMotorsports
Member#: 214570
It is, but he has a nice solid tune!
-Dave
Old 04-18-2013, 09:08 PM   #4
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
So basically a car on ur dyno needs meth to hit less than typical stage 2 numbers? That really does read super low, lol. My god. That tune looks super smooth and the power delivery looks great. I bet its a blast. I love my aquamist kit. 50k with it and not 1 issues. I don't understand why people get so put off by meth. It's safe,makes power and pretty much makes ur car run safer. Good job guys
Slimsti is offline   Reply With Quote
Old 04-18-2013, 10:08 PM   #5
AkumaMotorsports
Member#: 214570
Thank you, Meth sometimes gets a bad rap because some of the lesser advanced kits out there (we all know what they are). That said we have numerous cars running the Aquamist kits with zero issues whatsoever.
The stage-2 numbers are just that, numbers. We have some cars that do read higher than others, something we do see time to time. We use our Mustang 500 AWD dyno as a tuning tool. There are numerous posts from our industry friends with other dyno manufacturers that have commented on the differences between the Mustang and various others in the area.
We have a little more tweaking to do with this client.
The dyno day should put all the dyno results numbers to bed with the community and forum members. We cant wait to get all the tristate area members out to the Dyno Day. Akuma is really looking forward to meeting everyone!
-Dave
Old 04-18-2013, 11:35 PM   #6
AkumaMotorsports
Member#: 214570
Some cars give you a bit more than others. There is no black magic, it is a STG2 car. The car still has a stock MAP sensor, so I am only running 21PSI peak. If we switch to an AEM 3 BAR, I can offer the customer to run 23PSI peak and then taper off. He also only wants to run a 50/50 mix by volume. This set up is designed to add a margin of safety, not necessarily break HP records. The customer races this car, and the added cooling and detonation suppression were the primary objectives. The added power is really just gravy in this particular build.
Also, judging by the numbers in your signature(by your name), your car might make 350-360 on our dyno...maybe. Why don't you bring it by and find out...
John
Old 04-19-2013, 11:33 AM   #7
Slimsti
Member#: 155696
John
Oh i bet it would.lol Id be THRILLED to make 350 on your dyno. Numbers are just numbers though. I dont really pay much mind to them. Running the meth as less of a power adder and more of a saftey net is the way to go. Thats exactly what im using mine for. Id much Rather make 20-30whp less and have a really safe tune that'll last then push it with meth and aggressive boost and afr and have it last 30-40k. Building a block is not a fun time.
Also, im not sure if my first post about this car needs meth to make less than typical stage 2 numbers came off as a "knock" or a "Insult" cause i certainly didnt mean it like that. I was just shocked how low your dyno really does read.
Old 04-19-2013, 02:16 PM   #8
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
John any reason you don't like to use the OEM 3bar that comes with the 08+ cars?
Junior2JZ is offline   Reply With Quote
Old 04-20-2013, 05:53 PM   #9
AkumaMotorsports
Member#: 214570
Junior,
I actually think John was referring to the AEM 3.5 bar MAP sensor in order to read the higher boost levels accurately.
-Dave
Old 04-21-2013, 08:55 PM   #10
Slimsti
Member#: 155696
3 bar is good to 43 psi?
Old 04-21-2013, 11:07 PM   #11
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
3 bar should be good to ~28 psi of boost or ~43 psi absolute.
bswilmington is offline   Reply With Quote
