Old 04-17-2013, 11:35 PM   #1
jdogma
Member#: 242350
2013 Carma Wolf EZ30
black
Default Subaru EZ 30R mid engined track day car
I have really enjoyed reading on this forum and have learned a lot due to my prior ignorance about Subarus. I have been building a mid-engined, open 2 seat track day/road car for use as a fair weather sports car and club racer. It is designed to use a WRX engine with a 5 speed WRX gearbox.
some specs:
Wheelbase - 102.5 in.
OAL - 172 in.
OAW - 79 in
Height - 43 in (top of rollbar)
weight - 1660 lb 40/60 F/R%
Engine - 2007 EZ 30R from a Tribeca, 8.5:1 Supertech Pistons
Transaxle - 2008 WRX
Engine Management - Hydra
Turbo - Forced performance FP HTA GT3582R
Suspension - unequal length A-Arms, front; 5 link rear Len Terry type rear.
Spring/shocks - Niprotek Nitrogen gas springs w/ 5 way damping and infinitely adjustable spring rate.
Tires - Hoosier R6 205/45-16 front; 275/45-16 rear
body - carbon fiber with Nomex honeycomb core
I have built other mid engined high performance cars (my old company was Evans Automobiles), mostly Chevrolet powered, but wanted to do an open 2 seat car using a FWD engine/trans combo to make it affordable and to take advantage of the import tuner aftermarket that we have. https://plus.google.com/photos/10818...842?banner=pwa
The reason for choosing the Subaru drivetrain are the low engine and the longitudinal layout. I thought Honda or Mitsubishi (really wanted that paddle shift) initially, but the engine requires that the rear bodywork has to be pretty high (ugly). Also, both engines are almost directly over the axle, which is less than ideal for a mid-engine layout.
About that time, I had just read about Jeff Perrin's EZ 30R swap in a WRX and thought that would make a great flagship car. I would have saved a lot of time money and headache with an STI engine, but that's hindsight now... Another EZ 30 one would be easy now... Thanks to Jeff for helpful advice, thanks also to Phil Grabow of Element Tuning and the great guys at Outfront Motorsports who answered endless questions and supplied the headers, fuel rails and lots of other stuff. They seem to have more Subaru 6 cylinder turbo experience than anyone on the planet.
I am happy to share any information about the engine mods, specs, etc.
John
jdogma is offline   Reply With Quote
Old 04-18-2013, 03:16 AM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I am intrigued.
Old 04-18-2013, 11:27 AM   #3
K.Linchpin
Member#: 97984
2015 2.5i Foz w/6pd
Subscribed.
K.Linchpin is offline   Reply With Quote
Old 04-18-2013, 01:10 PM   #4
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
pics? forged internal? what ECU? Why single turbo instead of twin turbo?
Nice project!
Old 04-18-2013, 02:40 PM   #5
Evan
Member#: 11218
2005 Legacy GT Wagon
99 Miata, 91 Miata turbo
Sounds like an awesome project. What's the current status? It would be great to see some photos. I clicked your photos link and it said I needed permission, so I clicked the button to request access.
The Niprotek website doesn't have any information. Do you have any links to details on the shock/springs?
Evan is offline   Reply With Quote
Old 04-18-2013, 03:58 PM   #6
jdogma
Member#: 242350
black
Nice project!
Sorry, forgot to make the photos public. They are now. https://plus.google.com/photos/10818...865?banner=pwa
The pistons are forged. The rods are stock. I copied Jeff Perrin's 440 whp build as far as turbo size, pistons, rods, and Hydra ECU. We use an updated turbo, I think our intercooler is larger, and we should have less drivetrain loss due to not driving 4 wheels. There are lots of other minor differences too.
Single turbos are superior for maximum power because there is less heat loss. They are not as quick to spool as twin setups, but Jeff said there were no lag issues at these boost levels with the 3582. I'm not sure if twin turbos would be easier or harder as far as packaging and plumbing, but there would be more plumbing. A single turbo is less expensive and cost is an issue (for me anyway). I think if we start looking at 600 - 700 whp builds, a twin turbo setup would make sense, but then the whole build would be way more expensive, and another transaxle would be needed.
Old 04-18-2013, 05:20 PM   #7
jdogma
Member#: 242350
black
You now have access. I screwed up and did not make it public, but it is now https://plus.google.com/photos/10818...865?banner=pwa
The Niprorek units are prototypes. I added a couple more photos of them. They consist of a hydraulic ram, a nitrogen spring with a rate adjuster and a valve body with external adjusting screws. The prototype units are additionally fitted with an adjustable reservoir that can be used to adjust ride height slightly, but is mainly to provide for a super wide range of adjustments for testing of these prototypes. The units are cool because you can adjust ride height and spring rate independently and because you have a rising rate which is why I wanted them. Since I expect pretty high aero loads (they increase with the square of the speed), any constant rate spring would be a compromise. If it was stiff enough for the high speed sections it would be too stiff for the slow speed corners, and if it was soft enough for the slow stuff it would bottom out at high speed. With these I can adjust the rising rate curve. I also have lots of damper adjustability with medium and high speed adjustable blowoffs for compression and rebound (compression is red, rebound is blue). They are also lighter than a coilover unit. Even the rod is aluminum.
Old 04-19-2013, 12:33 AM   #8
GreenMarine
Member#: 36080
While I really REALLY still want one of Pook's TR-42 Exo-cars, I have to ask..... Are you planning on making more than one of these? If so, Cost??
GreenMarine is offline   Reply With Quote
Old 04-19-2013, 12:49 AM   #9
Evan
Member#: 11218
Looks awesome. What does the schedule look like for getting it finished?
What are you using for motor mounts? I noticed the exhaust is bolted to the chassis.
Old 04-19-2013, 01:55 PM   #10
jdogma
Member#: 242350
black
Yes, there are molds, planning is underway for production. Will offer them as rollers, finished cars or frame + body + suspension. Not sure if other than carbon body will be offered. Maybe woven glass epoxy, but the carbon bodywork is so light and stiff...
Pricing will be very reasonable. The car was designed for ease of servicing and ease of build too. It is also designed to be configured in different ways. For instance the fairings in front of the passenger and driver are added on so that they can be left off for different windscreen options or added on left or right only. Got to do a lot of figuring based on the realities of doing business these days, but should know very soon.
BTW, what does a TR-42 Exo cost?
Old 04-19-2013, 02:06 PM   #11
jdogma
Member#: 242350
black
Road testing should start this month. One of the big things on the finish list is wheel tubs for the rear and they are started. Next up are running lights, brake and turn signals - headlamps might have wait a bit (investigating some LED options).
The motor mounts are stock Tribeca.
The exhaust appears bolted, but there is a stover locknut on a bolt through a steel bushing and allows the exhaust to grow ~ 3/8 in length and swing side to side. If the 2 degrees of freedom are not adequate the bushing will be replaced with a larger silicone rubber bushing.
Old 04-19-2013, 04:35 PM   #12
Evan
Member#: 11218
I asked over on his forum and here's the response I got:
The kit runs 13900 as a powder coated roller.
You can opt out of my wheels and tires to provide your own by subtracting 800.00
You can also upgrade and add a windshield, cluster, etc...
Source: http://forums.velocityofky.com/post/Prices-5890324
Old 04-19-2013, 05:30 PM   #13
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
Just saw the pics... FRICKEN AWESOME!!!!!
Keep us updated; that thing looks like a beast!!!
TurboLag23 is offline   Reply With Quote
Old 04-19-2013, 09:33 PM   #14
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
Awesome project! That engine and chassis combo is going to equal one scary fast ride!
bigolrig is offline   Reply With Quote
Old 04-20-2013, 04:02 PM   #15
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Very nice. You should get a Photobucket account and post photos here. I have been building the Meyers Manx STi dunebuggy for years so very interested in others projects. I am always looking for ideas.
Thanks
RSti_Spyder is offline   Reply With Quote
Old 04-20-2013, 06:00 PM   #16
jdogma
Member#: 242350
black
Thanks
http://i1284.photobucket.com/albums/...psb3f08839.jpg
http://s1284.photobucket.com/user/jo...?state=replace
Took your advice and tried photobucket. I see the photobucket link when I edit, but don't see the photo...
I get a lot of ideas from other people's conversions. I got the idea (and NAPA belt #) for simplifying the belt system from a guy who put an EZ 30 engine in an airplane.
I had a Meyers Manx (splash copy probably) that I used to autocross back when I was 17. Cut the windshield down so it was only about 8 inches high and it was much faster. I bet it will be super fast with an STI engine, but you may have trouble keeping the front down. I could pull a wheelie with mine (about 5 inch), a 1600 cc w/ twin solex and mild cam. How much heavier is the STI engine? Maybe with a front radiator, battery, etc. it will be good...
Old 04-20-2013, 07:32 PM   #17
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Copy the IMGcode and command V to place it in post. Doing this for me puts the photo itself in place. I am on a Mac...
Old 04-20-2013, 10:28 PM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Because you're not using the [IMG ][/IMG ] tags. It's something new they started using on these boards just 10 or 12 years ago.
Old 04-21-2013, 01:02 AM   #19
jdogma
Member#: 242350
black
Thanks!
Old 04-21-2013, 01:06 AM   #20
jdogma
Member#: 242350
black
I'm slow...
Old 04-22-2013, 01:20 PM   #21
mtbrider
Member#: 269144
2001 RS
Nice. Subscribed.
mtbrider is offline   Reply With Quote
Old 04-22-2013, 02:15 PM   #22
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'm still wondering about the engine choice. If you are only looking to make 450 whp or so, why did you choose the EZ30? It just seems like a lot of added cost and weight when compared to an EJ. Torque and power will be marginally different, for the same turbo and boost, because of RPM difference...I guess we can assume the EZ to perhaps has less frequent rebuilds because of power density.
Just curious,
Micah
Old 04-22-2013, 05:13 PM   #23
Metzenw
Member#: 351532
95 Impreza Coupe
Green
Very Very cool. Any reason behind not using an aftercooler?
Metzenw is offline   Reply With Quote
Old 04-23-2013, 12:23 PM   #24
wtyree
Member#: 29879
2002 WRX Wagon
Subscribed.
wtyree is offline   Reply With Quote
Old 04-23-2013, 08:08 PM   #25
jdogma
Member#: 242350
black
Thanks! The intercooler is in the sidepod like on an Indy Car. The gas tank is notched out to allow for the plumbing.
The radiator is in the left sidepod and the intercooler is in the right sidepod.
