Old 09-24-2002, 04:44 PM   #1
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Default overseas dyno differences: 3rd vs. 4th gear pulls
I came accross this thread on the MRT forums:
http://www.mrtrally.com.au/forums/to...?TOPIC_ID=1645
One guy suggests that getting the truest readings requires doing dyno pulls in the gear closest to 1:1, which is apparently 4th gear in the WRX.
AFAIK, most tuners in the US do 3rd gear pulls...could this partially explain why our numbers seem *inflated* compared to the boys overseas? I'd always assumed in the US that we must run different dyno programs that gives higher readings than OZ and UK.
Of course, the type of dyno no doubt plays a role in this as well, but I'm wondering how much of a difference the gear actually makes.
Mark
annointed is offline   Reply With Quote
Old 09-24-2002, 04:55 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Who really cares? Well, maybe the folks in the Proven Power Bragging might have an interest. This thread should have been posted there.
Jon [in CT] is offline   Reply With Quote
Old 09-24-2002, 05:53 PM   #3
annointed
Member#: 5960
Thanks for that contribution.
I'm hoping to learn something here...how does gearing affect wheel hp figures? And is that effect real (ie, do you actually have less hp in 4th than in 3rd), or is the difference only related to the dyno's program? An engine dyno wouldn't even involve gearing, so I suspect that the peak hp difference is built into the dyno's program?
Anyway, I'm just brainstorming, so I'd just like to learn more about this whole issue.
Old 09-24-2002, 06:18 PM   #4
nmyeti
Member#: 4980
Default Re: overseas dyno differences: 3rd vs. 4th gear pulls
Mark
Mark,
I can't speak for the other shops, but we NEVER do 3rd gear pulls when we are tuning. We run 4th gear pulls with a 15 second ramp time between 2000 and 7000rpm.
-Nathan
nmyeti is offline   Reply With Quote
Old 09-24-2002, 06:28 PM   #5
annointed
Member#: 5960
Default Re: Re: overseas dyno differences: 3rd vs. 4th gear pulls
Originally posted by nmyeti
Mark,
-Nathan
Technically, what is your reason for 4th gear pulls?
Old 09-24-2002, 07:30 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
My contribution was to direct you to the correct freaking forum. Comparisons among diferent types of dynos and how to (mis)use them has zero Factory Forced Induction relevance, whereas it's a common and germane topic in the Proven Performance Bragging forum.
Old 09-25-2002, 08:36 AM   #7
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
and perhaps that was best posted in the Self righteous Idiot forum.
Pavlo is offline   Reply With Quote
Old 09-25-2002, 08:37 AM   #8
is2scooby
Member#: 19851
02 WRX
Aspen [email protected]
is2scooby is offline   Reply With Quote
Old 09-25-2002, 09:05 AM   #9
2000vfr800
Member#: 15599
OK... If you are looking for engine hp...
Power is power. Your engine will produce the same power from 1000 rpm to 7000 rpm no matter what gear you are in. You just have to convert the torque values to engine torque values based on the gear ratio of the gear you are in.
How you get a power curve on a dyno...
The dyno actually controls the speed. You place the car (engine) on the dyno, select the gear you want. The dyno is then set for the correct idle speed. Then, the throttle is set at WOT. The dyno will then keep the speed at idle speed. The force of the wheels (driveshaft) on the dyno will create a load (the car wants to go faster, the dyno is stopping it). This is measured with an in-line torque meter or load cell. This will give you torque. The dyno will then ramp up the speed at a certain rate and constantly record the torque. For emission testing, the Fed. usually specifies 8 rpm per second. At redline, you stop.
What you then get is a speed vs. torque graph. You then need to correct for gear ratios, humidity, temperature, and drivetrain losses to get your actual engine hp.
2000vfr800 is offline   Reply With Quote
Old 09-25-2002, 10:33 AM   #10
Mach V Dan
Member#: 12029
This is true of a resistance (braking) dyno like a Dynapack, but not of an inertial dyno like a Dynojet. The inertial dyno has heavy rollers that the car has to accelerate, and the rate of acceleration of the rollers translates into how much torque the car makes.
Dynojet, at least, does recommend using the closest gear ratio to 1:1, although since it knows both engine RPM's and wheel speed, the dyno software SHOULD be able to figure out torque in any gear. (It could calculate the effective gear ratio by dividing wheel RPM's by engine RPM's. I don't know that it actually does this, though.)
Assuming there's no fancy calculations on the part of the software, a lower-gear pull on an inertial dyno will make it appear that the car has more torque, since the torque multiplication of the gears will allow the car to accelerate the heavy rollers faster. I haven't use this software extensively, so I don't know if there is provision to tell it what gear/what gear ratios you are using.
Nathan, does the Dynapack software do the math so the computer will figure out what gear you are in, or not?
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 09-25-2002, 11:22 AM   #11
nmyeti
Member#: 4980
--Dan
Mach V
FastWRX.com
Dan,
We setup the pull by telling the computer what our gear ratios are. It will show actual torque (gear multiplied) or what it calls "flywheel" torque which is without the gearing factor in it.
There is also a "torque correction factor" which will allow you to guess at drive train loss, but we leave that as a "1" so that what you get at the wheels is what you see...
-Nathan
Old 09-25-2002, 02:27 PM   #12
jlevy
Member#: 15696
2015 WRX 6 speed
I would think that dynos that measure torque as the engine is accelerating would show lower torque values in lower gears (corrected for gear ratio of course) due to inertia of the wheels, flywheel and everything else you're trying to accelerate. This is the same reason why some people think lightened flywheels and pulleys give additional horsepower when they actually just let the engine accelerate faster.
-my 0.02
jlevy is offline   Reply With Quote
Old 09-25-2002, 03:53 PM   #13
2000vfr800
Member#: 15599
You're right. I am just used to working with higher end active dynos and such.
WTB: gear set or just 3rd and 4th gear of 02 wrx AFBeefcake Private 'Wanted' Classifieds 12 10-16-2006 10:20 PM
3rd vs 4th vs 5th on Dyno Runs. Which is Best? metoo Proven Power Bragging 17 03-06-2004 06:22 AM
3rd to 4th gear shift problems fstede21 Transmission (AT/MT) & Driveline 5 07-12-2002 05:38 PM
squeak in 3rd and 4th gear (only 3,500 miles) bahboy20 Transmission (AT/MT) & Driveline 0 11-13-2001 10:35 PM
trans grinds from 3rd to 4th gear wrxblitz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-12-2001 05:21 PM
