Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 08-16-2013, 05:49 PM   #76
mrbloink
Member#: 333058
Originally Posted by soobie doo View Post
The googles are telling me that it's a common issue, and I need to tighten stuff down better. I'll deal with it over the weekend.
Make sure everything is lubed up all nice! I used a healthy amount of marine grease on the sway bushings and endlinks. That should solve the clunk
mrbloink is offline   Reply With Quote
Old 08-16-2013, 06:27 PM   #77
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
I cranked everything down a bit tighter after work today, no more clunk. If it comes back, I'll try lubing it up.
soobie doo is offline   Reply With Quote
Old 08-18-2013, 08:29 PM   #78
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Be warned that the service manual does not call for greasing the bushings and end links. Doing so is not sanctioned by Subaru. Do so at your own risk.
I know that some aftermarket bars and bushings call for lube, and even provide grease fittings. But this is not the case on the OEM hardware.
sgoldste01 is offline   Reply With Quote
Old 08-18-2013, 10:12 PM   #79
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
Question for someone who knows more than I do. I have the sport package with stock 16mm sway bar. I just installed a 1 inch lift in front and 1 3/8 in back. I don't notice any extra body roll in back from this lift. Could it be because the control arms are lower and putting more tension in the sway bar and making it act stiffer? Would it still improve handling to get the 19mm? Please help me out. Thanks
SIA_worker is offline   Reply With Quote
Old 08-18-2013, 11:40 PM   #80
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
I honestly doubt that the control arms are doing anything to the sway bar, based on how sway bars work. The sway bar is probably functioning exactly the same as it always does. You likely aren't noticing more body roll due to just not driving it hard enough, combined with the probability that raising a chassis as well designed and stable as this one isn't all that affected by an inch of height. After all the Crosstrek is over two inches taller and still handles very well. If it aint broke don't fix it. With that being said, you REALLY should post pics of the lift and explain how you did it. Possibly a walkthrough if you feel like it. A good few of us have been seriously considering a lift but I think you may be one of the first to do it without using Crosstrek struts so many of us would be very interested in indeed.
Dirt Bringer is offline   Reply With Quote
Old 08-18-2013, 11:51 PM   #81
SIA_worker
Member#: 353354
2013 Impreza HB
Ice Silver Metalic
I have a post look it up. Love the lift. Do it!
Old 08-19-2013, 11:06 AM   #82
dorikin
Member#: 30640
2012 impreza 2.0 ltd
has anyone gone to 22mm yet? if so how is the balance?
i wanted to go with 22mm right off the bat (16mm presently) but due to the cost jump i ordered a 19mm to give that a shot first.
dorikin is offline   Reply With Quote
Old 08-19-2013, 11:21 AM   #83
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Good choice. Most folks here feel that 19mm gives the best balance, and that 22mm would induce too much oversteer.
Old 08-19-2013, 01:36 PM   #84
dorikin
Member#: 30640
the car handles decently with the 16mm bar (a good upgrade for base models for sure) but still pushes too much for my liking (coming from a previous setup with a lot less compliance). 22mm doesn't scare me tbh, i'm just thinking 19mm is a good compromise between handling improvement and price since it's a big jump from $100 for the 19mm to $500 for a bigger rsb and beefier end links. i'm sure 19mm will give it a bit more turn-in bite but i still don't expect a 19mm bar to neutralize the balance completely
fwiw many moons ago, stock WRXs came with a 20mm rsb.
edit- ^^^ but then again, subaru went back to 17mm shortly after; probably after one too many TTO accidents so maybe 19mm is a good compromise for a rain/snow/slush daily driver
Old 09-10-2013, 08:07 AM   #85
LegionSpecter
Member#: 353258
2013 XV Crosstrek
Bright effin Orange
well i got my hands on a 22 front and a 19 rear. im getting the clamps and hardware for the rear this weekend. ill let youse guys know how they help my base 2.0i
LegionSpecter is offline   Reply With Quote
Old 09-10-2013, 09:27 AM   #86
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
You already have a 22mm front from the factory.....
Old 09-10-2013, 09:59 AM   #87
LegionSpecter
Member#: 353258
2013 XV Crosstrek
Bright effin Orange
well it was all bouht together. $100 for the frontand rear, wih bushings and endlinks included. so i can just put he matching ones on and take my old front and use it as decoration in my bedroom
Old 09-10-2013, 10:34 AM   #88
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
did it come off a 2012 2.0i? if it didn't pretty sure it won't fit
Old 09-10-2013, 12:15 PM   #89
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Where's my damn popcorn
goregasm is offline   Reply With Quote
Old 09-12-2013, 09:05 AM   #90
EDKEdwin
Member#: 361912
2013 Imp GP Touring
Satin White Pearl
this certainly looks like a good upgrade.
what about the front tower strut? what sort of compatibility is there with other Imprezas?
EDKEdwin is offline   Reply With Quote
Old 09-13-2013, 03:47 AM   #91
curiouskevin
Member#: 319162
2013 Impreza SL
Anyone know if a 2013 STi sway bar would work too? I found some guy selling one on craigslist, but I want to check to make sure it'll fit.
curiouskevin is offline   Reply With Quote
Old 09-13-2013, 07:34 AM   #92
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
It should fit. I don't believe the 2013 STI sway bar is any different from the 2008 through 2012 STI sway bar.
Old 09-13-2013, 08:56 AM   #93
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Rear sway bar sure. I got mine used off a 2011 sti. Same suspension.
Old 09-13-2013, 12:32 PM   #94
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
I'm thinking about installing a rear sway bar on my 2013 Impreza 2.0i Base model sedan. Can anyone post a picture of a rear sway bar installed on one? I suppose it doesn't really need to be of the base model or the sedan. Just would like to see where it mounts and everything.
VegasSubie is offline   Reply With Quote
Old 09-13-2013, 01:32 PM   #95
tbaysubie
Member#: 366411
Installing this doesn't affect your warranty right ?
tbaysubie is offline   Reply With Quote
Old 09-13-2013, 01:43 PM   #96
myrt1987
Member#: 323103
2012 Limited 2.0i
No, of course not. They come stock on most models.
To Vegas: If you google it, it will you show you basically where its located and what the parts look like. Good luck getting someone to take a picture.
If youre thinking about getting one, youre overthinking it. Install takes about 5-10 mins.
Old 09-13-2013, 01:55 PM   #97
Angelus911
Member#: 89967
2012 Impreza Sport
The only problem I had installing mine was realizing I needed an allen wrench to install it. Once I saw that, it went smoothly
Angelus911 is offline   Reply With Quote
Old 09-13-2013, 02:35 PM   #98
VegasSubie
Member#: 365638
2013 Impreza 2.0i
1991 Galant VR4
Couldn't find any good images by searching Google. Did find a couple pictures by looking at custom exhaust on the forum though. Looks pretty simple. And the only thing I'm thinking about is that I'm pretty close to broke and not sure if I want to put one on my credit card.
Old 09-13-2013, 02:58 PM   #99
79letour
Member#: 302570
2013 XV
DGM!
Well, collect scrap aluminum and copper for a week or two and then buy one. If I decide to upgrade my stock rsb in the future, you can just have it for whatever the shipping costs. But I'm in no hurry to replace mine. May do it after christmas. I'm going with the oem 19mm when I do.
79letour is offline   Reply With Quote
Old 09-13-2013, 10:46 PM   #100
Vjaramillo
Member#: 359666
2013 Impreza limited
Ice silver
Anyone interested in a oem rear swaybar from a limited 2013 impreza? Just installed sti one.
Vjaramillo is offline   Reply With Quote
