Old 07-21-2013, 11:02 PM   #51
WelDun1
Member#: 249130
1999 Ver5 STi RA
Originally Posted by ShinjiML View Post
Haven't check this thread in a while, my heads sat at the machine shop for about a month before they finally began working on it, but everything's basically together now, only hold up is the injectors. I bought a set of 565 dark blue's from the classified, but all 4 ended up not spraying at all, so now I'm getting a set of Deatschwerks 650cc. That'll teach me to always try to buy used to save a few bucks...Some things you can buy used, but I guess injectors is one of the things that's probably better off purchased new. =\
Can't wait to finish everything and get it tuned!
I was saying the same thing the other day. Some parts are just better to get new. If it has moving parts, I usually get it new...Lol
If I were you, I'd Atleast get some 850cc. And get Injector Dynamics's. They have a better rep for lasting longer and keeping an even spray. I'm getting the ID1000cc. You can't go wrong with them. If ur only getting 650's, ur better off just screening some stock Pinks. It's definitely cheaper, but honestly, you should go with the ID1000cc like I am, if not the 1000cc, than Atleast the 850cc.
WelDun1 is offline   Reply With Quote
Old 07-21-2013, 11:23 PM   #52
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
I considered going bigger, but then I'd need a bigger turbo, which would then mean an sti tranny swap. This is my way of keeping myself in check lol.
It's so hard to keep myself from always spending on my car.
ShinjiML is offline   Reply With Quote
Old 07-23-2013, 07:25 PM   #53
WelDun1
Member#: 249130
1999 Ver5 STi RA
Any new info?
Old 03-05-2014, 06:05 AM   #54
karn101
Member#: 300055
1994 Impreza L
Red
Originally Posted by WelDun1 View Post
Any new info?
Half a year later bump!
A few questions,
1. Does the Version 5/6 EJ207 use the 02/03 EJ205 Timing Belt Kit?
2. If I swap to an EJ205 Intake manifold/sensors/ECU, what MAF do I use? I keep reading about how bad they are on the V5/V6. Do you switch to the EJ205 MAF after the swap?
3. Coil pack. Which one do I use?
4. Spark plug wires. I'm guessing this is an import part only?
Thank you!
My searching usually bring me info on the V7 and up so I decided to ask.
And here's my little contribution:
The ver 6 MAF (part number 22794AA010) can be replaced with the MY99 RS MAF (Part number 22794AA000)
Source -
http://www.rexnet.com.au/forum/index...lacement-part/
karn101 is offline   Reply With Quote
Old 04-11-2014, 01:19 AM   #55
Modollenroc
Member#: 243499
A few questions,
Thank you!
Source -
if this helps any i used the MY 99 MAF on my v6 ej207
the 205 timing belt will work for the 207...
the spark plug wires i used were usdm i believe, i got them form roadrace engineering.
Modollenroc is offline   Reply With Quote
Old 09-15-2014, 03:57 PM   #56
Beans33
Member#: 396152
1999 Impreza WRX Sti
Hey guys, does anyone happen to know where I can find a workshop manual for my v5 ej207 ? I can't seem to find one anywhere. I spun a rod bearing on the first day I got her and want to rebuild.
Any sort of info that will help me with the rebuild process is greatly appreciated !
Beans33 is offline   Reply With Quote
Old 09-25-2014, 01:48 PM   #57
Suee_whee
Member#: 380766
I currently have a jdm engine I'm putting in my wrx, idk if its ver 5)6)7 and so on but I would appreciate some help figuring it out please and thank you
Suee_whee is offline   Reply With Quote
Old 10-06-2014, 03:41 AM   #58
WelDun1
Member#: 249130
1999 Ver5 STi RA
Hey man, do you have any pics? Its pretty easy to tell the Ver5/6 from the Ver7, but to differentiate between a 5&6 is a little harder if you only have the engine. If you post some pics I can prolly tell you what you have tho.
The ver5/6 has the offset coil pack on the intake manifold, and the ver7 doesnt have a coil pack on the manifold, it uses the individual packs.
Old 10-06-2014, 03:49 AM   #59
WelDun1
Member#: 249130
1999 Ver5 STi RA
So I have my swap finished and now I'm doing the tuning. I'm running the stock ver5 RA ej207, rotated gtx3071r w/TiAl .63ar hotside, FMIC, TiAL 38mm EWG, TiAL Q BOV, custom fab'd vband up/dwn pipe, DW300 pump and DW850cc inj, AEM meth kit, 06+ 2.5 oil pan, KillerB pickup tube & baffle, Link G4 PnP ecu... I'm not sure how much boost I should be running, meaning how much boost I think the stock block can handle. I'm only going to be running on the stiffest WG spring for now, but I do have a Perrin EBCS Pro that I'll get installed as soon as I can get someone to tune for it. I think I should be good on 15-18psi tho...what do you guys think?
Old 06-02-2015, 06:24 PM   #60
isaiahkaid
Member#: 422623
Default My Clutch is gone!!! Please Help!!
hey guys, i have a 1999 RHD impreza wrx sti ver 5. i imported it from japan last year adn yesterday my clutch went! i have been trying to look for one around where i live in canada but i cant find one. i am looking for an exedy organic stage 1 kit, my issues however have been not being able to find one specifically made for MY car! i can only find ones for the impreza outback l 2.2L or the impreza rs 2.5L. I have an ej207 an that is turbod so would i blow the clutch if i bought one for either of those models? the other option is 2002 USDM wrx but im not sure if it will fit! Has anyone successfully put a USDM WRX clutch into a 1999 ver 5 GC8 STI???? Any help would be much appreciated im trying to get my car back on the road asap!!!!!
isaiahkaid is offline   Reply With Quote
Old 06-26-2015, 02:29 PM   #61
AsheL
Member#: 424392
You match clutch to trans not motor. Start looking clutches in a different way, what turbo cars have that transmission and match it that way
AsheL is offline   Reply With Quote
Old 07-13-2015, 01:01 AM   #62
Beans33
Member#: 396152
Hey guys I need some advice..Im planning on running the killer b oil kit, and mishimoto front mount oil cooler with thermo plate. Now I think the stock oil pump is 10mm ? But should I opt for the 11mm to compensate for a loss of pressure and increased capacity?
Old 11-21-2015, 01:44 PM   #63
Beans33
Member#: 396152
Did you guys just use 02 usdm torque specs for your rebuilds ?
Old 06-14-2016, 06:42 AM   #64
WelDun1
Member#: 249130
1999 Ver5 STi RA
Anyone know where the A/C IN wire is on the Ver5/6? I know its plug 135-11, but i dont know where it goes from the ECU. Does it go straight to the A/C compressor?
My A/C has been deleted, but i need to find that wire so i can use it for a Digital Input.
Old 08-28-2016, 02:49 PM   #65
Suubaruguy94
Member#: 453476
Default 94 legacy v5 swap
Anyone ever swap a 94 legacy turbo with a v5 ra Sti
Need help on wiring car cranks but doesn't have spark
Suubaruguy94 is offline   Reply With Quote
Old 09-08-2016, 06:04 PM   #66
Swampdonkey1
Member#: 454014
95 impreza
red
Default V5/6 sti swap
Hi I'm new to nasico and from the post on v5/6 swaps there's not much activity since 2015 on the subject I have done the rhd swap and am running the jdm ecu for this block I bought a half clip from eBay and I have the motor in the vehicle currently cranks but no spark fuel has straight 12v to the pump right now I have checked the timing it's dead on and checked ohms on cam and crank sensors there within range and good as far as ohms check out is there any more info someone can give me as to why I have no spark or any diagrams on the v5/6 any additional info would be appreciated also how do you attach photos since that will help putting your eyes on it thanks for any help you guys can give me on this subject
Swampdonkey1 is offline   Reply With Quote
