Old 04-18-2013, 01:51 PM   #1
HellyWRX
Member#: 347394
2009 Impreza WRX
Satin White Pearl
Default K&N Short-Ram Intake ?'s
Recently installed a K&N Short-Ram intake on my '09 WRX Hatch. At full throttle in 4th gear at about 5000rpm it almost seems to lose power for a split second then throw the check engine, traction control and cruise lights. I have tried a Stage1 tune, Stage1+SF tune and the Stage1+AEM Intake Tune. Checked the codes after and it gives me a Wastegate Soleniod code.
So far the Stage1 91 tune has seemed to work the best but I don't want to blow anything up and also would rather not have to sell the intake just to buy another one.
Running 91 with stock everything except the intake.
Just wondering if anyone else has the same intake installed and having the same issues or if someone has figured out the problem?
Any feed-back appreciated.
Thanks,
HellyWRX
HellyWRX is offline   Reply With Quote
Old 04-18-2013, 02:05 PM   #2
HellyWRX
Member#: 347394
2009 Impreza WRX
Satin White Pearl
Update: forgot to mention, the K&N website and any other research I've done indicates no tune is required with this intake although I know from popular discussion that anything to do with engine management/power should also be done with a tune!
Old 04-18-2013, 02:33 PM   #3
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
You absolutely need to be tuned for it. Some people claim they can get away with the Cobb SF maf scaling for it, but the 08+ wrx/sti have much more sensitive MAFs.
Either use the cobb map with the correct intake or get tuned via pro tune / custom tune / E tune.
endrswrd is offline   Reply With Quote
Old 04-18-2013, 03:15 PM   #4
ogboot
Member#: 170906
psm
This. I have one of these on my older MY, your MAF scaling is going to be off. Be careful, hopefully since you have a SF intake tune on there now it will be close enough to be drivable until you can get it taken care of.
ogboot is offline   Reply With Quote
Old 04-22-2013, 10:50 PM   #5
BubbaFNSmith
Member#: 352192
2014 WRX
Yup ^^
BubbaFNSmith is offline   Reply With Quote
Old 04-24-2013, 06:30 PM   #6
HellyWRX
Member#: 347394
2009 Impreza WRX
Satin White Pearl
Can anyone suggest a place to get an etune? I'm about to put on a Cobb CBE and that will be it for mods for some time.
Old 04-25-2013, 07:19 PM   #7
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
No tune is needed for a CBE. You will gain nothing but noise with a catback. Not sure if you were aware or just want a nice stage 1 tune.
Cathexis is offline   Reply With Quote
Old 04-27-2013, 01:43 AM   #8
Andrewxxcarlson
Member#: 316415
2006 WRX
Screw the catback and get a downpipe at least. You won't regret that decision.
Andrewxxcarlson is offline   Reply With Quote
Old 05-03-2013, 08:34 PM   #9
sto1vall
Member#: 353594
Ok, just got my AEM CAI just today and purchased a DP, catless, pocking upon
sto1vall is offline   Reply With Quote
