Welcome to the North American Subaru Impreza Owners Club Thursday November 27, 2014
Old 04-18-2013, 05:42 PM   #1
klaus_b2
Member#: 318411
Default XXR 531 fitment? 17x9
hey guys, first off, im new to having a wide wheel so just bare with me. I just got some 17x9 xxr 531 and i think im gonna have a problem fitting them to my car. I test fitted them on my car today and they are about a fingernail from hitting the strut. I was thinking im going to have to run spacers but whats the smallest spacer i could run? The wheels are now flush with the fender and i dont want too much pokeage. Help anyone?
[IMG][/IMG]
[IMG][/IMG]
klaus_b2 is offline   Reply With Quote
Old 04-18-2013, 05:51 PM   #2
20lgt05
Member#: 237444
2005 LGT limited
BSM
you can probably run a 3mm spacer and be fine. are they that close in all four cormers?
20lgt05 is offline   Reply With Quote
Old 04-18-2013, 05:56 PM   #3
klaus_b2
Member#: 318411
alright sweet i really wanna rock these wheels lol and no. the fronts are good. its just the rears that are tight
Old 04-18-2013, 06:28 PM   #4
20lgt05
Member#: 237444
2005 LGT limited
BSM
you might be able to get away with 5mm spacers. do you have any other pictures? i was looking into these wheels but was unsure how they looked on a subaru
Old 04-18-2013, 06:36 PM   #5
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
Whats the offset right now on those wheels? BTW...love the look of those! Nice pick up.
I do agree, you could probably get away with something small, 3-5 mm.
rmarchigiani is offline   Reply With Quote
Old 04-18-2013, 06:46 PM   #6
sc00by4life
Member#: 97135
thats MORE than enough room.....
the distance between the wheel/tire and the strut is a constant distance. it doesn't change. if you want to run an extra wide tire, then yes, you might want some small spacers depending on your camber.
and lol @ ccw knockoffs.
Old 04-18-2013, 06:56 PM   #7
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
^^^I agree with him, it is a constant distance, which is why you might need nothing at all. But you wont know that until you properly set the car up...ie - mount tires/wheels, camber, alignment....drive the car.
As far as knock offs....yes they are, doesn't change the fact that they look good and are more affordable.
To each their own....enjoy them.
Old 04-18-2013, 07:13 PM   #8
klaus_b2
Member#: 318411
thanks man, and they are +35
thanks for the info. and i drive a 2.5i which means i dont go fast, so no need for real ccw lol
hopefully i wont but well see once i get tires mounted, thanks for the help guys!
Old 04-18-2013, 10:05 PM   #9
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
If I were you I would get the wheels on and get the car set up to where you want it. Then drive it a little before your alignment this you can see if it rubs. This way you don't have to align it twice if you end u needing spacers.
GL man
Rafe
Old 04-18-2013, 10:35 PM   #10
sc00by4life
Member#: 97135
GL man
Rafe
you dont need an alignment for spacers...
Old 04-18-2013, 10:43 PM   #11
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
Although I agree with you.....if you push a wheel further out from the hub....even 3 mm.... You may have to run additional camber to fit the wheel and avoid rubbing on the fender or to avoid the "poke" look, which in turn can mess with toe. So in theory, you may need an alignment after the addition of a spacer, indirectly related to the spacer, to fix camber/toe.
I'm no expert, but that's my understanding. And if it were me and I changed my setup to fit after placing a spacer, I would realign my car to make sure my toe is in check.
Old 04-18-2013, 10:55 PM   #12
klaus_b2
Member#: 318411
yeah but the thing im not understanding is, wont the tire hit my strut when i hit bumps and stuff?
Old 04-18-2013, 10:59 PM   #13
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
No it shouldn't. Once the wheels is bolted to the hub, it shouldnt shift toward the strut. If it did, something would be seriously wrong.
Old 04-18-2013, 11:03 PM   #14
klaus_b2
Member#: 318411
No it shouldn't. Once the wheels is bolted to the hub, it should shift toward the strut. If it did, something would be seriously wrong.
haha yeah, hopefully thats not the case
Old 04-19-2013, 03:53 AM   #15
20lgt05
Member#: 237444
2005 LGT limited
BSM
Post up some more pics
Old 04-19-2013, 09:36 AM   #16
klaus_b2
Member#: 318411
At the Track
Of what? Just the rim on the car? Or with the tires? Cause I wasn't planning on getting tires til about 2 more weeks
Old 04-19-2013, 09:49 AM   #17
20lgt05
Member#: 237444
2005 LGT limited
BSM
Yea I want to see how they look on the car
Old 04-19-2013, 12:44 PM   #18
klaus_b2
Member#: 318411
I'll post up a pic once I get some tires on em
Old 04-19-2013, 12:59 PM   #19
besthaticouldo
Member#: 279660
just because you dont go fast doesn't mean you don't want real wheels
just saying....
besthaticouldo is online now   Reply With Quote
Old 04-19-2013, 01:45 PM   #20
klaus_b2
Member#: 318411
just saying....
damn that sucks, howd you do it?
Old 04-19-2013, 02:27 PM   #21
besthaticouldo
Member#: 279660
it wasn't me. but the car was in an accident.
Old 04-19-2013, 10:57 PM   #22
klaus_b2
Member#: 318411
then im sure real wheels wouldve had the same result haha
Old 04-20-2013, 01:08 AM   #23
sc00by4life
Member#: 97135
Having to run additional camber to fit spacers doesn't mean spacers require an alignment.
Spacers have nothing to do with needing an alignment.
Old 04-20-2013, 10:11 PM   #24
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
We can agree to disagree.....Im not going to be an internet tough guy and pretend I know it all, cause I don't.....but in my humble opinion, if you put spacers on and you need to adjust your set up to fit the wheels properly because of the spacers, ie dial in negative camber.....then you need an alignment afterwards.
Therefore, spacers indirectly affect the need for an alignment.
However if you put spacers on to clear brakes or struts, and do nothing else besides put the spacers on, then I agree, you do not need an alignment since you did not change camber/caster/toe. So Spacers do not always need an alignment, I agree, but then can indirectly lead to one, if other suspension mods are done.
Old 04-20-2013, 10:34 PM   #25
sc00by4life
Member#: 97135
This would be needing an alignment because you are doing something stupid. You require an alignment because you are messing with the camber, not necessarily because you are using spacers.
Correct. Spacers do not and will never directly require an alignment.
its not about being a "tough guy", its about posting correct information in a technical forum.
