Old 05-27-2013, 09:01 PM   #1
gbsharon
Member#: 354177
2013 XV Crosstrek
Desert Khaki
Default 2013 Impreza Conundrum
So I will be purchasing a 2013 impreza sport. I will immediately start upgrading the audio system, word has it that the OEM is not good. I have a few questions:
1. Is it worth ordering the tweeters from subaru just so i can have the pre-fabbed mounts and wiring in, or does it come with holes for the tweeters up high with some sort of blanks? (I do not want to be cutting holes in pillars)
2. If the tweeters are ordered from subaru, is the X-over built in to the door speaker, or is it running from the tweeter to the head unit? ( I will be replaced speakers first, then later HU)
Not sure if this information has changed for the 2012/ 2013 impreza refresh, so trying to pick new/ same info from old.
thanks in advanced!
-gb
gbsharon is offline   Reply With Quote
Old 05-28-2013, 09:11 AM   #2
Angelus911
Member#: 89967
2012 Impreza Sport
1. Your car already comes with tweeters standard, so if you plan on upgrading to aftermarket components, then you're all set.
2. AFAIK, the crossover is built into the tweeter itself (capacitor of some sort)
Old 05-28-2013, 03:41 PM   #3
phenryiv1
Member#: 91212
2011 WRX 5DR
Those are both true, but since the tweeter is built into the OEM mount you will need an adapter. I have made a couple for the Legacy/BRZ/Impreza models but I can't remember the dimensions. I have them somewhere.
phenryiv1 is offline   Reply With Quote
Old 05-31-2013, 09:21 AM   #4
SLYD3R
Member#: 353415
I am interested in this too. I just bought a 2013 Impreza limited. I feel the audio is a little lacking, but I don't want to lose any of the factory functions, ie steering wheel control and BT.
SLYD3R is offline   Reply With Quote
Old 05-31-2013, 11:25 AM   #5
phenryiv1
Member#: 91212
2011 WRX 5DR
Then upgrade the speakers.
Old 05-31-2013, 12:09 PM   #6
IASubie
Member#: 351754
2013 Impreza Sport
Dark Cherry Pearl
Crutchfield has an interface that works with OEM stereos, it has two output channels that can be used with amp or subwoofer and is highly rated.
I found the link:
http://www.crutchfield.com/p_161LC2I...i.html?tp=2001
IASubie is offline   Reply With Quote
Old 05-31-2013, 12:34 PM   #7
VolkFreak
Member#: 48556
2008 R32 #3528
CW
so the issue with the crappy sound is with the speakers ?
Just got a 2011 WRX and the sounds is very muddy and with no definition. After reading a few threads it seemed like the problem would be with the HU not the speakers.
Id like to keep the stock HU and was thinking of just trying to add an amplifier. Any ideas?
VolkFreak is offline   Reply With Quote
Old 05-31-2013, 12:52 PM   #8
phenryiv1
Member#: 91212
2011 WRX 5DR
No, not entirely. Nut if the previous poster does not want to change the HU, I would use the hidden menu to "zero" out the EQ that is built into the HU (http://forums.nasioc.com/forums/show....php?t=2317060) and start by upgrading the speakers. If you need more bass, add a sub. More overall volume before distortion? Add an amp.
The OEM HU has a crazy EQ that needs to be disabled before making any other changes.
But for the benefit of everybody, be aware that there are differences between the 2011 WRX stock system and the 2013 Impreza system, so don't get that confused.
Old 05-31-2013, 07:31 PM   #9
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
This still needs an amp to run separates.
I found the link:
CRAZYHAWK is offline   Reply With Quote
Old 05-31-2013, 07:33 PM   #10
CRAZYHAWK
Member#: 198067
WHITE Premium
Get a 2 channel amplifier that uses the front speaker wires for inputs.
Get separates for the front.
Old 05-31-2013, 10:52 PM   #11
blzr25x
Member#: 337689
2013 Impreza Premium
DGM Sedan
Changing the HU will definitely help with sound quality, but the speakers are still crap. Even after playing around with the hidden menu in the stock HU, the sound still didnt sound any better. So I upgraded the HU to a pioneer 2400bt. That helped with sound a lot, but still wasnt happy. SoI recently just upgraded the speakers to, polk db651, and it sounds amazing now. And if you're concerned about steering wheel control, there are adapters that can be purchased, such as the metra ASWC unit.
blzr25x is offline   Reply With Quote
Old 05-31-2013, 11:27 PM   #12
gbsharon
Member#: 354177
2013 XV Crosstrek
Desert Khaki
I am thinking of initially just upgrading the speakers, then saving up a little and adding a HU, dedicated amps, and sub. The stock HU will drive upgraded speakers, just not to their full potential, correct?
Old 06-01-2013, 08:22 AM   #13
phenryiv1
Member#: 91212
2011 WRX 5DR
Correct.
Old 06-01-2013, 02:45 PM   #14
VolkFreak
Member#: 48556
2008 R32 #3528
CW
on my 2011 wrx stock HU, i disabled loudness and the EQ and it made a big difference, but if you have it loud you can tell the speakers are having trouble. So definitely speakers now will be my first change, well that and a small sub.
btw does anyone know if on my 2011 i can use wrx oem underseat sub ?
