Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 02-03-2003, 11:34 PM   #1
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
Default Alternator, Alternator, Alternator
Does anyone know good detailed ratings on the alternator output of a 2003 2.5RS? I see it listed as a Mitsubishi 12v 75a alternator, but this doesn't speak to the varied outputs at different rev levels. Is 75 the ceiling, or the floor? Also, does anyone know how much there is to play with on a stock car with fog lamps? I'm wanting to put a JL 300.2 and 500.1 on there, powering MB Quart QSD 216s and a JL 10W7 in a Prowedge, with a 5 farad cap in there to control the burst draws, but i'm wondering if i'm already going to be way over alternator capacity at idle. I suppose I can hook a DC voltmeter up and check the idle running draw with various devices on, but i'm hoping someone else has already gone through all this fun.
ShadowIMg is offline   Reply With Quote
Old 02-04-2003, 12:29 AM   #2
Will98RS
Member#: 15816
1998 Impreza RS
not to highjack but i have a similar question.
i want to put in two rockford fosgate amps the 500x and the 500bd, i have a 98 RS.
basicly my question is how does one know when one's electrical system will be overburdened. this might make a good sticky at some point.
thanks
will
Will98RS is offline   Reply With Quote
Old 02-04-2003, 01:45 AM   #3
Sobelizard109
Member#: 10302
2005 GT WAGON
SILVER
how much are high out put alternators and where can i get one?
Sobelizard109 is offline   Reply With Quote
Old 02-04-2003, 01:16 PM   #4
TXBlueBeast
Member#: 24494
2008 Prius
you should talk to 'ruiner'. he got his alternator rewound....
here is a quote from him from a thread a while back
"The stock WRX alternator is 75 amps. This sucks. Most cars are ~90-100 amps. If you plan on any subs at all, and you want to keep your electrical system forget it. I just ordered an OEM alternator and am having it rewound to 165 amps."
Hope that help you a little bit
TXBlueBeast is offline   Reply With Quote
Old 02-04-2003, 03:20 PM   #5
subaru mike
Member#: 30749
2002 wrx
Are you going to rewire your car? I am thinking of doing this but i am worried that i will fry the wires....like when you use 100 watt bulbs in the stock wireharness...let me know
-mike
subaru mike is offline   Reply With Quote
Old 02-04-2003, 04:13 PM   #6
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
I don't have any real reason to rewire the car, the audio equipment is direct lined and fused seperately. I simply need more power available off the alternator, as the fuse rate on the 2 amps is 40A and 50A respectively, so if you take their max draw at 90A combined vs a 75A alternator peak, then add the car electrics to it, should my heater turn on with my headlights we're probably talking 140A-150A. I don't listen to things at great volume, so I can assume safely 25A and 30A draw giving me 55A of draw there, but the lights and electrics still put me way over 75A, which means dead alternators and batteries. I'll have to go digging around and see what I can find I guess. I sent a request into Subaru for an OEM high-output alternator. They used to put nice 110-120A alternators on the older models, we'll see what they say. Other than that, I believe Bosch makes a lot of aftermarket higher current capacity alternators. The rest of the wiring can stay just how it is, save probably the battery and the battery<>alternator lines. No added draw is being placed on any of that circuitry.
Old 02-04-2003, 04:43 PM   #7
Styley1
Member#: 32566
1999 911 C2
XBL GT: Fenrick
Default alternators
I recently spoke with a tech from Esoteric Audio (the guys who make Street Wires and some other decent equip) about the situation.
I am planning on transplanting the system from my integra into my WRX:
RF 360a2
RF 201S
AudioControl EQQ
Only about 300W total.
He said that it should be fine, and a 1F cap would be plenty (and a lot cheaper than a new alternator). With a 5F cap and the system you mentioned... I wouldn't think you would have much problem... just a shorter alternator life. You might want to give them or another audioshop (that doesnt' make alternators) a call. Hope this helps.
Styley1 is offline   Reply With Quote
Old 02-04-2003, 06:45 PM   #8
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
Well, it all comes down to the numbers. The shop doesn't make alternators, it was just a suggestion, and a correct one.
Alternator peak = 75A, so you can assume at normal engine speeds we're talking 65-70A output.
JL 300.2 Amp fuse rating = 40A, so 40A max / safe levels 25A constant draw
JL 500.1 Amp fuse rating = 50A, so 50A max / safe levels 30-35A constant draw.
Bear in mind, *ALL* a capacitor does is help for quick peaks, if you're drawing over your alternator rating consistently, your capacitor is doing absolutely nothing for you, except possibly making the problem less apparent to you.
Even running 300W total, it's a numbers game. The 75A alternator is just not a lot, especially if you have fog lamps, and it's winter time. You can safely assume with your normal headlights and fog lamps you're running 20A of draw right there, add the heater on, and I have a hard time guessing, but it's not going to be less than 5A draw, which brings you to 25A load.
300W / 13.8V = 21A, assuming 100% efficiency on your amp(s). 75% is a more reasonable estimate, for a good quality amp.
so If we assume 75% efficiency on 300W output, giving you 400W draw at 13.8V (perfect, no drop) you're talking 28A draw peak. Which means you're still safely under 75A, and your capacitor will probably be enough saving grace for you. If voltage starts dropping below 12V, you might be drawing up to 30-35A.
Now we take 300+500W output amps, assuming both 80% efficiency
300 / .8 = 375, 500 / .8 = 625. 1000W @ 13.8V means you're hitting 72A of draw. Toss in headlights, heater, foglamps, headunit, basic electrical systems, and you can clearly see that 75A isn't going to cut it. Long driving times with the system on would outright kill the battery unless you turned it off and let the car run to charge it back up, and your alternator is going to go about once a year.
The recommendation to replace an alternator at that point is well founded, especially for those of you running lightened alternator pulleys! Beware, those make your alternator signifigantly less efficient.
If you don't like doing all these numbers, just check the recommended fuse rating for your amps. The 300.2 is 40A and the 500.1 is 50A, which means manufacturer specifies it's safe for them to draw that amount of current before they should be shut down. That's 90A alone, by manufacturer specs.
I am very open to suggestion on this though, especially real-world voltmeter testing. I'd like to see how these are holding up. I know someone said they've had to replace their alternator yearly running a single 800W amp. Something to keep in mind.
Old 02-04-2003, 07:08 PM   #9
Krelkor
Member#: 6630
2001 GC8
black
i talked to dominick over on termpro
im sure someone who does stereos knows who im talkin about...
one of the best alternator guys out there
he can get me a 160a in stock casing for 399
or he can go to 205 for 389, but its a little bit bigger
if i want to go custom i can go up to 280a
i think im going to get the 205a
his alts put out about 90% at idle.... so they are good stuff
Krelkor is offline   Reply With Quote
Old 02-04-2003, 07:09 PM   #10
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
i have the JL 300.2 and 500.1 and a one farad cap. stock everything else. my lights dim a little at idle but thats about it. the volt meter never drops below 12.5
Nate
NateDogg is offline   Reply With Quote
Old 02-04-2003, 07:19 PM   #11
ruiner
Member#: 20784
2002 Impreza WRX
WR Blue
I'm actually having my alternator rewound to about 145 amps hot. That's all they were able to get out of the casing that the stock WRX is. Unfortunately there are NO aftermarket alternators available for Subaru vehicles that I was able to find so I had to have a stack and stator built custom for my vehicle. If there is any interest in a high output alternator similar to mine, send me a PM and I'll see what I can do. Ideally I would need a stock WRX alternator in order to do this, but if you cannot supply it, I can possibly come up with something of my own. I have one extra stocker at the moment, but it might be spoken for I'm not sure yet.
An alternator such as the one I could possibly supply, would be able to handle a stereo up to 2200 watts, as long as you used an Optima battery or similar.
Chad
ruiner is offline   Reply With Quote
Old 04-26-2005, 11:21 AM   #12
RodimusPrime
Member#: 82118
2005 GD6 2.5RS
Crystal Gray Metallic
Resurrecting an old thread....
Does anyone know for sure what the stock alternator output is on a 2005 2.5RS?
This thread claims it's 75amps, but I have read elsewhere that the N/A engines have a bigger alternator than the WRX's. Does anyone know?
Question part 2) Is a total of about 400W RMS too much for a stock battery / alt?
(That would be from a 90Wx2 amp for the front speakers, and a 200W basslink)
RodimusPrime is offline   Reply With Quote
Old 04-26-2005, 12:34 PM   #13
cgerald1
Member#: 34144
2003 WRX Wagon
Here is a site with formulas that look about right:
HO Alternator Calculations
When I get a minute I will review the calculations and try to apply this to our cars...maybe make a VB calculator if I get time.
cg
Edit: Another good formula site more formulas
yet another good link: How batteries relate to Alternators
cgerald1 is offline   Reply With Quote
Old 04-26-2005, 07:05 PM   #14
TheMort
Member#: 29371
2002 Subaru WRX
Rally Blue
Does anyone have any experience with these Alternators Almost double the stock 75A, for $320.
TheMort is offline   Reply With Quote
Old 04-27-2005, 01:02 AM   #15
Scoobyracer1
Member#: 35114
I have an AFTERMARKET ALT on my wrx...
150AMP alt that produces :
130 amps @ 1000 RPMS
150 amps @ 1667 RMPS (Hot Rating)
It produces around 180 AMPS cold (SAE)
Unfortunatly they arent cheap, but if you are doing a FULL blown install.... u may need one...
After everything is said and done you are looking at over $500 for a quality piece of equipment...
As for these: http://www.2kracing.com/product_info...oducts_id/2650
The biggest problem is there are no specs... IE what it REALLY puts out... and are they hot or cold ratings... When does the ALT achieve max power...
Mine is linear driven... Made to produce max power right away and stay there.... It doesnt keep increasing... (wound ones typically do this) IE go from 1000rpm idle 40amps.... 5000rpm 120amp (Cold)....
In reality it may be only a very small increase over stock... The only way to tell is with spec sheets...
Scoobyracer1 is offline   Reply With Quote
Old 04-27-2005, 10:07 AM   #16
RodimusPrime
Member#: 82118
2005 GD6 2.5RS
Ok back to my original question
Can anyone confirm for a stock 2005 RS - what is the alt output?
75A, like the WRX, or more? I have read differing opinions...
Old 04-27-2005, 10:42 AM   #17
ruiner
Member#: 20784
2002 Impreza WRX
WR Blue
The stock RS alternator is 75A. The only one that is higher is the STi at 90A, and I believe the Outback or Forrester may also use the 90A unit.
Old 04-27-2005, 11:09 AM   #18
RodimusPrime
Member#: 82118
2005 GD6 2.5RS
Thanks ruiner - exactly what I was looking for.
Old 06-01-2013, 02:11 AM   #19
best1
Member#: 268495
I have a jdm ej207 v7, is the alternator interchangeable with USDM ej257? bc mine is shot, killed 2 batteries. I probably need a hi performance /high amp alternator
best1 is offline   Reply With Quote
WTB : An alternator...any working alternator RallyGuy2k TXIC Private Classifieds 3 04-29-2010 08:11 PM
wtb--timing idler pulley, alternator and alternator bracket skate enjoi MWSOC Private Classifieds 2 06-05-2008 05:42 PM
is my Impreza Alternator SO much more than a Legacy alternator ? IllNastyImpreza Electrical & Lighting 4 06-04-2007 01:06 PM
Relationship between alternator whine, voltage, and alternator health caterpill Electrical & Lighting 2 01-16-2005 06:15 AM
Music: Is there an alternative to the alternative?? O2-GGA Off-Topic 20 02-05-2004 07:27 PM
