Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 12-23-2012, 03:34 AM   #1
Member#: 341355
2005 sti
Default Isc coilovers seized up! Help!
I have isc coilovers on my 05 Wrx! The back passenger side coilover is seized up, I got the nut to break loose to lock it in place but the actually pillar part that you twist to lower the car is seized up and won't budge! I've sprayed with pb and I've used a pipe wrench to twist it and it still won't move at all! Help! Any ideas on what to do?
Brabbit40 is offline   Reply With Quote
Old 04-23-2013, 02:07 PM   #2
Member#: 293680
2002 wrx
wow can't believe no one has replied to this. Im in the same boat. My front left one seized up and wont twist down either
wrxbugeyekid02 is offline   Reply With Quote
Old 04-23-2013, 02:33 PM   #3
Member#: 218072
2002 wrx
I had this happen when I was replacing the rear shafts I got as a replacement from AJW. I ended up putting the shaft in a vice and using a 3 foot pipe as leverage to spin the mounts off. I didnt care about my threads though since I was was replacing the shaft anyways.
mike245 is offline   Reply With Quote
Old 04-23-2013, 08:37 PM   #4
Member#: 163703
09 Forester
Had this happen and did all that could. Ended up contacting ISC and ordering replacement rears. This time I will grease it up before putting them on.
silviajdm is offline   Reply With Quote
Old 04-23-2013, 11:13 PM   #5
Member#: 340677
2005 LGT 5EAT
After you get them loose, ANTI SEIZE the bodies. Run the nuts all the way up and down the body and then wipe off a bit of the excess, leaving a film on. If you have to readjust down the road, simply use a brush to remove any crap that stuck to the film and loosen and adjust and apply another film of ANTI SEIZE.
jmp6889928 is offline   Reply With Quote
Old 04-24-2013, 02:05 PM   #6
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Another thought would be to use a better coilover which offers superior corrosion resistance if you're going to live and drive in regions of the country which see a lot of rain, snow, and salt which might cause corrosion and lead to situations like this.
I realize not everyone has money for the expensive brands, but how many times do you need to waste money fixing and repairing the cheap stuff before you kick yourself for going cheap?
You could also find some form of rust inhibiting spray or perhaps a dry film lubricant to spray onto the body/threads which might slow the rate of corrosion. Adding a grease or anti-seize is more than likely just going to attract sand and ruin things.
Scooby921 is offline   Reply With Quote
