Old 04-19-2013, 01:55 PM   #1
Garbels90
Member#: 322129
2007 Impreza SE
Newport Blue
Default Low Idle?
Hello ive owned my 07 Non-turbo manual impreza for almost a year now and ive noticed that it idles at a very low rpm. 500 ish low. I asked around and was told that it could be that my fuel pump seal or the pump itself. Any ideas or has anyone else had this problem and found out any information on it? Thanks
Garbels90 is offline   Reply With Quote
Old 04-19-2013, 09:23 PM   #2
RallyB
Member#: 294247
2007 Impreza
Sounds normal to me, thats where my 07 idles, I wouldnt really worry until the idle is at like 100, then you have a problem
RallyB is offline   Reply With Quote
Old 04-19-2013, 10:13 PM   #3
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
If it doesn't stumble and stall it's fine.
Rudgers73 is offline   Reply With Quote
Old 04-20-2013, 01:53 AM   #4
Matthew88
Member#: 127834
2007 2.5i Wagon
My 07 idles around 600. I found it low as well, but it's never lowered or fluctuated. Always a constant 600 rpm. Seems normal to me.
Matthew88 is offline   Reply With Quote
Old 04-25-2013, 07:34 PM   #5
Bubakanush
Member#: 209975
2016 WRX
LBP
My 06 idles between 500-600 usually as well. Pretty sure thats the norm
Bubakanush is offline   Reply With Quote
Old 04-27-2013, 10:49 AM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
My 2.5L '98 idles around 600RPM once warmed up a little. Is yours smooth or rough? Mine is a little rough until warm, likely need to clean the IAC.
Old 04-27-2013, 03:09 PM   #7
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Subarus idle somewhat low.
goregasm is offline   Reply With Quote
Old 04-27-2013, 04:11 PM   #8
GrundleJuice
Member#: 165749
The 07 2.5i 5MT ecu idle speed table is set at 700 rpm once the water temp reaches a temp threshold. If it idles lower and the ecu had not been reprogrammed then there is probably something wrong.
Its worth noting that the tach graduations below the 1000rpm mark are not the same as above. The first graduation is 500 rpm.
Old 04-27-2013, 07:20 PM   #9
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
The gauge isn't 100% accurate. Especially at low RPM ranges, it can be a couple hundred off. Stop trying to scare him.
Old 04-27-2013, 07:46 PM   #10
GrundleJuice
Member#: 165749
It is quite accurate. Might lag behind the actual Engine speed on fast accel/decel when revving but it's close enough to indicting what the ecu is detecting that I can't see any error.
I'm not trying to scare anyone. This is not the first thread on this exact subject and it was an error in reading the tach gauge on the last one.
Old 04-28-2013, 12:47 PM   #11
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
My 05 rs idles low...usually around 500 or so but then drops to as low as 100 and wants to die out...then it will jump back up...
Any ideas why...
Jb2.5rstst is offline   Reply With Quote
Old 04-28-2013, 06:47 PM   #12
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Any ideas why...
Dirty/oil caked IAC?? That would be the 1st thing to check.
Old 05-29-2013, 06:44 PM   #13
RallyB
Member#: 294247
2007 Impreza
That sounds like its just the O2 sensors working, when does it do that?
Old 05-29-2013, 07:22 PM   #14
VIsubi
Member#: 187834
06 2.5i impreza
Red
Got a cobb accespsort for 200 bucks for the 2.5i models if your intrested or if you feel like adjusting that idle from stock to 400 rpm up..along with all the other tuning goodies it can do
VIsubi is offline   Reply With Quote
Old 05-30-2013, 10:38 AM   #15
RallyB
Member#: 294247
2007 Impreza
Where would one find a cobb accessport for a 2.5i? I tried finding one already and had no luck and believe they were discontinued by both cobb and rallitech
Old 05-30-2013, 02:26 PM   #16
hatchimon
Member#: 206333
Try cleaning out the throttle body. Usually oil residue from the intake manifold builds up and doesn't allow as much air into the engine.
hatchimon is offline   Reply With Quote
Old 05-31-2013, 12:27 AM   #17
Jb2.5rstst
Member#: 330553
2005 subaru 2.5 rs
I replaced both o2 sensors and still having the same idling issue. It only happens when in drive or reverse and at a stop, it will idle very low and high vibrations...
Next step is to clean the throttle body and try and see if my throttle sensor is acting up....
This started after I replaced my headgasket...
Old 05-31-2013, 11:27 AM   #18
GrundleJuice
Member#: 165749
How much atf fluid and what condition is it in? Sounds like it might be a transmission/tq converter issue. I stress "might".
Old 06-01-2013, 12:21 AM   #19
cctalley
Member#: 358054
1993 Impreza L AWD
Mine idles at 500 to 600, but doesn't stall or anything. The boxer 4 can be a little rough on idle, same as in a 70's Porshe 914 I used to have.
cctalley is offline   Reply With Quote
Old 06-01-2013, 11:35 AM   #20
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Trying to scare him? As Race Face said, this topic has come up a number of times, and more than once the result has been the OP realizing that their car was not idling that low, it was just that they were reading the tach wrong.
What are you basing your gauge inaccuracy claims on? Stop trying to scare people.
Originally Posted by RallyB View Post
That sounds like its just the O2 sensors working...
No.
Old 06-01-2013, 03:39 PM   #21
GrundleJuice
Member#: 165749
Can you post a picture or video of the tach when it's idling? First with everything off and again with the a/c on. Make sure it's warmed up , too
Old 06-02-2013, 10:04 PM   #22
ENCHILADAS
Member#: 352836
Do you have a CEL? If so what code?
ENCHILADAS is offline   Reply With Quote
Old 06-03-2013, 03:09 PM   #23
Lithel
Member#: 221307
2007 Impreza
My '07 Subaru idled a little low last year, and a bit unstable, but cleaning the IAC fixed it for me.
Lithel is offline   Reply With Quote
Old 07-17-2013, 08:02 PM   #24
Garbels90
Member#: 322129
2007 Impreza SE
Newport Blue
No it seems pretty smooth for the most part.
Old 07-17-2013, 08:04 PM   #25
Garbels90
Member#: 322129
2007 Impreza SE
Newport Blue
No CEL is showing just the low idle
